Over my head (and its OK!)
  • Please log in to reply
18 replies to this topic
#1 mark68502
mark68502
    Local Racer
  • Members
  • Pip
  • 11 posts
  • Why VFRD?:Bought project bike and am slowly learning...
  • In My Garage::1981 CB750K, 1987VFR700
Posted 02 April 2012 - 11:37 PM
Bought an 87VFR700 last year that had been garaged for 10 years. Joined VFRD at that point but have been mostly a lurker since then.
Learned quickly that you should NOT bother replacing side panels until you can start the bike! (Ok, so I didn't really "learn" the lesson, I just ran out of money... lol)
Anyway, started fiddling with things and learning my way around this bike and here's where we are
1. Im definitely in over my head.
2. This is NOT a problem - its how I learn.
3. Spent alot of time with miracle oil, pb blaster and what-not
4. The engine can now be turned over (by hand) but there is ALOT of pressure when piston 1 reaches TDC. Its WAY more than when any of the other pistons goes through compression even with all the plugs out
5. Took the top end off to assess the damage from a battalion of mice that were living in the airbox.
I am suspecting the valves are not working quite right on that cylinder - they suffered the most from the mice and show alot of surface corrosion - but I CAN manually turn past that point so... wondering if anyone has a magic mirror and can ask it what the likely meaning of this little problem is?
6. Much to my surprise, I seem to have got the cams put back on right. Shop manual really DOES help!
Edited by mark68502, 03 April 2012 - 09:04 AM.
#2 WestOfBen
WestOfBen
    Factory Team Rider
  • Members
  • PipPipPip
  • 194 posts
  • Why VFRD?:Since a wee laddie...
  • In My Garage::1994 VFR750F
Posted 03 April 2012 - 03:05 AM
I would try turning it over by hand with all plugs removed. By my reasoning this would allow you to test whether things are hitting other things, like valves hitting pistons slightly and it might give you a feel for bearings. After that I would invest in a compression tester, or find someone who can do this for you. Squirt a little bit of light oil in the cylinders (with the plugs out).
All of this may be wrong of course. VFRD Gurus please correct me so that I might learn also!
#3 coffeebrake
coffeebrake
    Factory Team Rider
  • Members
  • PipPipPip
  • 290 posts
  • Why VFRD?:Breakfast of champions.
  • In My Garage::'86 VFR700F rescue
    '05 Kawasaki Concours
    '99 Suzuki Bandit
    '79 Honda CX500
Posted 03 April 2012 - 05:43 AM
You tore into a top end with zero experience?
My advice is to stop right now before you ruin something expensive or rare, sell the bike to someone with more wrenching experience, and go get yourself an 80's air-cooled parallel twin to rebuild instead. You will learn so much more if you start with a simpler machine. And you will find the process so much more rewarding if you get a rideable motorcycle out of it, which you might not with this VFR. If rodents actually damaged the valves, I have to wonder if this bike is a practical project.
You could pick up a Ninja 500 or Vulcan 500, or a Honda CM400, or CB450, a KZ400, or an XS400 that "needs work" for super cheap. Just make sure piston rings and carb parts are available for it.
I am by no means being mean to you. I'm sharing my hard experience. I completely tore apart and re-assembled a little twin engine, taking it from the frame and splitting the cases to check every single tolerance, before I ever tackled a top end job on a bigger bike. My mistake was choosing a little twin without making sure I could get the parts I needed. What I did right, was take apart (and re-assemble correctly) a very simple engine instead of a relatively rare, heavy, water-cooled, and cramped V-four.
#4 YoshiHNS
YoshiHNS
    Race Team Owner
  • Forum Contributor
  • 4026 posts
  • Why VFRD?:Because I want to make fun of Seb being a post ho
  • In My Garage::Honda dealership with some unwanted suzuki's
Posted 03 April 2012 - 05:54 AM
How did the mice get to the valves? Airbox is easy and I know that's not too uncommon, but the valves?
Some bikes end up being a project. Yoshi manages to make it a career.
No no no. This is the precision toolboard. The hammer resides elsewhere.
Never ending projects: 1971 Suzuki MT50, 1989 Honda VTR250, 1993 Honda CBR F2, 1994 Tomos Targa LX, 1996 VFR750F, 2006 Honda ST1300
Road Worthy: 1993 Honda ST1100, 1996 Honda VFR 750F, 1998 Honda VFR 800, 2001 Honda ST1100, 2007 Honda VFR800 RWB.
 sml_gallery_3681_4223_1633.gifCatskills03.jpg2010CatskillsIcon.jpgtmac2010-1.pngsml_gallery_491_6304_271.gifsml_gallery_491_6304_1801.png
#5 coffeebrake
coffeebrake
    Factory Team Rider
  • Members
  • PipPipPip
  • 290 posts
    '99 Suzuki Bandit
    '79 Honda CX500
Posted 03 April 2012 - 06:20 AM
I assume the bike was left with the carbs off?
#6 kgsmotorcycles
kgsmotorcycles
    World Superbike Racer
  • Forum Contributor
  • 526 posts
  • Why VFRD?:V.F.R.D. is simply the only place to be!
  • In My Garage::vfr750
Posted 03 April 2012 - 06:37 AM
Will not any vfr 750 engine 86-97 slip straight in? At least any RC24 engine anyway..86-90
Buy them cheap with carbs on.... saves a fortune and time.
#7 wlodek1980
wlodek1980
    Privateer
  • Members
  • PipPip
  • 86 posts
  • In My Garage::vmx 1200
    vf1000fe
Posted 03 April 2012 - 06:54 AM
looks like you misalligned top end and now bending valves on cyl1
#8 mark68502
mark68502
    Local Racer
  • Members
  • Pip
  • 11 posts
Posted 03 April 2012 - 07:38 AM
I would try turning it over by hand with all plugs removed. By my reasoning this would allow you to test whether things are hitting other things, like valves hitting pistons slightly and it might give you a feel for bearings. After that I would invest in a compression tester, or find someone who can do this for you. Squirt a little bit of light oil in the cylinders (with the plugs out). All of this may be wrong of course. VFRD Gurus please correct me so that I might learn also!
I think thats good advice, since thats where I started. :)
You tore into a top end with zero experience? My advice is to stop right now before you ruin something expensive or rare, sell the bike to someone with more wrenching experience, and go get yourself an 80's air-cooled parallel twin to rebuild instead. You will learn so much more if you start with a simpler machine. And you will find the process so much more rewarding if you get a rideable motorcycle out of it, which you might not with this VFR.
Small twins are great for learning! Learned carbs & electrical on a small v-twin and resurrected an 81CB750 for my daily rider. This is definitely more of a mechanical adventure but for $300, I can afford to explore a little. Cams don't worry me too much but I have no desire (yet) to drop the engine or go any deeper.
I know right!? They ate / pissed their way right through the filter and then the urine just dripped down into everything. I think they were probably gentically enhanced super-evil mice or something... :)
Edited by mark68502, 03 April 2012 - 07:40 AM.
#9 mark68502
mark68502
    Local Racer
  • Members
  • Pip
  • 11 posts
Posted 03 April 2012 - 07:46 AM
Bent valves is what it feels like. Could be that the PO damaged #1 but it was stiff before I dug into the top end and after re-assembly it feels just like it did before, except that it is smoother on 2, 3, and 4 than it was at first...
#10 mark68502
mark68502
    Local Racer
  • Members
  • Pip
  • 11 posts
Posted 03 April 2012 - 07:53 AM
No but the airbox was not capped.
swallowtailed
swallowtailed
swallowtailed
swallowtailed
