What about an "italian stallion" viffer
  • Please log in to reply
308 replies to this topic
#191 karhawk
karhawk
    World Superbike Racer
  • Forum Contributor
  • 320 posts
  • Why VFRD?:one of the best there is
  • In My Garage::75 Fiat X19,82 Fiat 2000 spider,95 Suburban 2WD,and 96 VFR
Posted 19 May 2012 - 09:49 AM
one more mock up, I would change the black here with that snakeskin tank stuff. brake lines, clutch master, and caliper spacers are the only things holding this back from a ride.
Posted Image
What material did you use to make the filler panel at the bottom of the tank? I'm attempting to make one out of aluminium, but am not 100% pleased with it at this point...
It's just a good looking mock up made out of balsa like foam board I got at the art supply house and painted red. My plan is to use Kydex which is a plastic formable material that you heat up and it will mold to your negative.
Ah, ok, thanks for the info. Would you be willing to make a second one, or mail some Kydex over here, as I'm not sure that I can find it where I live in Germany. I do have a U.S. mailing address, so shipping won't be expensive, and I can easily paypal you. Thanks again!
I don't think I will use the Kydex material, it turns out it has to be held on the negative mold with pressure and my negative is made out of bookbinders cardboard so unless I make a plaster of paris base for the negative it won't stand up to the pressure needed to mold the Kydex. I think I will use fiber glass as a backing and bondo to smooth the front.
#192 Veefer800Canuck
Veefer800Canuck
    FrankenOwner
  • Forum Moderator
  • 11506 posts
  • Why VFRD?:I have the V-4 disease and there is no known cure except for copious applications of Throttle!
  • In My Garage::2010 Honda GL800RR-SP2
    Back in business baby!
Posted 19 May 2012 - 10:17 AM
Awesome, coming along nicely. Those brakes are going to be stupid powerful!!! This is good.
And your daughter is all kinds of cute!!!!
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle’s handling, stability and braking, making it unsafe to ride.
#193 The Phantom
The Phantom
    Quieta non movere
  • Volunteer
  • 3957 posts
  • Why VFRD?:Force of habit...
  • In My Garage::94 VFR750
    95 VFR750
Posted 20 May 2012 - 09:30 AM
+1
Great stuff Chris!
It's a tour, not a race... but don't get in my way while I'm touring!
#194 trjerm
trjerm
    Factory Team Rider
  • Forum Contributor
  • 165 posts
  • Why VFRD?:A great group of riders with great info and insight
  • In My Garage::1994 VFR 750 , 1985 kawasaki Gpz 900, 1969 kawasaki A7RA ,1968 kawasaki A7SS, 1994-97 VFR 950RR
Posted 20 May 2012 - 09:59 AM
that things coming along great and nice stand to go with it.
#195 karhawk
karhawk
  • Forum Contributor
  • 320 posts
Posted 21 May 2012 - 08:36 PM
Posted Image
Tank fairing painted I just need to glue a dowel on the back side, also waiting on the 900RR pedals, brackets and ankle guards. I changed the temp sensor to work with the 900 RR gauge and need to finish wiring to the gauge. This thing barks with that old cut down Micron exhaust.
#196 mello dude
mello dude
    half genius, half dumbass whackjob foole
  • Forum Contributor
  • 1664 posts
  • Why VFRD?:The best collection of motorcycle geek tech minds on the planet
  • In My Garage::'98 VFR800 & '99 Valkyrie, one to go fast, one to go slow, not necessarily in that order.
Posted 21 May 2012 - 09:14 PM
Looks amazing!
#197 SEBSPEED
SEBSPEED
    float like a goldwing, sting like a gixxer
  • Volunteer
  • 21665 posts
  • Why VFRD?:Because it's the best
  • In My Garage::Mini Honda dealership
Posted 22 May 2012 - 07:43 AM
Can't wait to see it in the wild!
Sebastian Live to mod, mod to live... the best you know is the best you've ridden... adventures suck when you're having them...
2005 VFR800 - Winning Red -- 1996 VFR750 - secret project -- 1995 XR250R - little beasty
1983 VF750F - hot rod resto -- 1981 CB900F - hot rod build/resto -- 1976 BMW R60/6
-- 1996 XR400R -- 2000 XR70R -- 2003 CRF150F
Gone but not forgotten - 01 F4i - 84 VF500F - 02 954 - 96 VFR750F
tmac07avatar.jpgCatskills03.jpgTMac09RideIcon.jpg2010CatskillsIcon.jpgTMac11Icon.jpg678973a4.jpgPostHo.jpg
#198 trjerm
trjerm
    Factory Team Rider
  • Forum Contributor
  • 165 posts
Posted 22 May 2012 - 09:22 AM
Hi Chris, thats one of the nicest franken VFR's that I've seen, awesome job so far, when its done give a call and lets go for a ride.
#199 karhawk
karhawk
  • Forum Contributor
  • 320 posts
Posted 22 May 2012 - 01:11 PM
Anybody wanna hazard a guess about wiring these connectors? 1st photo is VFR blue and green plugs noted,
2nd photo is the connector for 900 rr gauge. I can't get power to the gauge, I have switched power
going to the red and the two negatives going to the frame.
Posted Image
Posted Image
#200 karhawk
karhawk
  • Forum Contributor
  • 320 posts
Posted 22 May 2012 - 01:22 PM
That would be good, I'm itchin to take her out
swallowtailed
swallowtailed
swallowtailed
swallowtailed
