fabio222 Posted September 3, 2013 Share Posted September 3, 2013 Hello all, Some of you may know that the fuel pump on my 750 packed up recently and was only brought back to life by the mechanic filing down the points inside. He said it'll work for a while but that I will definately need to get myself a new one. Of course the OEM one is a ton of money and will eventually break again so I am looking at getting something cheaper that will also last longer. Facet seem to do a range of pumps but is there one in partiuclar that will work as good as OEM and not flood the engine? There is also this one but again might it flood the engine: http://www.ebay.ie/itm/12V-ELECTRIC-FUEL-PUMP-UNIVERSAL-DIESEL-OR-PETROL-/261060771194?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cc86f3d7a And then this one: http://www.ebay.co.uk/itm/HONDA-CBR600-900-VFR750-Replacement-Fuel-Pump-/111142109343?pt=UK_Motorcycle_Parts_13&hash=item19e096009f What would your recommendations be? Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 3, 2013 Member Contributer Share Posted September 3, 2013 Cheaper and last longer donot match imho...... I would call a few breakers in Ireland if I were you and get a used oem. Sure, no guarantees but still Honda. Found one in NL for you, maybe combine with a trip to Amsterdam? http://www.motorparts-online.com/#MXJlY29yZHNldHxodHRwOi8vd3d3Lm1vdG9ycGFydHMtb25saW5lLmNvbS9yZXF1ZXN0X29uZGVyZGVlbC5waHA/cGlkPTAuMzE2ODk0NjM0OTA3ODEzNiZzdGFydF9wb3M9NjAmb25kZXJkZWVsX2lkPTEwNDMxNA== Link to comment Share on other sites More sharing options...
fabio222 Posted September 3, 2013 Author Share Posted September 3, 2013 Normally I would agree with the cheaper but last longer thing! However the last pump linked in my original post is a solid state pump with no moving points so it should never burn out. The thing I am worried about is pressure etc. As for a trip to Amsterdam...well my girlfriend is moving to some place near Le Mans for a few months next year and I'll be visiting on the VFR. Can't rule out a trip up to Amsterdam, I'll be sure to get in touch with you! Link to comment Share on other sites More sharing options...
V4 Rosso Posted September 3, 2013 Share Posted September 3, 2013 Why not get replacement contact points? http://www.wemoto.com/bikes/Honda/VFR_750_FL__RC36/90/picture/Fuel_Pump_Repair_Kit_-_Point_Switch/ Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted September 3, 2013 Member Contributer Share Posted September 3, 2013 I remember this coming up once before. Someone found a replacement pump, but in the end he had problems with it. A search and almost every thread on that pump was people having problems with it. I would search for an OEM unit, and in the mean time, keep what tubing you need to run a gravity feed system, just in case. Link to comment Share on other sites More sharing options...
fabio222 Posted September 3, 2013 Author Share Posted September 3, 2013 You see that's the thing, a lot of people report some form of problems with non-OEM pumps too despite the OEM pumps also being crappy! Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted September 3, 2013 Member Contributer Share Posted September 3, 2013 It was a pressure issue IIRC. The aftermarket ones were pushing more pressure than they were supposed to. It is not too often that I hear a VFR pump completely go out. Is the part Rosso linked to a solution? Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted September 3, 2013 Member Contributer Share Posted September 3, 2013 hit the breaker yards a pull one from 600 Link to comment Share on other sites More sharing options...
fabio222 Posted September 3, 2013 Author Share Posted September 3, 2013 I've bought a new set of points. Looking at the service sheet from the shop it says "Cleaned Fuel Pump Contacts (Will Need PNT" That is exactly how it is printed on the sheet from the workshop so I guess PNT is points. So I went and bought new ones and will fit them myself and hope for the best. Might include the fuel pump points as an inspection at the 8000 mile service each time. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 3, 2013 Member Contributer Share Posted September 3, 2013 Take pictures and post 'm up! I will go to the shed now and get myself a can of Guinness Draft! Link to comment Share on other sites More sharing options...
