Dead electrics
This topic has been archived. This means that you cannot reply to this topic.
1 reply to this topic
#1 snowy
snowy
    Local Racer
  • Members
  • Pip
  • 10 posts
Posted 26 June 2012 - 12:55 AM
Would be grateful if one you wise people out there can suggest what my problem might be.
Had been riding for about an hour, stopped for 10 minutes jumped back on, started engine, side stand up, into 1st no problem, just went to pull away and engine died.
Complete electrical failure, no panel lights, nothing except clock.
Have checked fuses all ok, checked earth on blue connector, have good continuity across the connector with no resistance.
I have fully charged battery and have 12v at ign switch. i am thinking that the problem may lie with either the engine stop relay or kill switch, i haven't had time to check these yet. I thought i would chuck it past you guys as 2 heads are better than 1.
Under the front cowl there are 4 relays ( engine stop, fuel cut off and 2 h'light) could someone tell me if these relays are the same so that if i find it is the engine stop relay at fault i could perhaps use one the h'lght relays for the time being.
Thanking you guys in anticipation.
Snowy.
#2 dutchinterceptor
dutchinterceptor
    Black on Black on Black on Black
  • Forum Contributor
  • 4015 posts
Posted 26 June 2012 - 01:17 AM
Check your starter relay and fuse B wiring next to the battery. Also need to check the white connector with yellow wires on the right side of the bike. Has the recall been done yet?
VFRD Ride Icons:
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
Famous Quotes:
"Ride lots!" -- E. Merckx
"Dinosaurs were not created to lubricate motorcycles. They were created to eat each other. Mobil 1 is manufactured to lubricate motorcycles." -- Bent
"I usually just chop the throttle hard during a 2nd gear wheelie which results in my nuts being smashed against the tank and at that point I no longer care if they are hot and sweaty." -- Baileyrock
"As to my "former" screen name... Know why I picked it don't you? Cause Bitch was already taken!!" -- Nicole
"Of course, all of them caused the motor to seize, then I crashed and died, the bike burst into flames after sliding along the road and crashing into immoveable objects, then exploded, and I died all over again. It's really starting to piss me off, all this crashing, exploding, dying nonsense!" -- Enzed Viffer
swallowtailed
swallowtailed
swallowtailed
swallowtailed
