Member Contributer mello dude Posted September 25, 2016 Member Contributer Share Posted September 25, 2016 Park the bike immediately. Voltage is way too high. You need an R/R minimum, but I would check the stator AC voltage on each leg too. (A to B, B to C, and C to A) BTW - 16 volts is too high too. Link to comment Share on other sites More sharing options...
Member Contributer thtanner Posted September 25, 2016 Member Contributer Share Posted September 25, 2016 100% agreed with mello dude there. You should never see above 15v while charging. A high voltage situation is usually a faulty regulator (as mentioned), but 100% do your stator checks. Check AC voltage between the legs, as well as continuity to ground (you should have none). Link to comment Share on other sites More sharing options...
bobbyn Posted September 25, 2016 Share Posted September 25, 2016 7 hours ago, mello dude said: Park the bike immediately. Voltage is way too high. You need an R/R minimum, but I would check the stator AC voltage on each leg too. (A to B, B to C, and C to A) BTW - 16 volts is too high too. I thought that was too high. I didn't park it today (way too nice out), but I did get that rotten egg smell of an overcharged battery when I got home. The R/R needs to be replaced. Any suggestions? Link to comment Share on other sites More sharing options...
Member Contributer thtanner Posted September 25, 2016 Member Contributer Share Posted September 25, 2016 MOSFET based unit is a must now days. This is a nice kit: http://roadstercycle.com/ Link to comment Share on other sites More sharing options...
duccmann Posted September 25, 2016 Share Posted September 25, 2016 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
bobbyn Posted September 26, 2016 Share Posted September 26, 2016 On September 25, 2016 at 4:56 PM, bobbyn said: Any R/R suggestions? Link to comment Share on other sites More sharing options...
Member Contributer thtanner Posted September 27, 2016 Member Contributer Share Posted September 27, 2016 On 9/25/2016 at 2:11 PM, thtanner said: MOSFET based unit is a must now days. This is a nice kit: http://roadstercycle.com/ Link to comment Share on other sites More sharing options...
bobbyn Posted September 27, 2016 Share Posted September 27, 2016 16 hours ago, thtanner said: On 9/25/2016 at 5:11 PM, thtanner said: MOSFET based unit is a must now days. This is a nice kit: http://roadstercycle.com/ This web site confuses me even more. I'm looking for plug-in play. Link to comment Share on other sites More sharing options...
Member Contributer thtanner Posted September 27, 2016 Member Contributer Share Posted September 27, 2016 Then you will not find a quality unit. The only MOSFET based plug and play option is a Ricks Hotshot Rectifier, which people have reported failing after 30-40k miles (not much of an improvement, if any). It's very easy to install the kit, and it's pretty much the defacto replacement. Kit to buy: The Super Mosfet Kit FH020AA - there are other options there but I personally prefer the FH units over the SH ones. How to install: http://www.roadstercycle.com/Easy Mosfet Install.htm Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted September 30, 2016 Member Contributer Share Posted September 30, 2016 I've settled on putting my FP's massive SH847 under the rear tail unit. Not so much because it necessarily requires the airflow, but because there's nowhere else it will fit! Ciao, Link to comment Share on other sites More sharing options...
bobbyn Posted October 1, 2016 Share Posted October 1, 2016 I bought an R/R from RMStator. Meter reads 14.2 volts @ 5k rpm. Sweet. Link to comment Share on other sites More sharing options...
duccmann Posted October 1, 2016 Share Posted October 1, 2016 JZH Great job--Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted October 1, 2016 Member Contributer Share Posted October 1, 2016 Has anybody actually fitted a SH847 in the stocker 5th gen spot? I made up a wood block to size 4 3/4 x 4 3/4 x 1 1/2 inches to check it out. Huge. Its looking like a no go.... Link to comment Share on other sites More sharing options...
bobbyn Posted October 1, 2016 Share Posted October 1, 2016 This MOSFET device looks like it requires major rearranging of seats, systems, maybe even adding a tail rack just to install it. Not my idea of a day well spent in the garage. Link to comment Share on other sites More sharing options...
Member Contributer thtanner Posted October 1, 2016 Member Contributer Share Posted October 1, 2016 27 minutes ago, bobbyn said: This MOSFET device looks like it requires major rearranging of seats, systems, maybe even adding a tail rack just to install it. Not my idea of a day well spent in the garage. That is a SH device pictured, which is a Shunt style, not MOSFET. I suggested the FH020AA, which is smaller, and MOSFET based. Glad you're back on the road; hope your direct replacement lasts longer than others have reported. Worst case, you know for next time. Link to comment Share on other sites More sharing options...
duccmann Posted October 1, 2016 Share Posted October 1, 2016 Look at pat #30--- that was the only logical place to mount mine since I'll never remove my top boxFYISent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted October 1, 2016 Member Contributer Share Posted October 1, 2016 To clarify on the R/Rs both the FH012AA and FH020AA are both MOSFET R/Rs --- the other we are referring to the SH847 and SH775 are series style R/Rs, with the 847 being a new model at 50amps and kinda large. The FH020 AA is near OEM size and with fit in most stock locations. Plenty of guys have used this one and it is reliable. Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted October 2, 2016 Member Contributer Share Posted October 2, 2016 15 hours ago, bobbyn said: This MOSFET device looks like it requires major rearranging of seats, systems, maybe even adding a tail rack just to install it. Not my idea of a day well spent in the garage. Better a day spent in the garage than on the side of the road waiting for a tow truck! I was almost stranded the day my Stator/RR failure. To add insult to injury, the two main motorcycle tow services were either too busy or not is service that day. What started out as a lunch with some friends turned into a whole day of running back and forth to the Honda dealer to get a new battery to at least get me going. Link to comment Share on other sites More sharing options...
Auspanglish Posted October 2, 2016 Share Posted October 2, 2016 ...and then the battery burst into flames... I'd rather spend a day in the garage then have my balls blown off and then crash and burn into a smouldering heap. There's a jocular tone to my statement but it's simultaneously deadly serious. Rotten eggs to fried eggs, a poofteenth away... Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted October 3, 2016 Member Contributer Share Posted October 3, 2016 1 hour ago, Auspanglish said: I'd rather spend a day in the garage then have my balls blown off and then crash and burn into a smouldering heap. Really?! I thought it was better to go out in a blaze of glory. Link to comment Share on other sites More sharing options...
