Poor fuel economy?
#21
Posted 24 April 2012 - 08:29 PM
I calculated your 280kms, equals 173 miles. if thats where you getting a low fuel warning thats about right, but you have about 30 to 40 miles in reserve.
sunday I road a tank 202 miles and only held 4.75 gallon on fill up, so even though I was on empty warning, I still had about a gallon left
#22
Posted 24 April 2012 - 08:39 PM
My experience the temp falls faster after you turn the motor off, than waiting on the fan.
Yea, I just turn the bike off when I stop, even if the fan in on.
Rodney Reynolds
http://www.MotorcycleDistraction.com
04 VFR800 (Current)
11 CBR250R
06 Kawasaki 650R
06 Yamaha TW200
83 Honda 100cc dual sport
#23
Posted 24 April 2012 - 09:18 PM
#24
Posted 24 April 2012 - 11:19 PM
This is my experience too with my 2006. On my longest ride to date, from north of San Antonio, Texas to Vancouver, B.C., (more slab than I would have liked due to time constraints), I managed 47 mpg. In city driving, definitely under 40 mpg. There is quite a bit of juice left once the last bar on the fuel gauge starts flashing. I figure it's close to a gallon, so safely 30 miles and maybe 40 as Spud suggests. I've never run out (yet), but I have had to squint pretty hard to see gas in the bottom of the tank
Note: By all accounts, the Power Commander will reduce your mileage. I don't have one since I seem to have one of the 6th gens that's fairly smooth at small throttle openings and the VTEC transition (revised in 2006) is also smooth. I think digitallyhip described it as turning on a vibrator
Edited by Belfry, 24 April 2012 - 11:27 PM.
"Luck is what happens when preparation meets opportunity."
-- Seneca (Roman philosopher, mid-1st century AD)
#25
Posted 25 April 2012 - 02:01 AM
#26
Posted 25 April 2012 - 12:08 PM
I've been able to get 300kms+ out of my 09. I do mostly highway driving, using 91 octane. Have you ever put a little fuel injector cleaner through it. I often put a touch in the odd tank. Don't know if it makes a difference but I also use synthetic oil...One other thing to keep in mind especially in Canada is that most fuel companies add gas line antifreeze to the fuel calling it wintergas. Being that its still early in the season, you may still be getting some of this winter gas at your gas station until its all used up. I know my truck gets terrible fuel mileage on the winter gas. Just saying.
I use 87 octane from mainly one gas station, so maybe. I have used a bit of the Lucas fuel infection cleaner, maybe I should put more in to really clean her out. I'm not sure, but using Lucas should be equal to high Octane fuel? Or maybe I should try and few tanks of the high octane.
Sent from my Galaxy Nexus using Tapatalk 2
Rodney Reynolds
04 VFR800 (Current)
11 CBR250R
06 Kawasaki 650R
06 Yamaha TW200
#27
Posted 25 April 2012 - 01:02 PM
#28
Posted 25 April 2012 - 02:42 PM
IIRC, higher octane fuel has less stored energy. The greater HP output associated with it has to do with being able to run it under higher compression without detonation. If your bike isn't detonating, there's no reason to run the higher octane.I've been able to get 300kms+ out of my 09. I do mostly highway driving, using 91 octane. Have you ever put a little fuel injector cleaner through it. I often put a touch in the odd tank. Don't know if it makes a difference but I also use synthetic oil...One other thing to keep in mind especially in Canada is that most fuel companies add gas line antifreeze to the fuel calling it wintergas. Being that its still early in the season, you may still be getting some of this winter gas at your gas station until its all used up. I know my truck gets terrible fuel mileage on the winter gas. Just saying.
#29
Posted 25 April 2012 - 08:39 PM
Rodney Reynolds
04 VFR800 (Current)
11 CBR250R
06 Kawasaki 650R
06 Yamaha TW200
Rules
