VFR Discussion: Beware 90 degree valve stems - VFR Discussion
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Beware 90 degree valve stems Valve stem failures
#1 User is offline   maddog Icon
  • World Superbike Racer
  • Icon
  • Group: Forum Contributor
  • In My Garage::2000 VFR
Thank You's: 0
Neutral
Posted 02 March 2006 - 12:41 PM
I've had the misfortune to suffer two valve stem failures, both on front tires, in the past few months. The most recent was last night, coming home from work.
The first one occured on a Sunday morning, on a lightly traveled two lane road in very rural(no cell coverage) Missouri. Fortunately, I wasn't really hauling, due to loose gravel. But it is very difficult to maintain control on a narrow, ditch-lined road(no shoulders) with a very suddenly flat front tire.
The episode last night occurred on an Illinois interstate highway as I was preparing to exit. The tire gave some indication something was wrong, and within maybe three or four seconds, the tire was completely flat, with steering being very difficult. I made it to the exit ramp and parked immediately.
The culprit in both cases was a 90 degree rubber valve stem. In the first case it had lasted for many thousands of miles. I really don't recall when it had been installed. The most recent failure was on a valve stem with fewer than 1000 miles. In both cases the tires(Metzlers) were in excellent condition.
I blame myself for not learning from the first episode. There is no way my bike will ever have another rubber 90 degree valve stem. I may, however, put on some Ariete 90 degree aluminum valve stems.
I don't know what it is about Illinois and Missouri, but I have now had a rear tire blow out on I-70 (north St. Louis) plus the two valve stem failures (one in each state). Prior to these cases, I have gone decades and a huge amount of miles without any tire-related problems.
On another note, all three of these cases resulted in me having to contact Honda Riders Club (HRCA) for their towing services. I have found them to be very slow to answer the call (30+ minutes on hold is not uncommon, like last night). Then some doofus comes out with tow truck without proper M/C tie-downs, no idea how to deal with a bike with fairings ("I thought it was a full dress Hardley"). He left, with me again stranded. Cops showed up, gave ma a ride home, and I arranged with a local provider for service (Beyer Auto Body & Towing in Glen Carbon, Il.).
Prompt, knowledgeable service. Finally!
Sorry for the long-winded blab, but hopefully someone else will benefit from my tales of woe.
Thankfully, I'll be heading back to Idaho in about a month. Can't wait. :)
0
#2 User is offline   BaileyRock Icon
  • Nail'ed It!
  • Icon
  • View gallery
  • Group: Forum Moderator
  • In My Garage::02 Vtec
    04 vtec track pig
    07 SYM Fiddle 50
    about 3 bikes worth of pieces!
  • Signed Flaf:
Thank You's: 12
Good
Posted 02 March 2006 - 12:56 PM
Man that's a very bad feeling when the front goes down that quick. I was on I-40 doing around 70 mph when I felt something strange with the front and a second or 3 later I had almost No ability to turn the bike and I was in a turn. :blink: managed to get it stopped against the center wall, wipe my butt and almost idled across 3 lanes of highway traffic. Not fun and couldn't imagine having that happen while rippen a set of twisties!!! :unsure:
It was a failed rubber valve stem (straight).
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
"If everything seems under control, your just not going fast enough" Mario Andretti
current bikes
02 VFR BLACK, 71,250 miles(no Valve check yet), SB-II exhaust , 15t, Ohlins w/19kg, AfterShocks forks w/.95 kg, V1, heated grips, Pilot Power front/ Road 2 rear, No surge or Vtec transition problems! Mobil 1 15w-50 or Shell Rotella T Syn., Buell pegs.
01 VFR (brother's) crashed
07 GSXR 750(SOLD!)
02 F4i Track Bike(GONE!)
93 Yamaha WR250(in a box)
04 VFR track pig project(fast & crashed)
09 Everest & Jennings 18" chrome on black wheelchair!
0
#3 User is offline   7K Rush Icon
  • Icon
  • View gallery
  • In My Garage::2003 VFR, 1972 CB350F, '73 Porsche 914 2.0, lot of crap I don't need
Thank You's: 0
Neutral
Posted 02 March 2006 - 01:12 PM
Is there a safer valve stem to use than the usual rubber ones?
