Installing staintunes on 2003 vtec
  • Please log in to reply
5 replies to this topic
#1 richieg
richieg
    Local Racer
  • Members
  • Pip
  • 11 posts
  • Why VFRD?:Just purchased a 2003 VTEC
  • In My Garage::2003 Silver VFR8000 VTEC
Posted 18 May 2012 - 04:31 PM
I've removed my stock exhaust and have a question regarding fitting the staintunes. is it necessary to remove the old silver coloured gasket? it looks as though the staintunes will not fit unless it is removed but i'm concerened about the exhaust leaking. The instructions on line also suggest using high temperature sealant on the mufflers - is this necessary as the second hand pipes i'm fitting don't look as though any sealant was previously used...
Posted Image
#2 bayarearider
bayarearider
    Motorcycle Racing Legend
  • Volunteer
  • 1030 posts
  • Why VFRD?:VFR info runs deep here...
  • In My Garage::04 VFR-Asphalt
Posted 18 May 2012 - 05:59 PM
I had not noticed a gasket at the mid-pipe / cat connection when I replaced the cracked mid with the new hanger design one.
The bolted strap keeps it plenty tight.
I did however use the high heat copper silicone sealer on both cans to Y pipe connection to get rid of a noticable rattle. Worked like a charm!
#3 Knute
Knute
    Milepig
  • Forum Contributor
  • 396 posts
  • Why VFRD?:Great info!
  • In My Garage::04 VFR (red)
    09 Yamaha FZ6R (wifes)
    08 Ridgeline
    Honda snowblower, lawnmower, generator
Posted 18 May 2012 - 06:07 PM
Pretty much the same here... just used a little sealant at the Y pipe connections and that was it.
Knute
Red '04 ~ Michelin PP [F], PPR2 [R] ~ Power Commander 3USB - Cozye's Map ~ Radio Shack O2 Eliminators ~ K&N Filter ~ Datel Volt Meter ~ OEM Hard Bags ~ Heli Bars  ~ Sargent Seat ~ Cheap Pazzo Knockoff Levers ~ PowerLet Power Supply ~ VFRness & Fuse Block. ~ Cut Rear Foot Pegs ~ TomTom GPS ~ Staintune Exhaust ~ F4i Fork Conversion (VFR Uppers/F4i Lowers) ~ Ohlins rear shock ~ Steel Braided Brake & Clutch Lines.
#4 PACIFICMAN
PACIFICMAN
    Factory Team Rider
  • Members
  • PipPipPip
  • 237 posts
  • Why VFRD?:Excellent site for info, how to and help.
  • In My Garage::2002 Honda VFR
Posted 18 May 2012 - 07:40 PM
Same as above. Clamp the pipe, as is to the header/Cat. Use High temp copper(I used Permatex) sealant at the "Y" pipe muffler joints, Tighten bolts, let sealant cure per the instructions and ride.
Edited by PACIFICMAN, 18 May 2012 - 07:41 PM.
#5 richieg
richieg
    Local Racer
  • Members
  • Pip
  • 11 posts
Posted 20 May 2012 - 02:34 AM
The staintunes is fitted - I used some loctite 5920 to seal the mufflers on the y pipe.
Thanks for all responses.
When assembling though I could not get the replacement passenger bolt through the exhaust bracket with mufflers attached so gave up in the end and used stock bolt. I think I read somewhere that this is no longer done on newer exhausts...
Finally I can't remove one of the db killers - seems to be held in very securely.. any tips?
Posted Image
#6 johnmark101
johnmark101
    Power is nothing without control.
  • Forum Contributor
  • 1986 posts
Posted 20 May 2012 - 08:26 AM
The spuds should come out of the cans rather easily. Try squirting some PB blaster on the small screw and let it soak a bit.
swallowtailed
swallowtailed
swallowtailed
swallowtailed
