7th gen front wheel on 6th gen?
#1
Posted 26 June 2012 - 04:56 PM
#2
Posted 26 June 2012 - 05:48 PM
#3
Posted 26 June 2012 - 06:34 PM
#4
Posted 26 June 2012 - 08:32 PM
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle’s handling, stability and braking, making it unsafe to ride.
#5
Posted 27 June 2012 - 12:19 AM
#6
Posted 02 July 2012 - 02:27 PM
#7
Posted 02 July 2012 - 02:28 PM
the axel is the killer...I wonder if the brake disk mounting holes are the sameNot even close. The axle is different and the brake discs aren't the same size.
#8
Posted 11 July 2012 - 06:21 PM
NO - the 7th gen has 5 lugs the 6th has 4, the wheel is wider with a different offset too, the brake wont make much difference its out of the way but you would definitely have to fab up a new spindle with 5 lugs - an interesting alternative would be the cb1000 wheel though!
Anyone know if that CBR rear wheel works on the RC46?
#9
Posted 11 July 2012 - 08:12 PM
Yes it does, see this thread:
http://www.hondacb10....html#post66392
Rules
