Hot frame, is that normal?
  • Please log in to reply
4 replies to this topic
#1 Ashok
Ashok
    Club Racer
  • Members
  • PipPip
  • 36 posts
  • Why VFRD?:nice website, useful resources
  • In My Garage::1998 VFR800.
Posted 16 June 2012 - 10:17 PM
I just bought a 5th gen and after I rode it home 20 miles, I noticed that the frame (the flat shiny silver colored bit) got a bit hot. I'm guessing this is because the radiators are mounted sideways but I'm curious if it is actually normal.
#2 CornerCarver
CornerCarver
    Then the forks fell off...
  • Forum Contributor
  • 2560 posts
  • Why VFRD?:You meet the nicest people on a Honda board....or onboard a Honda.
  • In My Garage::91,98 & 01 VFR 800 FI, 2003 Honda Odyssey, VF-500Fs for the boys! 1999 Dinan Stage III M3
Posted 16 June 2012 - 11:09 PM
how hot is "a bit hot"?
Can you hold your hand on it or is it too hot for that?
They will get warmer than you might think at first blush but you nailed it with the rads mounted on the side up front.
In North Georgia it is a great place to warm your hands on cooler mornings in the spring/fall before you install heated grips. :smile:
#3 Earthshake
Earthshake
    Motorcycle Racing Legend
  • Volunteer
  • 1010 posts
  • Why VFRD?:I like hangin' out with scoundrels and lackeys.
  • In My Garage::2010 Multistrada 1200s
    2006 Crownline (when it's too hot to ride)
Posted 16 June 2012 - 11:10 PM
Not to worry, it's typical.
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
#4 Ashok
Ashok
    Club Racer
  • Members
  • PipPip
  • 36 posts
Posted 16 June 2012 - 11:15 PM
Thanks for the responses.
I could hold my hand against it for a few seconds without much discomfort but I can definitely feel the heat. Almost as hot as the silencer.
#5 Veefer800Canuck
Veefer800Canuck
    FrankenOwner
  • Forum Moderator
  • 11509 posts
  • Why VFRD?:I have the V-4 disease and there is no known cure except for copious applications of Throttle!
  • In My Garage::2010 Honda GL800RR-SP2
    Back in business baby!
Posted 17 June 2012 - 03:01 AM
The frame runs right past the Two rear cylinders and heads. It's gonna get hot.
Don't ride with shorts on. :-)
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle’s handling, stability and braking, making it unsafe to ride.
swallowtailed
swallowtailed
swallowtailed
swallowtailed
