'Gravity tank' for VFR RC30 project
#1
Posted 22 February 2012 - 08:29 AM
Second question from my RC30 replica project,
I want to use an NC30 tank on my VFR750 (4th gen) for my RC30 project (would love an RC30 one but seem to be as rare as rocking horse, er, teeth).
From what I can see teh VFR uses a pressurised fuel system via a fuel pump, the NC30 and RC30 both had a simple gravity type system (pretty sure most of the earlier VFRs did), can I simply ditch the fuel pump and use that type of tank, running the fuel line from the fuel cock to the carbs?
Any help would be welcomed!
Sean
#2
Posted 22 February 2012 - 10:46 AM
The 750s used an external fual pump, sucking out of the tank, so I see no reason why you could not plumb the NC30 tank's outlet into the VFR's electric pump inlet.
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle’s handling, stability and braking, making it unsafe to ride.
#3
Posted 22 February 2012 - 02:00 PM
#4
Posted 27 February 2012 - 04:52 PM
#5
Posted 27 February 2012 - 07:23 PM
The pump would not care what bike the tank came off of, so long as the petcock is open, there is enough fuel in the tank, the tank is higher than the pump inlet, the hose size is adequate and not kinked, the tank is properly vented, and the filter is not plugged.
#6
Posted 28 February 2012 - 03:45 PM
#7
Posted 28 February 2012 - 07:42 PM
#8
Posted 31 March 2012 - 11:53 PM
Also tagged with one or more of these keywords: fuel pump, gravity fuel tank, rc30 conversion
Enthusiast Discussion →
VFR Models →
Fifth Generation VFR's →
Fuel Pump Not Energizing After Horn Event. Relay Not ClickingStarted by MaxSwell, 29 Apr 2013 |
VFR Models →
Third and Fourth Generation VFR's →
Installing Facet Fuel Pump On '95 - Looking For Tips & PicsStarted by kayaktom, 26 Dec 2012 |
VFR Models →
Fork options for RC30 replica projectStarted by seansparkle, 22 Feb 2012 |
Rules
