Helibars install with new cables - problem found
  • Please log in to reply
14 replies to this topic
#1 RedShed
RedShed
    Go Florida Gators
  • Forum Contributor
  • 64 posts
  • Why VFRD?:Great people, a sense of community, and a hope to improve my skills, knowledge, and wisdom!
  • In My Garage::1999 VFR800, 1976 Porsche 912e, 1974 Triumph Spitfire
Posted 25 March 2012 - 08:04 PM
Ok, so I received my new st1100 throttle cables today (17910-MT3-000 cable A and 17920-MT3-000 cable B). I spent about an hour and a half installing the helibars. The clutch side went without a hitch, however I am stuck on the throttle side. I have the bars installed, and the throttle cables routed following the factory route, but the free length of the cables seems too short to be able to attach at the engine end of the cable. Is there a trick to getting the cable back into the throttle body end?
Redshed, aka Mike
First bike was a honda MT125 elisinore enduro
Followed by a 1984 VT500 Ascot
........Many years and cars later.......
Back in the game on a red 1999 VFR800
#2 AnikMankar
AnikMankar
    Moto Grand Prix Racer
  • Forum Contributor
  • 690 posts
  • Why VFRD?:to meet my fellow VFRD friends ...
  • In My Garage::VFR800 - 1998,
    SX4 - Suzuki
    Previous Bikes
    GSX750 - 1981
    RD350 - 1985
Posted 25 March 2012 - 11:00 PM
ST1100 throttle cable
you will get very little to no slack but it works. I am using it for last 6 months and no issues. in time it will stretch.
#3 Veefer800Canuck
Veefer800Canuck
    FrankenOwner
  • Forum Moderator
  • 11523 posts
  • Why VFRD?:I have the V-4 disease and there is no known cure except for copious applications of Throttle!
  • In My Garage::2010 Honda GL800RR-SP2
    Back in business baby!
Posted 25 March 2012 - 11:03 PM
Did you remove the bracket that the throttle cables attach to? Then you can move the cables closer to the wheel, and hook the cables in their grooves, then slide the assembly back and resecure the bracket to the throttle bodies.
I JUST did this this week, and it worked fine. You may have to manually work the throttle wheel to get the cables attached.
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle’s handling, stability and braking, making it unsafe to ride.
#4 AnikMankar
AnikMankar
  • Forum Contributor
  • 690 posts
    SX4 - Suzuki
    Previous Bikes
    GSX750 - 1981
    RD350 - 1985
Posted 25 March 2012 - 11:46 PM
Yes i did that ...it was easier...and quicker...
#5 RedShed
RedShed
    Go Florida Gators
  • Forum Contributor
  • 64 posts
Posted 26 March 2012 - 05:08 AM
No, I did not remove the bracket, was trying to lasso the wheel with the bracket attached. I will give it a try! Thanks.
Redshed, aka Mike
#6 RedShed
RedShed
    Go Florida Gators
  • Forum Contributor
  • 64 posts
Posted 26 March 2012 - 05:44 PM
Ok, pulling the bracket was the ticket! I'm back in business! Thanks all
Redshed, aka Mike
#7 Veefer800Canuck
Veefer800Canuck
    FrankenOwner
  • Forum Moderator
  • 11523 posts
Posted 26 March 2012 - 06:00 PM
YAY!
#8 AnikMankar
AnikMankar
  • Forum Contributor
  • 690 posts
    SX4 - Suzuki
    Previous Bikes
    GSX750 - 1981
    RD350 - 1985
Posted 28 September 2012 - 04:07 AM
anyone know where to get longer Choke cables ? for 5th gen
#9 gr8vfr
gr8vfr
    RideWNC.com
  • Members
  • PipPipPipPipPip
  • 605 posts
  • Why VFRD?:?
  • In My Garage::+++++++ Y2K VFR800fi
    09 Kawi C-14
    08 Ducati 848
    03 Yamaha Kodiak 400
    96 VFR750F
    95 VFR750F
Posted 28 September 2012 - 06:35 AM
I have had Heli's on my 2000 on and off many times swapping between stock and heli's.
There has never been and issue with the cables or hoses being to short.
Is this issue limited to first generation(98-99) fifth gen VFRs?
Edited by gr8vfr, 28 September 2012 - 06:36 AM.
Why is there never enough time to do it right the first time, but always enough time to do it over?
#10 Veefer800Canuck
Veefer800Canuck
    FrankenOwner
  • Forum Moderator
  • 11523 posts
Posted 28 September 2012 - 06:55 AM
I had helibars on my 99 before i did the front end swap. I had stock cables with no issues. Just had to reroute them for maximum free play.
swallowtailed
swallowtailed
swallowtailed
swallowtailed
