Misspent Youth Posted April 11, 2013 Share Posted April 11, 2013 Most aftermarket bar ends for 7/8" bars are simply rubber plug insert/tighten arrangement. Sometimes a screw, sometimes an allenhead, to tighten. Quote Link to comment Share on other sites More sharing options...
V4 Rosso Posted April 11, 2013 Share Posted April 11, 2013 Has anyone done this on a 4th gen?An NTV650 top yoke is a straight swap on a 3rd & 4th gen VFR fork. No need to drill holes in the stock yoke. 2 Quote Link to comment Share on other sites More sharing options...
Member Contributer dalesvfr Posted April 11, 2013 Member Contributer Share Posted April 11, 2013 I did the LSL riser because it gives the option to go back to stock or Heli risers without sourcing a new top clamp. I suppose you could just put some type of plug in the holes though....Honda 599/919 bars worked for me as they were already punched for the indexing pin on the switch gear and the bars that came with the kit from Spiegler were still too low for me. I had to reroute clutch hose behind forktube so bleeding is required, and the throttle cable was disconnected at throttle body and rerouted as well. I like having a 7/8 bar to mount GPS, power outlet and controller for Gerbing jacket. 1 Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted April 11, 2013 Share Posted April 11, 2013 Has anyone done this on a 4th gen? An NTV650 top yoke is a straight swap on a 3rd & 4th gen VFR fork. No need to drill holes in the stock yoke. This is feckin brilliant. Quoted for emphasis. +rep for Rosso Quote Link to comment Share on other sites More sharing options...
Guest navas Posted April 12, 2013 Share Posted April 12, 2013 Nt 650 correct? Can't find anything on ntv 650 Quote Link to comment Share on other sites More sharing options...
V4 Rosso Posted April 12, 2013 Share Posted April 12, 2013 According to this wikipedia article a slightly modified version (e.g. chain drive instead of shaft drive) was sold in the US with the name Hawk GT. My notes show the top yoke dimensions of the 5th gen are the same as that of the 3rd and 4th gen so the NTV yoke should also fit the 5th gen VFR. Quote Link to comment Share on other sites More sharing options...
NakedViffer Posted April 12, 2013 Share Posted April 12, 2013 Pretty sure the Hawk had clip ons and not handlebars..? Not 100% Quote Link to comment Share on other sites More sharing options...
V4 Rosso Posted April 12, 2013 Share Posted April 12, 2013 Here there was also a model that had (sort of) clipons: The NTV650 Revere NTV650 Revere NTV650 Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted April 12, 2013 Share Posted April 12, 2013 Pretty sure the Hawk had clip ons and not handlebars..? Not 100% Hawk 650 DID have clipons. NTV650 = Deauville Quote Link to comment Share on other sites More sharing options...
V4 Rosso Posted April 12, 2013 Share Posted April 12, 2013 NTV650 = Deauville The NTV650 Deauville is the succesor of the NTV650 and might have the same dimensions top yoke. The dash in the previous NTV650 pic obscures some of the yoke so it is hard to tell if they are different. The yoke of the Deauville you posted looks exactly the same as that of the top yoke a member of the Dutch VFROC put on his 3rd gen. The yoke was sold to him as being from an NTV650. NTV650 (Deauville) top yoke on a 3rd gen VFR fork: edit: Found a pic of a cleaned up NTV650 yoke and it has two extra tabs to hold the dash. So it seems Veefer800canuck is right and the correct yoke comes from a NTV650 Deauville. Bottom yoke in the picture is from a NTV650 Quote Link to comment Share on other sites More sharing options...
Guest navas Posted April 12, 2013 Share Posted April 12, 2013 So it's the hawk? Quote Link to comment Share on other sites More sharing options...
Member Contributer slo1 Posted April 13, 2013 Member Contributer Share Posted April 13, 2013 So it's the hawk? Nope, us Hawk GT had clip-ons. The ntv Deauville that the rest of the world got is the right one. Hawk on top. Quote Link to comment Share on other sites More sharing options...
superfunkomatic Posted April 13, 2013 Share Posted April 13, 2013 One member has already done this mod on his sixth gen. Lots of info in the thread. Tim's a great guy and if you sent a PM I'm sure he'd help you out. http://www.vfrdiscussion.com/forum/index.php/topic/41723-vfr-triple-clamp-project/?view=findpost&p=505672 1 Quote Link to comment Share on other sites More sharing options...
Guest Deeds Posted April 30, 2013 Share Posted April 30, 2013 (edited) What size and type bolts hold the top triple in place next to the ignition? I can't seem to get at them. Well, looks like they are Torx, and I managed to strip one of them. I also don't have the right size Torx bits. WHY, HONDA, WHY?? Guess I am at an impasse until I can find my way around them. Can't drill them out, either, because there won't be enough room to get a drill in there. Edited April 30, 2013 by Deeds Quote Link to comment Share on other sites More sharing options...
Dawgwhat Posted May 1, 2013 Share Posted May 1, 2013 What size and type bolts hold the top triple in place next to the ignition? I can't seem to get at them. Well, looks like they are Torx, and I managed to strip one of them. I also don't have the right size Torx bits. WHY, HONDA, WHY?? Guess I am at an impasse until I can find my way around them. Can't drill them out, either, because there won't be enough room to get a drill in there. what part of Virginia? Quote Link to comment Share on other sites More sharing options...
