How long can gas sit and still be good?
#1
Posted 21 June 2012 - 10:51 PM
AGATT
Take Care
#2
Posted 21 June 2012 - 11:31 PM
Can I convince you to paint it flat black?
Just when we thought the Early VFR section was safe...
#3
Posted 21 June 2012 - 11:43 PM
#4
Posted 21 June 2012 - 11:46 PM
I've let the mower sit with gas in it over the winter once or twice. It didn't want to start at first, but I added some fresh gas to the old and it fired right up.I have never had gas in my tank over a month but I've had gas sit in a lawn mower and a snow blower for about six months each on multiple occassions and they both fired right up and ran fine. (two cycle snow blower with oil mixed in, unleaded gas in the mower)
#5
Posted 22 June 2012 - 02:29 AM
Mayby Dutch gas differs from US recipes???
You can always try some banaple gas..............
#6
Posted 22 June 2012 - 04:02 AM
However, the greater worry is that the injectors are gummed up.
7 months may not do it, but there's only one way to tell.
Might not be a bad idea to dump a small bottle of fuel injector cleaner in the tank, then fire her up and take a good long ride. Put some fresh fuel in it as soon as possible.
I know it's too late for you now, but I always put Sta-Bil in everything that sits for the off season, bike, snowblower, lawnmower, etc.
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle’s handling, stability and braking, making it unsafe to ride.
#7
Posted 22 June 2012 - 04:26 AM
todays gas can go bad in as little as a month.
+1..............it may run fine but old gas will cause damage. If one of my bikes is going to sit for more than 2 - 3 weeks, I put Stabil in it.
#8
Posted 22 June 2012 - 06:13 AM
While deployed I used to unhook my battery and fill tank with stabil and I would have no issues a year later when I came back.
#9
Posted 22 June 2012 - 06:25 AM
#10
Posted 22 June 2012 - 10:51 PM
Rules
