Update: As Seb said, “Dig in man! If it was easy everyone would do it!”
My original thought was to do the standard F2 front/rear wheel upgrade. I ordered Jamie’s front F2 wheel kit and after fitting that ordered the rear which is a machined carrier and three new wheel spacers. While waiting I found a 900rr rear wheel (5.5”, 180 tire) and thought I’d give it a try. Tom, mutant bike, fitted a VFR sss with a 180 so I knew it was possible for the 5.5” wheel/180 tire to fit and still line things up. I wanted to use the original swingarm though, the sss is too much fab for me.
Quick check seemed to show the wheel should fit.
The wheel/tire does fit the R swingarm and has clearance all the way up to the minimum chain length.
The F2/F3/900rr share the same sprocket carrier, so after getting Jamie’s machined carrier back I put it in the 900rr wheel and lined things up. It was apparent I would need an offset countershaft sprocket. The R bike shares sprockets with the 5/6 gen VFR, Blackbird, CB900, CB750 dohc plus some others. Kruger offers these in several different offsets,
http://stores.ebay.d...ger-cycle-parts. I went with the 9mm offset, the largest measured that would squeeze in the frame.
Lining up the wheel wasn’t too difficult, Jamie’s kit includes a 12mm spacer which was just what I needed on the right.
A 2mm spacer on the left,
And everything looks lined up
The chain and wheel are within a mm of being lined up and centered. I think I’ll live with the difference at this point.
Next hurdle is machining some space under the sprocket cover where the clutch slave mounts in. This will probably mean spacing the clutch slave out about 5mm or so, necessitating a longer release rod to be machined up.
Shock extension machined up, still some final steps to finish it off. Using a 5G dogbone, 4G triangles, raising the rear of the bike about 1”.
Still waiting on the rest of the RC front end to come in next week.
Digging in! Triples are at the machinist's getting steering stems pulled, welded, turned and pressed back in for the RC front end swap.
