Member Contributer Ryanme17 Posted July 7, 2008 Member Contributer Share Posted July 7, 2008 Hey, I'm pretty new to the forum, so I'm not sure how this works, but my outside air temperature gauge works fine at first, but after a few minutes of riding, it gets colder and colder, and after about 5 minutes, it reads so cold it just displays the two lines (just like the engine temperature reads when it's below 100*). Any ideas what this is or how to fix it? --Ryan Link to comment Share on other sites More sharing options...
Guest Posted July 7, 2008 Share Posted July 7, 2008 In addition to checking the connections, you can pull the sensor and connect an Ohm meter to it to check the resistance. Should be 4.8 -5.2 @77 degrees F. Action Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted July 7, 2008 Author Member Contributer Share Posted July 7, 2008 In addition to checking the connections, you can pull the sensor and connect an Ohm meter to it to check the resistance. Should be 4.8 -5.2 @77 degrees F.Action I will check the resistance, thank you for the reference point! I was thinking maybe a bad resistor along the line somewhere? Not sure why it would start fine and then get colder, though... Link to comment Share on other sites More sharing options...
Baileyrock Posted July 7, 2008 Share Posted July 7, 2008 " Outside Air Temperature Gauge Too Cold" Move South! :biggrin: Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted July 8, 2008 Author Member Contributer Share Posted July 8, 2008 " Outside Air Temperature Gauge Too Cold" Move South! :goofy: That's hilarious! :laugh: Although that is often a problem here in Michigan, I mean it reads colder than it should until it stops working altogether. Plus, if I could move anywhere else, it would be someplace with better twisties. Link to comment Share on other sites More sharing options...
Baileyrock Posted July 8, 2008 Share Posted July 8, 2008 " Outside Air Temperature Gauge Too Cold" Move South! :goofy: That's hilarious! :biggrin: Although that is often a problem here in Michigan, I mean it reads colder than it should until it stops working altogether. Plus, if I could move anywhere else, it would be someplace with better twisties. Never heard of this one, but it's either got to be a faulty sensor or Dash. I don't think I have an extra sensor laying around, or I'd send it to you to test with. We have great twisties here in TN and little to No snow and year round riding! :fing02: Link to comment Share on other sites More sharing options...
SEBSPEED Posted July 8, 2008 Share Posted July 8, 2008 Never heard of this one, but it's either got to be a faulty sensor or Dash. I don't think I have an extra sensor laying around, or I'd send it to you to test with. We have great twisties here in TN and little to No snow and year round riding! :biggrin: You're such a tease Kevin... I've never heard of that problem either, I hope it's just something dumb like a dirty connector or something. Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted July 8, 2008 Author Member Contributer Share Posted July 8, 2008 I'll let you guys know when I get a chance to take it apart, check the connections and resistance. I have a honda service manual, I'll see if it has a wiring diagram that might show any resistors within the temperature sensor or between that and the dash, I wouldn't think a loose connection would do that, though a weak electrical signal might...? Either way, I'll let you guys know when I figure it out. --Ryan Link to comment Share on other sites More sharing options...
SEBSPEED Posted July 8, 2008 Share Posted July 8, 2008 The service manual most definitely does have the wiring diagram! You can also download the electronic version here, and then print copies you can scribble on. :biggrin: Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted July 11, 2008 Author Member Contributer Share Posted July 11, 2008 In addition to checking the connections, you can pull the sensor and connect an Ohm meter to it to check the resistance. Should be 4.8 -5.2 @77 degrees F.Action It read 4.4 ohms @ 77*F. I'm going to replace the outside air temperature sensor and see if that helps. Link to comment Share on other sites More sharing options...
DainiusM Posted March 3, 2009 Share Posted March 3, 2009 hello, from lithuania. my problem: http://www.youtube.com/watch?v=CvlpLJ6n9Cg I show you how in the displey not rising temperature... I turn on motorcycle, turn on hairdryer, heated open air sensor, but in the display temeprature not rising, I turn of motorcycle, and turn ignition again, there we can see that temperature displaying higher, and it falling down ... I'm changed open air sensor with new one, but problem is the same. What You suggest to do? Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted March 9, 2009 Author Member Contributer Share Posted March 9, 2009 hello, from lithuania.my problem: http://www.youtube.com/watch?v=CvlpLJ6n9Cg I show you how in the displey not rising temperature... I turn on motorcycle, turn on hairdryer, heated open air sensor, but in the display temeprature not rising, I turn of motorcycle, and turn ignition again, there we can see that temperature displaying higher, and it falling down ... I'm changed open air sensor with new one, but problem is the same. What You suggest to do? Check the resistance of your open air sensor with an ohmeter. FYI, the open air temperature sensor is located in the very nose of the bike. Link to comment Share on other sites More sharing options...
DainiusM Posted March 9, 2009 Share Posted March 9, 2009 hello, from lithuania.my problem: http://www.youtube.com/watch?v=CvlpLJ6n9Cg I show you how in the displey not rising temperature... I turn on motorcycle, turn on hairdryer, heated open air sensor, but in the display temeprature not rising, I turn of motorcycle, and turn ignition again, there we can see that temperature displaying higher, and it falling down ... I'm changed open air sensor with new one, but problem is the same. What You suggest to do? Check the resistance of your open air sensor with an ohmeter. FYI, the open air temperature sensor is located in the very nose of the bike. I'm checked reistance. Resistance same in manual. Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted March 11, 2009 Author Member Contributer Share Posted March 11, 2009 hello, from lithuania.my problem: http://www.youtube.com/watch?v=CvlpLJ6n9Cg I show you how in the displey not rising temperature... I turn on motorcycle, turn on hairdryer, heated open air sensor, but in the display temeprature not rising, I turn of motorcycle, and turn ignition again, there we can see that temperature displaying higher, and it falling down ... I'm changed open air sensor with new one, but problem is the same. What You suggest to do? Check the resistance of your open air sensor with an ohmeter. FYI, the open air temperature sensor is located in the very nose of the bike. I'm checked reistance. Resistance same in manual. Then I have no idea. The sensor is simply a piece of metal that changes with temperature. A small current is run through it and as the metal heats up and cools down, how easily electricity flows through it changes. It's basically just a fancy wire. You bike reads these changes in resistance and calculates the temperature. But if your sensor is reading the correct resistance, I don't know why your temperature never changes. It may be a problem with whatever "reads" the resistance to calculate the temperature. These electronics are located in the dash, I believe. Does everything else work correctly electronically? I'm sorry I can't be more helpful, try posting a new topic in this forum (electrical). There are a lot of people on here smarter than I am, someone else might know. Link to comment Share on other sites More sharing options...
vfr_steve Posted March 11, 2009 Share Posted March 11, 2009 strangely enough a good jetwash resolved mine - but my gauge told me the opposite with a rather optimistic reading. Link to comment Share on other sites More sharing options...
DainiusM Posted February 7, 2011 Share Posted February 7, 2011 strangely enough a good jetwash resolved mine - but my gauge told me the opposite with a rather optimistic reading. Any ideas? Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted February 7, 2011 Author Member Contributer Share Posted February 7, 2011 strangely enough a good jetwash resolved mine - but my gauge told me the opposite with a rather optimistic reading. Any ideas? I solved my issue by replacing the Outside Air Temperature Sensor. Other than that I can't really tell you much more than I already have. Link to comment Share on other sites More sharing options...
spud786 Posted February 8, 2011 Share Posted February 8, 2011 I luv my outside temp guage Link to comment Share on other sites More sharing options...
