VFR Discussion: Upgrade To Hazards And Flash-to-pass Switch On An '02 - VFR Discussion
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Upgrade To Hazards And Flash-to-pass Switch On An '02 is it plug and play?
#1 User is offline   tx_vfr Icon
  • Vroom!
  • PipPipPip
  • View gallery
  • Group: Members
  • In My Garage::2002 VFR800 Blue
    1982 XR200R (broke)
    1971 Mustang 302 5spd
    1988 4Runner 22RE 5spd
Thank You's: 0
Neutral
Posted 08 September 2008 - 11:34 AM
My hi/lo beam switch is breaked (just the button/lever) and since I can't buy just that part, I was wondering if I could purchase a newer turnsignal switch that would give me the flash-to-pass and hazard switches.
The part numbers are obviously different between an '02 and '06 turn signal, but I don't know if the plugins are the same on the end.
As I understand the wiring, it shouldn't be any wiring different other then inside the switch. Could be wrong here, but thats what I'm seeing looking at the diagrams.
Thanks for the input
Nathan
I thought I was wrong once, but I was wrong.
You're gonna have to give me a really good reason to grow up, cause i haven't found any yet.
Two Wheeled Texans <-- I hang out over here as 1TallTXn
0
#2 User is offline   marid2apterbilt Icon
  • KneeDragging Novice
  • Icon
  • View gallery
  • Group: Volunteer
  • Location:western north carolina. not far from deal's gap
  • In My Garage::BLACK 06 vfr800 (Lysandra)
  • Signed Flaf:
Thank You's: 3
Neutral
Posted 08 September 2008 - 11:40 AM
06 dont have flash to pass.. And the turn signals are wired with 2 wires at the bulb not 3 so further investigation into the wiring is needed.. Sorry I cant be of more help..
Posted Image Posted Image
I have gone to look for myself,
If i should return before i get back keep me here,
Otherwise leave your name n number and as soon as i find myself i will return your call.
Thank you.
So many fun roads, Only 1 lifetime to try n ride them all.
0
#3 User is offline   BaileyRock Icon
  • Nail'ed It!
  • Icon
  • View gallery
  • Group: Forum Moderator
  • In My Garage::02 Vtec
    04 vtec track pig
    07 SYM Fiddle 50
    about 3 bikes worth of pieces!
  • Signed Flaf:
Thank You's: 12
Good
Posted 08 September 2008 - 12:17 PM
No Flash to Pass on any VFR is there? :unsure:
Different Main harness for the Hazards part.
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
"If everything seems under control, your just not going fast enough" Mario Andretti
current bikes
02 VFR BLACK, 71,250 miles(no Valve check yet), SB-II exhaust , 15t, Ohlins w/19kg, AfterShocks forks w/.95 kg, V1, heated grips, Pilot Power front/ Road 2 rear, No surge or Vtec transition problems! Mobil 1 15w-50 or Shell Rotella T Syn., Buell pegs.
01 VFR (brother's) crashed
07 GSXR 750(SOLD!)
02 F4i Track Bike(GONE!)
93 Yamaha WR250(in a box)
04 VFR track pig project(fast & crashed)
09 Everest & Jennings 18" chrome on black wheelchair!
0
#4 User is offline   TimC Icon
  • Solo Cornet
  • Icon
  • View gallery
  • Group: Forum Contributor
  • In My Garage::'04 VFR800
  • Signed Flaf:
Thank You's: 2
Neutral
Posted 08 September 2008 - 01:00 PM
No hazards on VFRs 'til '04, and that switch is on the right side below the run/stop switch, and I don't think any stock VFR has ever had flash-to-pass, tho I wish they did.
You might be able to use a Suzuki or other stock handlebar switchgear with high/low beams switch, turn signals horn and flash-to-pass, but I'm not sure if any switchgears have the hazards switch on the left side. Plus I believe you'd still have to wire the hazards in on your bike.
AMA Member 973972
Posted Image
0
#5 User is offline   soichiro Icon
  • VTEC POLICE!
  • Icon
  • View gallery
  • Group: Volunteer
  • In My Garage::04 vfr,
    81 silverwing,
    05 crf100f,
    1996 rm125
  • Signed Flaf:
Thank You's: 3
Neutral
Posted 08 September 2008 - 01:18 PM
I think the european models have flash to pass, on the 6th gen.
