Member Contributer luvtoleanit Posted June 13, 2014 Author Member Contributer Share Posted June 13, 2014 Talked to Jamie via email and he's working on my forks as I type. Bodywork, top box, and panniers are at my painters and that will be painted next week. Don got my ECU back to me pretty fast. I'm running out of patience. As soon as this stuff is ready it's still gonna be a month before the bike is ready to tune :( Must have patience................. Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted June 23, 2014 Author Member Contributer Share Posted June 23, 2014 Forks are back from Jamie. Look good to go. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted June 23, 2014 Member Contributer Share Posted June 23, 2014 Forks look good .... Link to comment Share on other sites More sharing options...
crakerjac Posted June 23, 2014 Share Posted June 23, 2014 Forks are back from Jamie. Look good to go. Yup... I knew it... Those stickers look a little crooked. Better save yourself the embarrassment and send those forks my way. But seriously. I cant wait to hear what you think. I talked with Jamie a while back, but due to my current financial situation, I'm going to have to wait on buying more bike stuff.... so I'm going to have to live vicariously through you. Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted June 23, 2014 Author Member Contributer Share Posted June 23, 2014 Been there dude. I'm years behind. Have to get the bikes done as the house projects are looming and they make bike mods look like peanuts :( I originally was going to do Ohlins inserts, modified to fit by Dan Kyle but I got convinced of Jamie's work. Will probably be a month before I get to throw a leg over it. Jamie's fork solution is very value priced. A fraction of what you could spend. Link to comment Share on other sites More sharing options...
lshark Posted June 23, 2014 Share Posted June 23, 2014 what exactly is included in Jamie's mod Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted June 23, 2014 Author Member Contributer Share Posted June 23, 2014 http://www.daughertymotorsports.com/vfr800.html Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted July 15, 2014 Author Member Contributer Share Posted July 15, 2014 Kory is making some progress. Pair covers installed. Gold Teef! Rear hugger. PM'd hvfrdave to see if the OEM hugger, well if there is going to be issues with the Ohlins bracket and the hugger touching. Check your PM's dude! Thurn's suspension links. Talk about jacking up the rear! Was supposed to be a 20mm rise, this is more like 32mm!!!!!!! Need to get a hold of Thurn Rear carrier back on, with a missing cover, which is driving me nuts! (Can't find a replacement, Honda doesn't sell them!) PC5/Autotune wired in. Switch for autotune off/on more to come later. Got my pearl white bodywork back from the painters! Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted July 18, 2014 Author Member Contributer Share Posted July 18, 2014 Had to pull the Thurn suspension link....it was designed for the stock shock, not Ohlins. Kory put it back together with the stock link so we could check sag and numbers look OK. Got to test the Sargent and it's pretty cool. Big improvement over stock. Link to comment Share on other sites More sharing options...
crakerjac Posted July 18, 2014 Share Posted July 18, 2014 Those are some beefy looking PAIR plates. Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted July 21, 2014 Author Member Contributer Share Posted July 21, 2014 Some body pieces were fitted to check color on the bike. Link to comment Share on other sites More sharing options...
Member Contributer arrow Posted July 21, 2014 Member Contributer Share Posted July 21, 2014 Is it possible that aftermarket shocks for the VFR1200F are a bit longer than the stock item? I recently had a Hyperpro shock installed, and although I have not yet set the sag, the rear end seems noticably higher than usual. This is pure speculation of course, I have not measured anything at this point... Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted July 21, 2014 Author Member Contributer Share Posted July 21, 2014 Is it possible that aftermarket shocks for the VFR1200F is a bit longer than the stock item? I recently had a Hyperpro shock installed, and although I have not yet set the sag, the rear end seems noticably higher than usual. This is pure speculation of course, I have not measured anything at this point... Yes sir. The Ohlins is +8mm compared to stock. Stock, the rear is too low IMO. A quick check to see if your Hyperpro is longer is to put the bike on the sidestand. If you notice that it leans a little farther on the kickstand then that is the tell-tale sign if you didn't measure. +8 is plenty for me. +5mm would have been sufficient, but +8 is even better. I can't wait until the cat is cut so I can get a map made and start riding it. All it is waiting on is that and to wire the Autotune in, put the bodywork on, and she's done. Well, at least until someone finally makes some rearsets for this thing. Link to comment Share on other sites More sharing options...
f3racer Posted July 23, 2014 Share Posted July 23, 2014 Dude I am super jealous Link to comment Share on other sites More sharing options...