Guest Deeds Posted May 2, 2013 Share Posted May 2, 2013 What size and type bolts hold the top triple in place next to the ignition? I can't seem to get at them. Well, looks like they are Torx, and I managed to strip one of them. I also don't have the right size Torx bits. WHY, HONDA, WHY?? Guess I am at an impasse until I can find my way around them. Can't drill them out, either, because there won't be enough room to get a drill in there. what part of Virginia? I am in Virginia Beach. I managed to get the top triple off. I just disconnected the ignition and pulled the whole thing out. I drilled the holes slightly off, so the bar will end up being crooked by maybe 1 degree. Oh well, that won't bother me much since I will be getting a LSL kit in the coming months to replace everything. Quote Link to comment Share on other sites More sharing options...
Dawgwhat Posted May 3, 2013 Share Posted May 3, 2013 What size and type bolts hold the top triple in place next to the ignition? I can't seem to get at them. Well, looks like they are Torx, and I managed to strip one of them. I also don't have the right size Torx bits. WHY, HONDA, WHY?? Guess I am at an impasse until I can find my way around them. Can't drill them out, either, because there won't be enough room to get a drill in there. what part of Virginia? I am in Virginia Beach. I managed to get the top triple off. I just disconnected the ignition and pulled the whole thing out. I drilled the holes slightly off, so the bar will end up being crooked by maybe 1 degree. Oh well, that won't bother me much since I will be getting a LSL kit in the coming months to replace everything. I would like to see what you have done before I mess up... Quote Link to comment Share on other sites More sharing options...
Guest Deeds Posted May 5, 2013 Share Posted May 5, 2013 Just finished the installation and a test ride. It's great! Feels MUCH more comfortable, and I feel like I have more control over the bike with the higher seating and greater leverage over the front wheel. I used ST1300 cables I copped off ebay for cheap, and they had plenty of reach (with a little bit extra). I have yet to get some bar ends that fit (I don't want to pay the $40 price for the Renthal ends(there aren't any noticeable vibrations, anyway)), and the holes I drilled in the top triple are ever so slightly off (will be corrected with a Dremel), but this works well as a temporary fix. I will be getting the LSL kit in the future, anyway. I am riding out to West Virginia next weekend (5 or so hours or riding), so I am excited to see how well they work. Quote Link to comment Share on other sites More sharing options...
silverbullet132 Posted May 5, 2013 Share Posted May 5, 2013 Just finished the installation and a test ride. It's great! Feels MUCH more comfortable, and I feel like I have more control over the bike with the higher seating and greater leverage over the front wheel. I used ST1300 cables I copped off ebay for cheap, and they had plenty of reach (with a little bit extra). I have yet to get some bar ends that fit (I don't want to pay the $40 price for the Renthal ends(there aren't any noticeable vibrations, anyway)), and the holes I drilled in the top triple are ever so slightly off (will be corrected with a Dremel), but this works well as a temporary fix. I will be getting the LSL kit in the future, anyway. I am riding out to West Virginia next weekend (5 or so hours or riding), so I am excited to see how well they work. You can use any 14mm bar end :) Quote Link to comment Share on other sites More sharing options...
Baileyrock Posted June 11, 2013 Share Posted June 11, 2013 Bump for the mother of all bar mods! BR Quote Link to comment Share on other sites More sharing options...
Member Contributer Vecky5 Posted June 12, 2013 Member Contributer Share Posted June 12, 2013 I wish I had time to source parts and do this mod before I take my 2,500 mile trip from KY to CT & NH and back again. I might have to do this soon. Quote Link to comment Share on other sites More sharing options...
Member Contributer Vecky5 Posted June 13, 2013 Member Contributer Share Posted June 13, 2013 I've noticed that people recommended two different options for longer throttle cables (ST1100 and ST1300). Would either of those work? Do i definitely need them if I go with a 22 mm riser and Renthal 756 bars on a 6th gen? Quote Link to comment Share on other sites More sharing options...
Member Contributer Vecky5 Posted June 23, 2013 Member Contributer Share Posted June 23, 2013 Come to find out, ST1100 throttle cables are roughly the same size as our 6th gen cables.So they won't fit with my superbar set up(I found this out after doing a ton of work setting up a superbar system only to have to set it all back to stock). Does anyone know the length of ST1300 cables or if they are 4-5" longer than stock VFR cables? Quote Link to comment Share on other sites More sharing options...
Baileyrock Posted June 23, 2013 Share Posted June 23, 2013 I have a set of later ST1300 cables and I'm guessing they might be 2" longer then stock VFR's. Not much gain IMO. Quote Link to comment Share on other sites More sharing options...
Tman Posted July 7, 2013 Share Posted July 7, 2013 Makes it look like wheelbarrow in my opinion. Each to his own.I would certainly use a color less conspicuous than gold.Other than that, I don't think tall handlebars are too out of place on a VFR. The police VFR750P/800P look just fine... except for the mirrors maybe. I was seriously considering the handlebar mod myself, but I think I'm starting to get used to the stock clip-ons. You guys bring up another benefit: you can run whatever color and bar bend you want or even go old skool chrome. Here's another pic of a black bar I've used: I prefer the gold bar on my vfr as it picks up the gold engine cover and 6 piston calipers quite nicely IMNSHO. :salesman: What are the make of the satin silver bar clamps? WHere did you buy them? Tman Quote Link to comment Share on other sites More sharing options...
