So, planning ahead a little bit for when I'm able to treat my 5th-gen to a set of RC51 SP1 forks and brakes, I got to thinking about the rear brake caliper and master cylinder.
Based on the WOTL (er, make that the wisdom of VFRD) I had previously acquired a 14mm rear master, so I wanted to check how close that would allow me to be to OEM, or to some sort of comparable OEM ratio.
Basically, with the RC51 SP1 forks, the linked brakes are necessarily history, so all that remains is to put together something workable for the rear brake. I have chosen the RC36 VFR750F as my OEM "target", as that bike has similar weight and performance (at least in OEM form!) as my RC46-I. I put together the chart below, which shows all of the popular master cylinder and caliper combinations I could think of that are used on Honda sport bikes:
Rear Brake Ratios
RC36 rear brakes have a 9.04:1 ratio (2x 27mm pistons and 12.7mm master), so that is the goal to achieve with my RC46-I rear caliper, because I really don't want to have to engineer a bracket to mount a different caliper (e.g., the ultra-common 38.1mm single-piston NISSIN found on everything from F3 to 1000RR). The RC46-I (i.e., pre-VTEC) rear caliper has 2x 22.65mm pistons tied together and one 27mm piston in the center and a 17.46mm (11/16") master cylinder. It is clear from the chart that using either the two 22.65mm pistons or the 27mm piston alone cannot get anywhere near the OEM-ish ratio of 9.04:1 found on the VFR750FL-V, but using all three caliper pistons together can achieve very close to that (8.97:1), provided I use a 14mm master cylinder. Cool, that's what I've got!
(FYI, the VTEC's rear caliper is different--it has three identical 25mm pistons.)
Now, the only question is, what's the best way to achieve it? I see two options:
Mello Dude's $30 braided stainless steel loop and double banjo solution, as detailed elsewhere, or
Something more solid, like what I think is done in the CBR1100XX de-linking kit sold by J.A.W.S. in the UK (or maybe I'm thinking of the kit that was once sold by 123ignition, also in the UK)? Can't seem to find any pics on the 'Web, but in any case, the approach I'm thinking of consists of a short ~12mm square bar of alloy with three holes: the bar is bolted to the rear caliper by the two OEM banjo bolts (maybe need double banjo bolts), and the third hole is another M10x1.25 on the end--with the hole continuing at smaller diameter (e.g., 5mm) down through the bar and intersecting both of the other holes. It's essentially a manifold.
Oh, and there would be at least one other way I had forgotten about: Remove the caliper from the bike, as well as the pistons and seals, pop it onto the drill press and drill straight through the back of the center piston bore into the connecting passage for the other two pistons. Then, clean everything out and rebuild the caliper--plugging one of the banjo bolt holes with a M10x1.25 plug of some sort. I like it... It does depend on the connecting passage being where I think it is, though!
Requires a caliper rebuild and is permanent, but I'm not too bothered about that. Any thoughts?
Question
JZH
Rear Brake Ratios
Cheers,
16 answers to this question
