Gday All.
Hope someone maybe able to assist on this one.
I have a Red 2005 VFR800 that has run flawlessly since I've had it until yesterday.
On returning from a ride, I indicated to turn a corner and the engine stopped. I restarted and indicated again and the engine stopped again.
I rode a little further and the same thing happened again. I pulled over and the same happened a couple more times till all of a sudden the indicators (all four and the green indicating light) stopped working altogether. I assumed a short somewhere and a blown fuse. I got the bike home and did nothing further.
This morning things have changed. When I now turn the ignition on, I get an ongoing buzzing (apart from the initial fuel injection noise). The indicators sort of work now. The rears work fine but both fronts come on dimly together as well as all dash lighting flashing in time with the indicators. The hazards do the same. This all is regardless of whether the engine is running or not.
What a mess...
Any idea's from anyone at all???
Thanks for reading...
Indicator Ignition Electrical Issue.
Started by yannih, Jul 25 2012 06:36 PM
3 replies to this topic
#1
Posted 25 July 2012 - 06:36 PM
#2
Posted 27 July 2012 - 01:18 AM
check your battery...is it fully charged. Could be an earthing problem also. Also you could spray some WD40 in the handle switches.
#3
Posted 27 July 2012 - 01:54 AM
Anything like this video?
Check the blue connector on the left side of the bike. You'll want to pull it apart to make sure it's not melted. Sometimes it's hard to tell until it's apart. Also check the wiring near the starter relay where fuse B is located for overheating/melting.
CLICK HERE for all the details and how to sort it out. The recall that replaces the front harness helps but doesn't completely cure the issues. Check out the VFRarness from Wiremybike to help keep it from happening again.
VFRD Ride Icons:
Famous Quotes:
"Ride lots!" -- E. Merckx
"Dinosaurs were not created to lubricate motorcycles. They were created to eat each other. Mobil 1 is manufactured to lubricate motorcycles." -- Bent
"I usually just chop the throttle hard during a 2nd gear wheelie which results in my nuts being smashed against the tank and at that point I no longer care if they are hot and sweaty." -- Baileyrock
"As to my "former" screen name... Know why I picked it don't you? Cause Bitch was already taken!!" -- Nicole
"Of course, all of them caused the motor to seize, then I crashed and died, the bike burst into flames after sliding along the road and crashing into immoveable objects, then exploded, and I died all over again. It's really starting to piss me off, all this crashing, exploding, dying nonsense!" -- Enzed Viffer
Famous Quotes:
#4
Posted 27 July 2012 - 03:34 AM
Thanks guys. Really appreciate the responses.
But now I have some news for you all. Not sure if you are all aware.
The VFR800's have a recall for replacement of the front wiring loom... For the life of the bike... Apparently they were melting and causing issues like mine. Luckily I found out from a knowledgeable and helpful mechanic. I'll get him a case of beer.
Called Honda Australia and they confirmed it after checking my VIN number! Happy days. My bike is now in being repaired under the recall. For free!
I would assume this would apply around the world but can't be sure.
Hope this helps...
Hope this helps...
Rules
