Battery or something more serious?
#1
Posted 15 June 2012 - 06:02 AM
So, i pulled off to the side of the road and let her sit for a while. After about 20 minutes of sitting, she fired up and I cut across the median on i81 and ran her home to restart my journey in the car instead. Where I was going, it's all stop and go traffic and I didn't want to get stuck again in Jersey.
Of course, it was hot. So the fan was constantly running.
My guess is the battery didn't have a full charge and the combination of lights, fan and idling motor just taxed it to death. Wires looked okay - nothing fried that I could see.
Other than putting the bike on then tender when not in use, should I worry about anything else being wrong?
#2
Posted 15 June 2012 - 06:07 AM
#3
Posted 15 June 2012 - 10:57 AM
-Jake
-Douglas Adams
#4
Posted 15 June 2012 - 11:05 AM
Like everybody already mentioned, check your main connector near the starter relay and the connector for the stator and the main connector for the R/R. Do you have Tightwad's VFRness harness upgrade? Might want to check into that. I used his kit and cut the connectors out and soldered the wires together and used the extra ground wire on his kit to run right to the negative battery terminal (I had previously modified the terminal with a bigger gauge ring terminal soldered onto it, and use a slightly longer, higher quality screw for my terminal connection).
Hope you get it sorted!
Cheers!
#5
Posted 15 June 2012 - 11:10 AM
Edited by mk2davis, 18 June 2012 - 12:39 AM.
#6
Posted 15 June 2012 - 11:55 PM
Time to find out how good Batteries Plus is on warranty issues.......
#7
Posted 16 June 2012 - 03:51 AM
Needing a new battery myself. Current one is just a year old AGM. Charging system is fine. Bike is ridden 2-3X a week. VFR batteries live a rough life being so close to the exhaust/shock, and the high freq vibration.
Is it a Batteries Plus branded battery?
Im sure their warranty is very usable, especially being a chain type store. If it was a 6th gen id suggest upping to the st1300 battery if an option. The stock battery is just barely adaquate.
#8
Posted 16 June 2012 - 11:13 AM
Yeah it is the higher CCA BP brand battery. Bought in SF last June. I may try some heat shielding on the undertail to see if it helps.
#9
Posted 16 June 2012 - 11:14 AM
#10
Posted 16 June 2012 - 11:30 AM
If the replacement only lasts a year, different brand might be best.
Rules
