6th gen built around rear shock? (more rant than anything)
  • Please log in to reply
24 replies to this topic
#1 pres589
pres589
    World Superbike Racer
  • Forum Contributor
  • 557 posts
  • Why VFRD?:Great resource for all sorts of information.
  • In My Garage::2004 VFR800
Posted 09 May 2012 - 09:24 AM
2004 VFR, non-ABS, did Honda not want people to ever consider replacing the rear shock unit? I think I burned half an hour at least trying to get the top bolt out of the rear shock unit on this thing last night until hanging it up. 14mm combo wrench on the bolt, 17mm combo wrench on the nut, and this thing is so hard to get to I never did get the thing completely apart.
The bottom bolt was nothing, just fire up the compressor and a touch of the impact wrench and I'm good. But that top... I've got the tank pulled off and set forward and it isn't in the way, unless I'm supposed to swing a wrench at the nut from the front side. Plastic all off the rear of the bike including the battery and opposite covers, pulled the rear MC reservoir out of the way, along with an electrical disconnect that was in the same general area. If the linked brake prop valve wasn't hanging out in front of the nut maybe life would be easier.
Is there something I'm missing or is this just one of those things that stinks to deal with no matter how a guy attacks it?
#2 digitallyhip
digitallyhip
    Factory Team Rider
  • Forum Contributor
  • 198 posts
  • Why VFRD?:ask George Mallory
  • In My Garage::2003 VFR, 2007 Mitsubishi Outlander, 2012 Mini Countryman All4, Kawasaki KLX-250S
Posted 09 May 2012 - 09:32 AM
If you had an ABS version, you'd also have the joy of removing the preload adjuster...
Posted Image Posted ImagePosted ImagePosted Image
#3 Egg on Leggs
Egg on Leggs
    Factory Team Rider
  • Members
  • PipPipPip
  • 294 posts
  • In My Garage::Honda VFR 800 VTEC ABS
Posted 09 May 2012 - 11:17 AM
Pres, just undo and remove the rear tank bolt, after releasing the front then raise rear of tank to reveal the top bolt of the top shock mount and drop the lot.
To put it back just attach the top mount to the shock, thread it back up, bit of a wiggle, get the nut back on a few threads and rest
#4 bayarearider
bayarearider
    Motorcycle Racing Legend
  • Volunteer
  • 1029 posts
  • Why VFRD?:VFR info runs deep here...
  • In My Garage::04 VFR-Asphalt
Posted 09 May 2012 - 11:25 AM
Hmm, don't recall it being that much of an issue when I threw the "Oh" on. Especially since it was my first. A little cramped but once properly stripped all reachable.
Hope it works out for you. You will be happy with the upgrade!
#5 pres589
pres589
  • Forum Contributor
  • 557 posts
Posted 09 May 2012 - 11:45 AM
So under the tail of the tank, where that hard mount is, I pull that up after removing it's retaining bolt/hinge? What else needs to happen? I didn't see an angle of attack available from the top that far forward. I won't get to do much with the bike tonight but I'll see if I can get 10 minutes in the garage and either get the bolt out or take a picture of what I'm seeing and ask again.
#6 SEBSPEED
SEBSPEED
    float like a goldwing, sting like a gixxer
  • Volunteer
  • 21666 posts
  • Why VFRD?:Because it's the best
  • In My Garage::Mini Honda dealership
Posted 09 May 2012 - 03:04 PM
It should only take about an hour to swap the shock on a non-abs.
Leave the tail intact. Pull the seat, prop the tank up, remove the rear wheel. Remove the triangle plates and jack the swingarm up as high as it will go. Then undo the top mount nut, shock will slip easily out the bottom.
Reverse for assembly...
Sebastian Live to mod, mod to live... the best you know is the best you've ridden... adventures suck when you're having them...
2005 VFR800 - Winning Red -- 1996 VFR750 - secret project -- 1995 XR250R - little beasty
1983 VF750F - hot rod resto -- 1981 CB900F - hot rod build/resto -- 1976 BMW R60/6
-- 1996 XR400R -- 2000 XR70R -- 2003 CRF150F
Gone but not forgotten - 01 F4i - 84 VF500F - 02 954 - 96 VFR750F
tmac07avatar.jpgCatskills03.jpgTMac09RideIcon.jpg2010CatskillsIcon.jpgTMac11Icon.jpg678973a4.jpgPostHo.jpg
#7 pres589
pres589
  • Forum Contributor
  • 557 posts
Posted 09 May 2012 - 03:22 PM
instructions instructions...
The problem I was having was getting access to the top bolt. The rest of this is pretty straight forward. Eggs says to head down at it from the top side, I seem to remember the rear subframe getting in the way as well as some other bits from the tank's rear mounting hardware, although I can take another look at that tonight. I'm only asking about this bolt, can you just address that aspect?
#8 Monk
Monk
    Race Team Owner
  • Volunteer
  • 5026 posts
  • Why VFRD?:Great people
  • In My Garage::Honda VFR '08
    Honda Civic
    Coupe EX '12
Posted 09 May 2012 - 03:38 PM
Easy even I can do it........ Like Seb said one nut at the top drop the shock out then worry about the nut and bolt on the top of the shock........ But you need to drop the shock 1st, to get to the nut and bolt.
The trick is putting it back......... You'll need to reinstall the nut and bolt tight enough to stay in place while you put the shock in the top hole.........and once it's lined up remove it again and torgue it down then put it back in the top hole again.
Defensive Riding Is A Pro-Active Must (John)
MOD's: Suspension(ByJamieDaugherty);LarimarLip;HeliBars;GripPuppies;ThrottleBoss;NepThrottleLock;
PegLoweringBlocks(ByBLS);TomTomGPS;GoProCamera;VoltMeter;TankBag;LowCutTankBra;SargentSeat;
TailBag;OemPanniers;WheelHugger;RedWheelStipes&RadiatorGrills;
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image 6
#9 SEBSPEED
SEBSPEED
  • Volunteer
  • 21666 posts
Posted 09 May 2012 - 04:23 PM
Lemme see if I can find the pic I have of my bike mid-swap.
I removed the front tank bolts, then the rear, propped the tank up at the back with a piece of wood and had at it.
#10 SEBSPEED
SEBSPEED
  • Volunteer
  • 21666 posts
Posted 09 May 2012 - 04:32 PM
Here you go...
Posted Image
swallowtailed
swallowtailed
swallowtailed
swallowtailed
