THRASHED Posted September 4, 2016 Share Posted September 4, 2016 I've got a grinding noise up front when leaving a stop. Likely culprits are front sprocket and/or chain slider. I found a chain slider, but can't seem to find a stock sprocket. Anybody have a link to a supplier? Also, is there really that much difference between the stock (rubber internals) and aftermarket as far as sound and vibration? Thanks, Scott Link to comment Share on other sites More sharing options...
THRASHED Posted October 4, 2016 Author Share Posted October 4, 2016 Just in case someone else has this issue. $22 and about 20 minutes and problem solved. The twin rings ( assume they were originally soft rubber) were shot. When the chain rubbed against these rings it caused a grinding sound. Popped on a new aftermarket sprocket and problem solved. Link to comment Share on other sites More sharing options...
