Fork options for RC30 replica project
#1
Posted 22 February 2012 - 08:23 AM
I'm new to the forum and although I've been looking round this site for months getting lots of useful info I've just started posting!
I'm starting a 1996 VFR750FT to RC30 replica project (I will be starting a thread when I have everything ready to go with lots of photos), I need answers to a few questions which I will post in separate threads.
First of all, forks.
I want my handlebars to look similar to the RC30, the clip ons sit under the yoke, the VFR has clip ons which sit above the yoke.
Looking at the service manual the 4th gen forks sit 39mm above the top of the yoke (with the clip ons fitted to this part of the fork).
I can easily get hold of clip ons which would sit under the yoke, but would be left with 39mm protruding, I was thinking of simply lowering the forks so the tops were virtually flush with the yoke top, but pretty sure this would make handling radically different (sharper from what i can work out) and also raise the height of the front of the bike.
Has anyone got a solution to this, or could comment on what lowering the forks by this much would do?
I'm thinking a different set of forks (F4i, VTR etc) may help, but to be honest I'm quite happy with the forks as they are.
Any help would be greatly appreciated!
Sean
#2
Posted 22 February 2012 - 10:44 AM
This would be a very bad thing.
Are you planning on staying with conventional forks, same type as the RC30?
If so, try CBR900 FireBlade forks. Measure them for overall length and go from there.
Of course, you will need both yokes and everything, as they have 45mm diameter tubes, whereas the VFR has 41mm.
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle’s handling, stability and braking, making it unsafe to ride.
#3
Posted 22 February 2012 - 10:51 AM
#4
Posted 22 February 2012 - 01:54 PM
To be honest I like the VFR standard brakes as they match my style of riding (i.e. slow!) and look like RC30 ones.
So in summary, and to ask a daft question, becasue I can't seem to get my head around this rake and trail concept, I would be looking for some forks that are about 40mm shorter than standard VFR ones?
I've heard that changing the height of the forks (and I get it now raising them above the yoke!) by 10mm makes a massive improvement in steering, so by that basis I'm looking for ones 30mm shorter.
Edited by seansparkle, 22 February 2012 - 02:22 PM.
#5
Posted 24 February 2012 - 02:40 AM
I've had a good search around the web, I found this company in the UK who specialise in fork Stanchions: http://www.bits4moto...fork-tubes.html
I found that the stock VFR750FT (4th gen) 41mm dia stanchions are 628mm long, so by my reckoning, 41mm forks 590-600mm would work out right.
I searched through their site looking for something that would work and came across CB600F (599 in the US) forks are 598mm, CBR400RR Triarm forks are 600mm.
So if I got a set of these stancions, would they swap straight over for the VFRs?
Would I use the VFR fork spring or the CB600f one?
Can anyone help?
#6
Posted 24 February 2012 - 03:10 AM
I would seriously look for the 900 FireBlade forks and measure them up.
At 45mm, they are sturdier than the 41mm VFR forks, and the brake mounts mean you can use CBR600F4i calipers, RC51 calipers, etc, which are 4-pot fixed calipers as opposed to the VFR style 2-pot sliding calipers.
#7
Posted 25 February 2012 - 05:56 AM
The rake/trail was spot on. Coupled with an aftermarket rear shock the handling was always inviting more.
The brakes - in silver are same as SP1 units am informed.
Should be the easiest option buying a complete front end and put it straight in.. no messing with tubes or anything....
The 98/99 front end was Hondas' pinnacle of right way round design and works very well. Better than a poorly set up upside down front end with yokes which are not always ideal in the rake/trail dept..
#8
Posted 25 February 2012 - 08:04 AM
One of the best ever vfr rides i have had used the CBR 900 98/99 forks and yokes with a 17" wheel in front...
Thanks,
So could you clarify what i would need for the conversion?
As I see it, Top and bottom yokes, forks, would the existing 17inch VFR wheel, axle, spacers, discs etc work with it?
Also just for interest would the existing vfr brakes fit?
#9
Posted 25 February 2012 - 08:20 AM
If i remember correctly your VFR wheel is ideal for the conversion. You may have to make up some spacers for front wheel to suit.(may be able to alter existing ones?) You may also want to change the bearing sizes to match axle sizes i dont recall.
...altho i used a VTR/blackbird wheel(had to mill discs 1mm) when i did a 98/99cbr front end change.
Going to clip ons will cause you problems with your fairing clearance(unless you find bars that will fit) and your oil cooler may way moving/altering.
#10
Posted 25 February 2012 - 08:34 AM
I don't know the free length off the top of my head, but I could measure mine for you later today. I have multiple top yokes littered about my shop - oem, LSL/Spiegler billet, and my own custom billet versions. Unfortunately, no oem lowers, but let me know if you decide to go this route I can help you out with some of the parts.
Sebastian Live to mod, mod to live... the best you know is the best you've ridden... adventures suck when you're having them...
2005 VFR800 - Winning Red -- 1996 VFR750 - secret project -- 1995 XR250R - little beasty
1983 VF750F - hot rod resto -- 1981 CB900F - hot rod build/resto -- 1976 BMW R60/6
-- 1996 XR400R -- 2000 XR70R -- 2003 CRF150F
Gone but not forgotten - 01 F4i - 84 VF500F - 02 954 - 96 VFR750F![]()
Also tagged with one or more of these keywords: rc30 conversion, forks
General Information →
Official Welcome Forum →
Fork Socket Bolt Not TighteningStarted by caferider, 20 May 2013 |
Enthusiast Discussion →
VFR Models →
Third and Fourth Generation VFR's →
Fork Refinishing On 4Th Gen.Started by bobbyn, 01 Jan 2013 |
VFR Models →
R1 Suspension Upgrade For Christmas! (W/ Pics)Started by smackdoogle, 23 Dec 2012 |
VFR Models →
91 Vfr Fork SwapStarted by oisface, 04 Nov 2012 |
VFR TECH →
Motorcycle Maintenance →
Suspension →
R/R forks for upgrade - How to?Started by 2thdr, 25 Oct 2012 |
Rules
