Has anyone fixed the grabby clutch for sure?
vfr grab grabby clutch
  • Please log in to reply
21 replies to this topic
#1 thenewwazoo
thenewwazoo
    Sport Tourer
  • Members
  • 6 posts
  • Why VFRD?:Because I have a VFR and need to know things. Also to ask things and answer things.
  • In My Garage::'00 VFR
Posted 12 October 2011 - 10:31 PM
I've done some reading, and it appears that I'm not alone in suffering from the awful >3500 RPM clutch grab/cough.
Has anyone permanently fixed it? How did you do so? I'm contemplating a complete Barnett clutch kit soon as I just can't live with it - I'm afraid I'm going to get asspacked by a cager some day pulling too slowly off a light!
#2 enzed_viffer
enzed_viffer
    Crazy Blue Cakemixer-o-cycle
  • Volunteer
  • 4247 posts
  • Why VFRD?:Coz
  • In My Garage::VFR800Fi1 (in blue, of course!);
    Some other people's cars;
    Junk and mess;
    More junk.
Posted 12 October 2011 - 11:17 PM
Mine seems to have come right by itself; certainly, I can take off fairly aggressively without the nonsensical behaviour I used to get.
#3 kaldek
kaldek
    Impatient bugger
  • Forum Contributor
  • 2780 posts
  • Why VFRD?:Even though I sold my VFR and am now a BMW owner, I love this forum like a family.
  • In My Garage::2012 BMW K1300R
Posted 12 October 2011 - 11:36 PM
I had a grabby clutch, which was fixed by replacing the clutch plates and springs. However that was on my old motor and the new (35,000km) motor I've got in it now also has the dreaded grabby clutch. Grrr.
BMW K1300R is my new girlfriend.
#4 Vee-Ef-Ar
Vee-Ef-Ar
    All aboard!!
  • Forum Contributor
  • 1014 posts
  • In My Garage::Ninety Eight - NH-118M-U
Posted 12 October 2011 - 11:48 PM
I know what you mean... I'm hoping a new chain, bleed, possibly new cush's and a 45T will help before I contemplate the clutch.
Sometimes I hurt it :sad:
Posted Image
#5 hotshoerob
hotshoerob
    Local Racer
  • Forum Contributor
  • 68 posts
  • Why VFRD?:The Best VFR forum
  • In My Garage::'00 VFR 800
    '73 Norton 750 Commando
    '89 Yamaha TDR 250
    '74 Montesa Cota 247
Posted 13 October 2011 - 01:03 AM
My '00 used to be the same way and I thought the same, it was time for a new clutch.
Best place to start is to clean the slave cylinder. That's where my problem was.
Remove, dissassemble, clean thoroughly, reassemble - preferrably with brake grease, bleed.
Now mine is smooth as butter.
It's cheap and not hard to do.
"If you find yourself in a hole, the first thing to do is stop diggin'."
#6 Jakobi
Jakobi
    Factory Team Rider
  • Forum Contributor
  • 172 posts
  • In My Garage::'78 CX500, '84 VF500F, '98 VFR800
Posted 13 October 2011 - 01:15 AM
I'm not familiar with this problem?
-Jake
"Flying is easy, all you have to do is throw yourself at the ground and miss."
-Douglas Adams
#7 Veefer800Canuck
Veefer800Canuck
    FrankenOwner
  • Forum Moderator
  • 11520 posts
  • Why VFRD?:I have the V-4 disease and there is no known cure except for copious applications of Throttle!
  • In My Garage::2010 Honda GL800RR-SP2
    Back in business baby!
Posted 13 October 2011 - 01:39 AM
11 years and 80,000 km and I've never had an issue?
I changed the clutch a couple thousand K's ago, just because I would have the cover off, and doing the clear cover mod, and the clutch still works fine.
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle’s handling, stability and braking, making it unsafe to ride.
#8 Gbam
Gbam
    Factory Team Rider
  • Members
  • PipPipPip
  • 147 posts
  • Why VFRD?:Just bought a 96 and want to know more about the bikes!
  • In My Garage::1996 VFR750 (Black)
Posted 13 October 2011 - 05:56 AM
I haven't heard of this either, although, I have a 4th Gen. Luckily I don't have to worry about the dreaded clutch grab... Just electrical fires. :tongue:
#9 KPerham
KPerham
    KevCarver
  • Forum Contributor
  • 3719 posts
  • Why VFRD?:Cause BaileyRock said so!
  • In My Garage::'99 VFR, '01 RC51, '03 ST1300, '02 Dakota
Posted 13 October 2011 - 05:59 AM
I too am unfamiliar. I'm at over 72,000 on my '99 and never had an issue... (Never even removed the clutch cover)
I keep my lever pivots greased, my hydraulic cylinders clean, and my fluid clear (Not brown!). Just switched over to an SP1 clutch master with my front end rebuild, and it's even better than the stock VFR was.
Cheapest thing to try is flushing the fluid, maybe even pull the slave cylinder and clean the bore and seal, make sure the pushrod is clean and straight. Take off the lever and clean the pivot and where the lever pushes the master cylinder and lightly grease them.
Kevin
#10 thenewwazoo
thenewwazoo
    Sport Tourer
  • Members
  • 6 posts
Posted 13 October 2011 - 10:37 AM
Glad to hear that some people haven't had it, but I do... and if you've ever had it, you'll know that it's not a question of maintenance. But thanks for the input.
kaldek, did you use factory Honda parts or aftermarket?
swallowtailed
swallowtailed
swallowtailed
swallowtailed