RUBBER IS CHEAPER THAN PLASTER
RC46 #888
"BRAVERY IS THE CAPACITY TO PERFORM PROPERLY, EVEN WHEN SCARED HALF TO DEATH"
GEN. OMAR BRADLEY
Posted ImagePosted ImagePosted ImagePosted ImagePosted Image
0
#6 User is offline   tx_vfr Icon
  • Vroom!
  • PipPipPip
  • View gallery
  • Group: Members
    1982 XR200R (broke)
Thank You's: 0
Neutral
Posted 08 September 2008 - 01:33 PM
Now that I think about it, the wiring diagram that I was looking at was for the '03+ Euro VFR.
Wonder why they didn't put the flash-to-pass on the US models.
I was more after the Hazards then the flash to pass anyway.
Thanks for the info y'all
Nathan
0
#7 User is offline   JZH Icon
  • International Bodger
  • Icon
  • View gallery
  • In My Garage::2 CBRs, 5 VFRs, an RVF, an ST and an RS
Thank You's: 3
Neutral
Posted 08 September 2008 - 01:38 PM
Plug-n-play is folly; haven't seen a Honda switch pod I couldn't re-wire, though...
(ROW models have always had Passing switches, AFAIK, though that could have changed recently with the switch (har, har) to always-on headlights on Hondas worldwide since ca. 2004.)
Ciao,
JZH
So.Cal., USA/London, UK
http://www.vsource.org
RS250; CBR400RRN; RVF400RT; VFR400RL; VFR444RN; VFR750FL; VFR800FiY; VFR837FP; CBR1000FP; ST1300A4 (and counting...)
0
#8 User is offline   BaileyRock Icon
  • Nail'ed It!
  • Icon
  • View gallery
    04 vtec track pig
    07 SYM Fiddle 50
  • Signed Flaf:
Thank You's: 12
Good
Europeans are more educated, civil and m/c friendly and they all know what the Flash to Pass is and move over for you.
Here in the US it will get you shoot by an ignorant dumb azz ! :unsure:
:rolleyes:
current bikes
07 GSXR 750(SOLD!)
0
#9 User is offline   thereisnospoon Icon
  • Goof-off extaordinaire
  • Icon
  • View gallery
  • In My Garage::Yellow VFR
Thank You's: 0
Neutral
Posted 08 September 2008 - 01:48 PM
On mine (5th gen) there is what looks to be a "knock out" at about the spot where a flash-to-pass trigger could be put... so I imagine the Euro models have a properly functioning left switch pod. hazards would be handy every so often.
Anyone with a Euro bike handy that can see if they have flash to pass/hazards? :D
The beatings will continue until morale improves.
0
#10 User is offline   tx_vfr Icon
  • Vroom!
  • PipPipPip
  • View gallery
  • Group: Members
    1982 XR200R (broke)
Thank You's: 0
Neutral
Posted 08 September 2008 - 02:55 PM
:rolleyes:
Tis true. Course Zuki has flash to pass on most of their bikes.
wouldn't use that all that often anyway
Nathan
0
#11 User is offline   Rivcyko Icon
  • See,..I'm not a monster. I'm just ahead of the curve.
  • Icon
  • View gallery
  • In My Garage::2002 Honda VFR vtech,
    2002 Ford Ranger,
    A Grill, Yard tools,
    Fiberglass dust, Spiders,...
  • Signed Flaf:
Thank You's: 0
Neutral
Posted 08 September 2008 - 03:29 PM
Yes. Hosed. D-oh!
Travis, aka,...Riv, "The Travi", MR. A$$-HAT.
"Mr. Travis is a handsome man,....Like Robin Hood"--L.E. HA!
"A guy goes down,.. rashes up his plastic. "Oh, the fairings are down to the wear bars." --Jon--
"The grass is always greener,..." To that, I say, " My yard is plenty green, but it's mostly weeds." --Me--
"Sandpaper is your best friend, like it or not. (Unless you have friends who will sand for beer). " --SEBSPEED--
"NO ONE MESSES WITH ADAM WE.."