Bryan Greenly
Italian Red '03
CW fender eliminator, Geelong CF tank protector, Puig dark smoke DB
0
#4 User is offline   SAFE-T Icon
  • FrankenFrugalizer
  • Icon
  • View gallery
  • In My Garage::Murphy
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 02 March 2006 - 01:17 PM
Metal ones ? :rolleyes:
0
#5 User is offline   Veefer800Canuck Icon
  • Gear is good!
  • Icon
  • View gallery
  • In My Garage::1999 Honda GL800RR-SP2
    Currently a pile of smoldering rubble, thanks to an errant cager. :(
  • Signed Flaf:
Thank You's: 8
Neutral
Posted 02 March 2006 - 01:28 PM
http://www.motowheel...&categoryID=405
Posted Image border='0' alt='user posted image' />
Posted Image
Rob McKinnon
'99 GL800RR-SP2
http://s13.photobuck...eefer800canuck/
Quote
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. Because Honda cannot test all other accessories, you must be personally responsible for proper selection, installation, and use of non-Honda accessories.
Quote
We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle's handling, stability, and braking, making it unsafe to ride
0
#6 User is offline   chris2992 Icon
  • Boogity, Boogity, Boogity
  • Icon
  • In My Garage::99 Red
Thank You's: 0
Neutral
Posted 02 March 2006 - 10:07 PM
Thats where I'm from. Edwardsville and Glen Carbon are basically one and the same. Where did you break down at.
"We strongly advise you not to remove any original equipment or modify your motorcycle in any way" quoted Honda.
Current mods include: Staintune LM, Jet-Hot Coated Headers, Power Comander II P.O.S., DIY Modified FPR, K&N Air Filter, Flapper valve gone, Pair Valve Gone, De-snorkeled, Puig Screen, Kriss Amp-U-Tron Volt/Amp Meter, Auxilary Fuse Block (Blue Sea 6 Circut), Heated Grips, Corbin Seat and Home Made Backrest, Home made "powerlet" kit, Blue Gauges, Tapeworks Red Reflective Rim Stripes, Modified Headlights for Super Bright, Steering Stem Garage Door Opener, '04 R1 RR, Kuryakyn LED License Plate Lights, Garmin nuvi 350 GPS and RAM Mount, Harbor Freight Lift, Home Made Front Wheel Chock.
0
#7 User is offline   vfrurknee Icon
  • Moto Grand Prix Racer
  • Icon
  • View blog
  • View gallery
  • In My Garage::2 Y2K VFRs,
    '86 VFR750, '86 VFR700
    '03 RC51, '02 954
    Yamaha 660 Grizzly in Realtree Camo
Thank You's: 0
Neutral
Posted 02 March 2006 - 10:47 PM
I have never had a valve stem fail but on two occasions have hit objects in the road that bent the front rim and caused the tires to go flat. The first time I was only about five miles from home and rode it in flat. Straight line was no problem. Turning was a different story.
This past New Years Eve I collected a piece of firewood. Never saw it before it launched my front end about two feet skyward. This time I was 70 miles from home. I got off to check the tire and rim. Rim was bent but pressure seemed OK. Turned for home and felt the lack of response on the first curve. Backed off to about 55-60 and took her home. I guarantee you this will give you a tension headache!
I was going to attach an image from my gallery but can't seem to get the hang of it. There are a couple of pics there if you are interested.
vfrurknee
0
#8 User is offline   vfrurknee Icon
  • Icon
  • View blog
  • View gallery
    '03 RC51, '02 954
Thank You's: 0
Neutral
Posted 02 March 2006 - 10:51 PM
BTW, I recovered the piece of firewood and burned it in my fireplace!
vfrurknee
0
#9 User is offline   maddog Icon
  • Icon
Thank You's: 0
Neutral
Posted 03 March 2006 - 08:05 AM
Tire started going down while on I 270 eastbound, about 1/2 mile west of 159 exit. I did make it to the exit ramp, where I parked it.
I'll remove the wheel tonight after work and hopefully get repairs done tomorrow morning.
