silverbullet132 Posted September 26, 2011 Author Share Posted September 26, 2011 Ah, well I am going to try replacing the kickstand switch as someone had messed with it before. They are cheap enough anyways. Link to comment Share on other sites More sharing options...
Tightwad Posted September 26, 2011 Share Posted September 26, 2011 Check out your starter relay plug as well...the sidestand switch connects there and they commonly melt down. Link to comment Share on other sites More sharing options...
silverbullet132 Posted September 28, 2011 Author Share Posted September 28, 2011 Check out your starter relay plug as well...the sidestand switch connects there and they commonly melt down. Nothing melted on the starter relay. Also, did not get to checking the tip sensor...buuttt... While I had the tank up to check the fuel pressure regulator, I decided to try it. Bike had 0 problems starting with the tank up (near vertical) while in riding position with the kickstand down or up. So it now looks like something to do with a component of the fuel tank. Thoughts? Link to comment Share on other sites More sharing options...
VFRocker Posted September 29, 2011 Share Posted September 29, 2011 There's too much going on with this bike, don't know if any of it is related to original problem or if you're just having to sort out several things that have happened at the same time and possibly somewhat related. I'd check the connections on the fuel pump and see if you can trace the wires at least to where they enter the loom. You might have a loose connection or rubbed wire that started all of this by messing with your fuel pressure and your ECU trying to compensate? Link to comment Share on other sites More sharing options...
silverbullet132 Posted October 1, 2011 Author Share Posted October 1, 2011 There's too much going on with this bike, don't know if any of it is related to original problem or if you're just having to sort out several things that have happened at the same time and possibly somewhat related. I'd check the connections on the fuel pump and see if you can trace the wires at least to where they enter the loom. You might have a loose connection or rubbed wire that started all of this by messing with your fuel pressure and your ECU trying to compensate? Hopefully it is that simple, it is getting to be quite cold up here in Ontario :( Makes sense that it could be the wires to the fuel pump, just the whole start on sidestand die as soon as tilted up thing complicates it. Hopefully a connection clean with some product on both the wiring and the fuel pump connectors fixes this issue, I really want to ride this thing. Link to comment Share on other sites More sharing options...
silverbullet132 Posted January 13, 2012 Author Share Posted January 13, 2012 Bump Link to comment Share on other sites More sharing options...
Member Contributer Ranger77 Posted January 17, 2012 Member Contributer Share Posted January 17, 2012 If you're still having problems then just get on ebay and get a '98-'99 harness. I've seen them cheap several times. Link to comment Share on other sites More sharing options...
silverbullet132 Posted January 18, 2012 Author Share Posted January 18, 2012 If you're still having problems then just get on ebay and get a '98-'99 harness. I've seen them cheap several times. Good suggestion, but I have read that the 98-99 harness could go bad while riding causing lights to flicker etc etc. It is an option, but if I have to replace the harness I will just get a 00-01 harness to eliminate the issue mentioned. Link to comment Share on other sites More sharing options...
silverbullet132 Posted March 9, 2012 Author Share Posted March 9, 2012 Pictures of some connectors mechanic found, also narrowed problem down to the running light circuit *the cut small green wire was done by him, to ground that circuit elsewhere to see if that solved it* any ideas? Link to comment Share on other sites More sharing options...
silverbullet132 Posted April 3, 2012 Author Share Posted April 3, 2012 Stator turned out to be bad...27v on one phase, 45v on another, and about 80v on the last one. Could this be what is causing the problems? Ordered a Rick's stator to replace. Link to comment Share on other sites More sharing options...