Posted Image
My Mods: Bug Buster, Heli bars (gel filled), Progrip 714's, Custom barends, Blue gages, Reduced and painted windscreen, Signal Dynamics LED voltmeter, Sargent seat w/griptex, Matching cutom 1/2 tank bra, P.C.III USB, Speedo Healer, Custom dynamics adj. turn signal modulator, All LED turn signals, All LED brake lights With additional light bars under tail, and licence plate, Stop Alert brake light modulator, Custom fairing graphics, Silver painted side covers, Silver powder coated rims, Rear lock lug nuts, Custom fender eliminator w/mud flap, Rivcyko hugger, AFAM 15 tooth front/43 tooth rear w/DID x ring chain, Givi top box rack w/ EXL tailbag on it, Gutted, shortened, large ported, de-blinged stock exhaust, Modded Lobster's mirror extenders, (part 2), Cut down front fender, Not to mention, Diablo Corsa III, new thermostat, C.C.T. 's
HOME PAGE-HAS ALL B.B. & HUGGER INSTALLATION INSTRUCTION LINKS- http://home.comcast....cyko/page1.html
0
#12 User is offline   V4 Rosso Icon
  • Race Team Owner
  • Icon
  • View gallery
  • Group: Volunteer
  • In My Garage::1993 750
    Trek Fuel EX6
    Giant Cadex CRF2
  • Signed Flaf:
Thank You's: 8
Neutral
Posted 08 September 2008 - 05:00 PM
Hazard switch situated just above the starter button.
Posted Image
I don't know about the 5th, but the 3rd and 4th gen do not have a hazard switch but a three position light switch (off/city light/main).
The pass triggerswitch is on the left clipon opposite to the turn signal switch. 3rd to 6th gens have a pass switch, not sure about older models.
Posted Image
Here is a pic with a better view on the switch. This is the switch of my 3rd gen.
Posted Image
It works better than advertised :biggrin:
Posted Image
0
#13 User is offline   BaileyRock Icon
  • Nail'ed It!
  • Icon
  • View gallery
    04 vtec track pig
    07 SYM Fiddle 50
  • Signed Flaf:
Thank You's: 12
Good
Posted 08 September 2008 - 05:03 PM
Nice Rosso! :fing02:
current bikes
07 GSXR 750(SOLD!)
0
#14 User is offline   Darth Bling Icon
  • "The Farkle King"
  • Icon
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::
    • 2002 VFR800
    • 1983 GS1100E
    • 2007 CBR600RR
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 10 September 2008 - 01:07 PM
You mean like this?
Posted Image
And no, it's not plug and play. :warranty:
Current VFR Farkles: 767fixer's Quad Hi-Beam Mod; Rubbermaid Trash Can Fender; 2005 GSXR1000 Left Gearswitch; Power Commander III; Sargent Seat; BLS Lowering Peg Blocks; GSXR Mirrors with Intergrated Turn Signals; RC51 Front-End Swap; Jet-Hot Coated 98/99 Cat-less Headers; Leo Vince TI Exhaust; Radar's Frame Sliders; Elka Rear Shock; Magura Radial Master Cylinders (Clutch & Brake); J&M Integratr IV with CB Radio; ProTaper ATV Handlebars; Zumo 450 GPS; Rostra Electric Cruise Control; ZG Touring Screen
CBR600RR Mods: Nemessis45 Ram Air Race Intake; Yamaha Monoblock Calipers; CBR929 Front Rotors; GCraft Rear Brake Reservor; CRG Clutch Perch; Leo Vince Full EVOII Exhaust; R&G Sliders; Vortex Rearsets; Ohlins Rear Shock; Brembo Front Brake Master Cylinder
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
0
#15 User is offline   JES_VFR Icon
  • Moto Grand Prix Racer
  • PipPipPipPipPip
  • View gallery
  • Group: Members
  • In My Garage::01 VFR
    SW-Motech racks, e360s, Krauser top rack
    Avon Storms, Hyperpro 3way adj w/ rem preload
Thank You's: 0
Neutral
Posted 12 September 2008 - 03:33 PM
I have a Euro switch for the 5th gen's that I never got a chance to install, yet...
It will be going on the bar when the rebuild starts (sometime next week I hope).
JohnS
Forging my body in the fires of my will
0
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