Headhunter Posted July 24, 2014 Share Posted July 24, 2014 Dude I am super jealous X10000 Link to comment Share on other sites More sharing options...
gloryracing Posted July 24, 2014 Share Posted July 24, 2014 Once you ride with your new suspension you may find that rearsets are not necessary. Stiffer springs in the front and a Penske on back and I no longer scrape pegs. It worked well for my ride! Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted July 24, 2014 Author Member Contributer Share Posted July 24, 2014 Once you ride with your new suspension you may find that rearsets are not necessary. Stiffer springs in the front and a Penske on back and I no longer scrape pegs. It worked well for my ride! I figured as much but I would still like them. Thurn's footpegs don't fit despite what he says. I'm tired of adjusting riding position and boots bring the stock footpegs up, quite alarming. I'd like them up just a hair and definitely back. Nobody makes them though so it's moot. Link to comment Share on other sites More sharing options...
lshark Posted July 25, 2014 Share Posted July 25, 2014 my vfr has been running a little hot, only on 3rd bar but throwing a lot of heat at my inner thigh and through the seat...i suspect the ohlins bracket is blocking a lot of airflow...(installed ohlins over this past winter) ...did this with a punch press at my buddy's shop....let's see if this helps at all Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted July 25, 2014 Author Member Contributer Share Posted July 25, 2014 I doubt that is your issue judging by location. Link to comment Share on other sites More sharing options...
duccmann Posted July 25, 2014 Share Posted July 25, 2014 Looks good...you must be printing up yur own green backs:D Sent from my SGH-T679 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted July 25, 2014 Author Member Contributer Share Posted July 25, 2014 Nope. Years and years of savings, foregoing eating out, no more bar tabs, no kids, no trophy wife. Just hard work. ;) Link to comment Share on other sites More sharing options...
lshark Posted July 26, 2014 Share Posted July 26, 2014 it was 10 F cooler today (81 F) but it did feel like it helps....i've had the bike 3 years now and it has normally run at 2 bars on the temp gauge, bumping between 2 and 3 bars on hot days...it always was toasty around the right ankle but now it stayed at 3 bars and the heat was coming up toward my right thigh and the seat....it never did this even on 100F days...the right frame rail was almost too hot to touch....i suspect that that area is important to the cooling, acting like a chimney flue to create a draft to pull the heat out Link to comment Share on other sites More sharing options...
Guest Posted July 28, 2014 Share Posted July 28, 2014 These things DO run hot on the right side, and the frame rail is definitely something to stay away from in warm weather! We had a fast run up in temperatures on Saturday, and there I was out in 100 degree weather, and believe me- not enjoying it at all! Definitely not on the lower right leg- the worst spot. Pulled in and got a bite, and fortunately a off shore wind started coming in- dropped the temps to about 90- made a huge difference- almost digital- in comfort. I'd be surprised to hear you were uncomfortable in 81F weather, but then, I'd hazard that 70 would be a lot nicer.... like when I started out Saturday AM! Link to comment Share on other sites More sharing options...
Member Contributer luvtoleanit Posted August 3, 2014 Author Member Contributer Share Posted August 3, 2014 Link to comment Share on other sites More sharing options...
Member Contributer spinalator Posted August 7, 2014 Member Contributer Share Posted August 7, 2014 Very nice Link to comment Share on other sites More sharing options...