0
#10 User is offline   steve_mn Icon
  • Factory Team Rider
  • PipPipPip
  • Group: Members
  • In My Garage::82 GS550l Suzuki wifes
    95 VFR
Thank You's: 0
Neutral
Posted 03 March 2006 - 08:50 AM
I've read on other forums that 90 degree valve stems are prone to failure. I have steel straight ones on my bikes, swapped out the plastic/rubber ones.
A 90 degree steel one would be nice for checking pressure though.
0
#11 User is offline   chris2992 Icon
  • Icon
Thank You's: 0
Neutral
Posted 03 March 2006 - 09:03 AM
That is just a few blocks from my place, should have called. :goofy:
0
#12 User is offline   maddog Icon
  • Icon
Thank You's: 0
Neutral
Posted 03 March 2006 - 09:50 AM
I would have, except for two things. I wasn't carrying my cell phone and I don't have your number. :P
0
#13 User is offline   Veefer800Canuck Icon
  • Gear is good!
  • Icon
  • View gallery
  • Signed Flaf:
Thank You's: 8
Neutral
Posted 03 March 2006 - 02:01 PM
http://www.vfr911.com
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#14 User is offline   JoeAsheville Icon
  • The Ultimate RC46.
  • Icon
  • In My Garage::Air.
Thank You's: 0
Neutral
Posted 13 July 2006 - 09:37 PM
View Postveefer800canuck, on Mar 3 2006, 07:01 PM, said:
Way cool. We had something like that on the Ferrari biglist back in the early nineties.
I'm in.
"I do not call upon the state to compel everyone to accept my opinion, but, rather; not to force me to accept anybody else's opinion"
-F. Bastiat
0
#15 User is offline   teleskier Icon
  • No Worries !! Yeah Right !!
  • PipPipPipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::00 VFR Yellow, 03 VFR, 08 Concours 1400 CJ7 rocker, Duramax CC P/U
  • Signed Flaf:
Thank You's: 0
Neutral
Posted 13 July 2006 - 10:55 PM
only problem is there is only two of listed for all of northern california. Me and Alleycatdad
By the way, my 90deg. stems work very well.
Teleskier -
00 VFR, Ohlins rear,Aftershocks front, sargent seat, R&G sliders, Micron high mount, Scorpion low mount, Jet-Hot coating, Catless exhaust, Hugger, Throttlemeister, Scotts Dampner,polished wheels,8 spoke rear, blue LED dash, EBC pads, Pilot powers, Turbo City FPR, 16T front w/DID chain and fenderectomy,Pazzo Levers, magknight tank protector, PIAA bulbs, adjustable pegs, De-Dumbo'ed, speedohealer, factory pro shift kit, powerlet, LED volt meter...Damn, I think I have spent more on goodies than I did for the bike!!
"Faster and Faster until the thrill of speed overcomes the fear of death"
0
#16 User is offline   Darth Bling Icon
  • "The Farkle King"
  • Icon
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::
    • 2002 VFR800
    • 1983 GS1100E
    • 2007 CBR600RR
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 14 July 2006 - 12:52 AM
I'm in.
Awesome, I just signed up.
Current VFR Farkles: 767fixer's Quad Hi-Beam Mod; Rubbermaid Trash Can Fender; 2005 GSXR1000 Left Gearswitch; Power Commander III; Sargent Seat; BLS Lowering Peg Blocks; GSXR Mirrors with Intergrated Turn Signals; RC51 Front-End Swap; Jet-Hot Coated 98/99 Cat-less Headers; Leo Vince TI Exhaust; Radar's Frame Sliders; Elka Rear Shock; Magura Radial Master Cylinders (Clutch & Brake); J&M Integratr IV with CB Radio; ProTaper ATV Handlebars; Zumo 450 GPS; Rostra Electric Cruise Control; ZG Touring Screen
CBR600RR Mods: Nemessis45 Ram Air Race Intake; Yamaha Monoblock Calipers; CBR929 Front Rotors; GCraft Rear Brake Reservor; CRG Clutch Perch; Leo Vince Full EVOII Exhaust; R&G Sliders; Vortex Rearsets; Ohlins Rear Shock; Brembo Front Brake Master Cylinder
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
0
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
