Vf500f Pictures and Painting
vf500f
  • Please log in to reply
11 replies to this topic
#1 eamann
eamann
    Privateer
  • Members
  • PipPip
  • 59 posts
  • Why VFRD?:I purchased my first VFR, a 1986 VF500F, and am looking to get some help with getting it running properly. I would also like to figure out some ways to mod the bike if possible
  • In My Garage::1986 Honda VF500F, 2006 Honda CBR1000RR , 2004 Triumph daytona 600, 2006 Ducati Monster 800
Posted 09 March 2012 - 02:02 PM
Alright guys,
So thanks to all the help from you here on the forum (especially invisiblecities, a walking encyclopedia of information about interceptors), I was able to get the bike up and running strong. Total cost of bike with parts (not including 100 hours of work!) was about $850. Time to start making her look pretty. Here's a list of things I am going to do...
Rebuild brakes (possibly new lines if it's in the budget)
Paint anything that needs it (especially the frame)
New sprockets/chain possibly
Paint rims (not sure about this yet)
Belly fairing needs paint
Painting the forks (I hate the red, maybe black?)
The right side casing is scraped pretty bad. I don't know exactly what I want to do with that. Suggestions?
Exhaust mod
Posted Image
DSC01052 by eamann66, on Flickr
Posted Image
DSC01051 by eamann66, on Flickr
Posted Image
DSC01053 by eamann66, on Flickr
#2 Veefer800Canuck
Veefer800Canuck
    FrankenOwner
  • Forum Moderator
  • 11506 posts
  • Why VFRD?:I have the V-4 disease and there is no known cure except for copious applications of Throttle!
  • In My Garage::2010 Honda GL800RR-SP2
    Back in business baby!
Posted 09 March 2012 - 02:31 PM
For the right side engine cover, you could remove it, file the damaged area a bit to remove most of the scratches, then repaint it gloss black again.
I did that with a VF750 and it turned out not too bad. Several coats with the part laid on its back almost filled the scratches.
The paint is only limited by your imagination.
As for exhaust, there is nothing out there, so you're stuck with finding a set of dual cans on eBay and adapting them with custom midpipes from your stock collector box. Bear in mind that most full size bikes will use cans that are quite long and look out of proportion on the miniceptor. Either cut them down or find some shorties like the stunters use. And most cans nowadays use a 2 inch inlet pipe and I'll bet the outlets from your collector box are 1.5 inch or close to that, so you will need to step up/down your pipe size to suit.
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle’s handling, stability and braking, making it unsafe to ride.
#3 eamann
eamann
    Privateer
  • Members
  • PipPip
  • 59 posts
Posted 09 March 2012 - 02:44 PM
What kind of money are we talking for parts making a custom exhaust? I can get a welder and everything but I don't know what we're looking at price wise for pipe for the bike. Is that a possibility or is that just a silly dream of mine?
#4 InvisibleCities
InvisibleCities
    slightly off center
  • Forum Contributor
  • 271 posts
  • Why VFRD?:Fan of Honda V4s.
  • In My Garage::'84 VF500F – modified
Posted 09 March 2012 - 02:49 PM
Exhaust is tricky. A very good thread on this topic can be found here:
http://www.vfrdiscus...-vf500-exhaust/
#5 Veefer800Canuck
Veefer800Canuck
    FrankenOwner
  • Forum Moderator
  • 11506 posts
Posted 09 March 2012 - 03:18 PM
If you are paying someone else to do it, you will pay more than the bike is worth. I was suggesting keeping the stock headpipes and collector, and just fabbing a set of slipons. The midpipes would only be like a foot long or so, so easy to do.
#6 InvisibleCities
InvisibleCities
    slightly off center
  • Forum Contributor
  • 271 posts
Posted 09 March 2012 - 03:24 PM
On this note, slip-ons rob power over stock.
If going for a 4-1 system you'll need some serious design skills to get everything dialed in. Even then expect a drop at mid-range.
I'd invest in other upgrades (i.e. new monoshock) before diving into a custom exhaust (my 2 cents of course).
Good luck either way and look forward to seeing the progress!
#7 eamann
eamann
    Privateer
  • Members
  • PipPip
  • 59 posts
Posted 09 March 2012 - 04:24 PM
Yes I was looking into that the other day. Probably a better investment to start.
Also, I need to strip the cans and repaint them. Should I just use a wire brush with a drill on the can?
#8 Veefer800Canuck
Veefer800Canuck
    FrankenOwner
  • Forum Moderator
  • 11506 posts
Posted 09 March 2012 - 06:29 PM
I believe the factory finish is a type of black chrome. You probably aren't going to get that off without a chemical bath or glass bead blasting.
Best method would be a chemical dip and strip at a chrome shop followed by replating or ceramic coating, but then again, you're soon spending more than a pristine example of the bike would be worth.
#9 eamann
eamann
    Privateer
  • Members
  • PipPip
  • 59 posts
Posted 19 March 2012 - 10:09 PM
In terms of a new shock. What am I looking for? I would like to get one sometime in the future.
Also, is it doable for someone who does not have a metal shop to do a front and rear wheel swap for the f2 conversion? Anyone know of the right thread to be looking at?
Edited by eamann, 19 March 2012 - 10:18 PM.
#10 InvisibleCities
InvisibleCities
    slightly off center
  • Forum Contributor
  • 271 posts
Posted 22 March 2012 - 08:41 AM
I'd recommend an F4i shock conversion (with remote reservoir) from DMr.
Posted Image
Also tagged with one or more of these keywords: vf500f
swallowtailed
swallowtailed
swallowtailed
swallowtailed