Member Contributer kaldek Posted April 3, 2012 Member Contributer Share Posted April 3, 2012 What. The. Eff. And I thought my problems were complex. Cutting ground wires to trace faults? Wow. Serious time. Link to comment Share on other sites More sharing options...
silverbullet132 Posted April 17, 2012 Author Share Posted April 17, 2012 Stator replaced but he now discovered the cover had been well messed up by the last owner. Found weld fixup spots, and I think caulking too. Told me when he replaced the stator it was hitting off of the flywheel rotor? Ordering a new OEM cover/gasket tonight/tomorrow. Link to comment Share on other sites More sharing options...
smoothsailin Posted April 17, 2012 Share Posted April 17, 2012 ... My 5th gen has 43000 miles with stock everything. No failures. Thanks Timmy...that's what I wanted to hear! While I'm planning to check out my '98's wiring & connnections before Tmac, if everything checks out o.k. I'll probably leave the stock wiring and connections alone. I may look for a way to relocate the RR for improved airflow/cooling though. Link to comment Share on other sites More sharing options...
silverbullet132 Posted May 6, 2012 Author Share Posted May 6, 2012 Update: Stator tested bad, replaced. After replacing the stator it was discovered that the stator cover has been bent and welded back up before. That has since been replaced, waiting for a call back. Hopefully that will be the last of the parts to be replaced. Link to comment Share on other sites More sharing options...
silverbullet132 Posted June 3, 2012 Author Share Posted June 3, 2012 Replaced the stator, replaced the stator cover, worked well. He started bolting stuff back on and tested it again, stator was fried. He is now testing the crank to see if it is bent :( Anyone have ideas? possible bent flywheel? Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted June 3, 2012 Member Contributer Share Posted June 3, 2012 New stator got insta-fried? Huh? Link to comment Share on other sites More sharing options...
silverbullet132 Posted June 3, 2012 Author Share Posted June 3, 2012 Basically. In testing it resulted that some of the stator phases/wires were shorting to each other. When he first put it in it was charging at 14.2-14.3v, now it charges at 15v+ and nothing has been touched in the electrics since the first install. Link to comment Share on other sites More sharing options...
Member Contributer kaldek Posted June 3, 2012 Member Contributer Share Posted June 3, 2012 Basically. In testing it resulted that some of the stator phases/wires were shorting to each other. When he first put it in it was charging at 14.2-14.3v, now it charges at 15v+ and nothing has been touched in the electrics since the first install. Overcharging has nothing to do with the stator, that's controlled by the regulator! The stator puts out anywhere between 24 and 100+ volts AC, the rectifier converts that to DC and the regulator circuit drops the voltage down to 14 volts. If your bike is charging at 15+ volts, your regulator is bad or you have a poor electrical connection between the regulator and the wiring harness and battery. Link to comment Share on other sites More sharing options...
Member Contributer kaldek Posted June 3, 2012 Member Contributer Share Posted June 3, 2012 Also, sounds like your mechanic is a bit of a muppet. Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted June 3, 2012 Member Contributer Share Posted June 3, 2012 Also, sounds like your mechanic is a bit of a muppet. :+1: nothing makeith any sence Link to comment Share on other sites More sharing options...
silverbullet132 Posted June 3, 2012 Author Share Posted June 3, 2012 I know the voltage is regulated by the R/R, but like I said the stator phases are shorting to each other. Link to comment Share on other sites More sharing options...
Member Contributer kaldek Posted June 4, 2012 Member Contributer Share Posted June 4, 2012 I know the voltage is regulated by the R/R, but like I said the stator phases are shorting to each other. I don't buy it. If it was doing that it wouldn't be generating ANY volts. Link to comment Share on other sites More sharing options...
silverbullet132 Posted June 4, 2012 Author Share Posted June 4, 2012 I know the voltage is regulated by the R/R, but like I said the stator phases are shorting to each other. I don't buy it. If it was doing that it wouldn't be generating ANY volts. I saw him do the test in front of me, either way I will be getting an update on it later today or sometime tomorrow. Link to comment Share on other sites More sharing options...
grump007 Posted September 15, 2017 Share Posted September 15, 2017 AHAA. good info. Link to comment Share on other sites More sharing options...
