Crossrunner - First ride impression
35 replies to this topic
#31 Noddy
Noddy
    Club Racer
  • Forum Contributor
  • 44 posts
  • Why VFRD?:I love the ride reports
  • In My Garage::VFR1200FD-A
    KTM990SM
    VFR800 Vtec (6th Gen)
    CB900F2D (1983)
Posted 29 May 2011 - 04:53 AM
The write up in the UK's MCN was a bit indifferent, and you can see why. Just an upright seating position with less power, spoilt by peg position.
Yet a friend of mine had a test ride on one yesterday and quite liked it, although he baulked at the 9 grand asking price. He also test rode a CB1000R and couldn't get on with it. And he's 6'4" tall.
So, don't knock it until you've tried it, but I suspect the Market for this bike is not existing VFR owners....
#32 timmythecop
timmythecop
    Deported to Maryland, Says he's not from there!
  • Volunteer
  • 6907 posts
  • Why VFRD?:because I have no real friends
  • In My Garage::VFR 800, VF500R, Seca2, GS850G, CB400T
Posted 17 June 2011 - 01:57 AM
I may be able to help later on this summer. The Crossrunner is one of my finalists of "what bike to rent" when I go to the Eifel Forrest in July. If so, full write-up.
Money will be an issue and the Crossrunner is 350 euros for a week.
On a different note, this thing is also on the list and I dont know why. It intriques me...........
Posted Image
Can I convince you to paint it flat black?
Just when we thought the Early VFR section was safe...
Catskills03.jpggallery_491_6304_1140.jpgtmac2010-1.pngTMac11Icon-1.jpgaahb200-1.jpg678973a4.jpggallery_491_6304_1801.png
#33 carlitos92
carlitos92
    Captain of the SS WunderBear
  • Forum Contributor
  • 594 posts
  • Why VFRD?:I'm Good Enough, I'm Smart Enough, and Doggone It, People Like Me!
  • In My Garage::2007 VFR800A
Posted 17 June 2011 - 05:29 AM
Is that a CBF600?
If it's the same bike I'm thinking of, I've heard it's somewhat anemic and not at all what you would expect from a 600 naked. Depending on your intention whilst in the EU, it may be just the ticket, but you might have more fun on one of these, since it has 25 more horses:
Posted Image
Personally, I think the Hornet's uglier, but OTOH it might be easier to find one of them vs. the CBF. :happy:
2007 VFR800A (25th Anniversary Edition w/ ABS)
2006 CB600F (Sold 08/2009)
#34 Ivvan
Ivvan
    New Member
  • Forum Contributor
  • 4 posts
  • Why VFRD?:Tech info, exchange of ideas (tweaking, tuning etc)
  • In My Garage::VFR800 04, Yamaha TT-R 250, Suzuki DR-Z 250
Posted 19 June 2011 - 05:43 PM
Hmmm, surely reworked header pipes and intake trumpets also means different camshaft profiles and also less top end power...
It will be interesting to see how all this pans out because it really could mean that folks are dropping for the Crossrunner ECU and other mods!!
My ride is VTEC 2004 japanese spec, derestricted.
For those of you who do not know, according to Japanese regulations all vehicles are restricted in max. speed (180km/h) and max.power.
For example, 1000cc bikes are limited to 100hp, 400cc - to 53hp. VFR800 comes limitied to 80hp.
However Honda does not give up, and in order to please their customers they add some extra meat to their bikes in low and mid range. (probably other makers do the same).
Following parts have to be replaced if you want your jap spec VTEC to get its ponies back:
-intake trumpets (!!!) original are smaller diameter and longer then export spec (sounds familiar, isn't it?).
-different muffler
-spark plugs (they have to be colder type)
-some air box mods
-some fiddling with ECU wiring
As a result you will get 103hp at slightly lower revs, and yet there is more torque in mid range than export spec has. I saw graphs comparing derestricted jap spec with export spec. So obviously camshafts are different!!!
Almost forgot - VTEC cuts in at sweet 6400RPM!!!
Does not it all sound, that Honda had that Crossrunner engine developed long ago! But for whatever reason (probably less max power) did not use it for any exported bikes.
I could not complain about VTEC transition from the very beggining. However poor throttle control at low revs almost forced me to sell it last summer. I used to own GSX-R1000 K1 and it was much smoother and powerfull at low range (not comparing these two bikes, mind you)
Thanks to this site, I installed PCV and.... here it comes - VFR nirvana.
Cozy's map was not the best though, probably due to different cams and VTEC transition. After a lot of experimenting and fiddling with maps, found that the best one is Dynojet's M111-506.
So, is my bike is the best 6thgen VFR available or what?!?!
#35 VFRSuperfreak
VFRSuperfreak
    World Superbike Racer
  • Members
  • PipPipPipPip
  • 442 posts
  • In My Garage::96 VFR
Posted 19 June 2011 - 08:46 PM
...As a result you will get 103hp at slightly lower revs, and yet there is more torque in mid range than export spec has. I saw graphs comparing derestricted jap spec with export spec. So obviously camshafts are different!!!
...Cozy's map was not the best though, probably due to different cams and VTEC transition. After a lot of experimenting and fiddling with maps, found that the best one is Dynojet's M111-506.
Umm, So you lost the power dip at 6-7k rpm? Got torque spilled all over the lower RPMS now?
-This means maybe you now have a 4.5 Gen, or 5.1 depending...
For full effect get a full-on, analog 4th gen their 8 valves kick in when you turn the key. :biggrin: :fing02:
#36 Ivvan
Ivvan
    New Member
  • Forum Contributor
  • 4 posts
Posted 19 June 2011 - 09:54 PM
Do not forget, that my "5.1" runs in nice 6th gen chassis
Reply to this topic
swallowtailed
swallowtailed
swallowtailed
swallowtailed
