VFR Discussion: Chicken Stripes - VFR Discussion
  • (2 Pages)
  • 1
  • 2
  • You cannot start a new topic
  • You cannot reply to this topic
Chicken Stripes
#1 User is offline   Pete McCrary
  • Sophisticated Hillbilly
  • View blog
  • Group: Forum Contributor
  • In My Garage::2004 Honda ST1300
    2002 Honda Interceptor
    2001 KTM Duke II
    1996 Yamaha V-Max
Thank You's: 15
Good
Posted 05 June 2009 - 02:55 PM
Can anyone offer me a logical explanation as to why the chicken stripes on a bike are always wider on the front tire than the rear tire?
What is the relationship (or is there one) between chicken stripe width and proper set-up of a bike?
0
#2 User is offline   Beck
  • Race Team Owner
  • PipPipPipPipPipPip
  • Group: Members
Thank You's: 2
Neutral
Posted 05 June 2009 - 03:01 PM
Uhmmm... I dunno....effects of countersteering???
Beck
95 VFR
0
#3 User is offline   5thGenJim
  • I'm not an Achmed anymore!!!!
  • In My Garage::5th Gen, 2Bro's slip-on, Corbin, Givi E360 & E45NJ, genmar risers, progressive shock.
  • Signed Flaf:
Thank You's: 0
Neutral
Posted 05 June 2009 - 03:05 PM
Beck
95 VFR
I'm pretty sure it has to do with the size and shape differences between the two tires. The rear is typically shaped in such a way that, when you get into your lean, you'll reach the edge much quicker than you will on your front. A 180 rear is more "U" shaped, while a 120 front is shaped more like half a tennis ball. My best guess...
This post has been edited by 5thGenAchmed: 05 June 2009 - 03:14 PM
"We are what we repeatedly do, excellence then is not an act, but a habit."
Posted Image Posted Image
0
#4 User is offline   sckego
  • Doesn't like crashing
  • View blog
  • View gallery
  • In My Garage::'04 VFR800, '89 VTR250
  • Signed Flaf:
Thank You's: 3
Neutral
Posted 05 June 2009 - 03:22 PM
Chicken strips come off through a combination of lean + pressure on the tire. On the rear tire, this happens while getting on the gas coming out of a corner... a fairly common occurance for most riders. The lean, combined with the tire getting further 'squished' due to the weight transfer to the rear, can force the tire down to it's edge or beyond. Scrubbing the strips off of the front, on the other hand, mean that you need weight on the front while leaned over, which is what you get while trail-braking deep into a corner... not so common for alot of riders, which is why most have much larger strips on the front then the rear.
At my most recent trackday this past weekend, I was getting more comfortable with trail-braking almost up to the apex of a few corners. By the end of the day, both my front and rear tires had about 1/8" of chicken strip left...
Posted Image
Kegan - IBA #41999
'04 VFR - 75k Miles & zero valve adjustments - Sargent - Helibars - Gutted - Catless '99s - PCIII - Evo Shift Star - Sonic Springs & Racetech Valves - Wilbers Shock - Scottoiler - ScalaRider Q2 - Givi E460 - O2 elim'd - Datel Voltmeter - Custom Roadrash (LH only) -
0
#5 User is offline   Yosh70
  • Factory Team Rider
  • PipPipPip
  • View blog
  • Group: Members
  • In My Garage::2002 VFR
Thank You's: 0
Neutral
Posted 05 June 2009 - 03:32 PM
These are on a bike? :huh:
Posted Image
This post has been edited by Yosh70: 05 June 2009 - 03:32 PM
Sargent, Micron's and Pazzo's, oh my!
0
#6 User is offline   HispanicSlammer
  • Veefalo!
  • View blog
  • View gallery
  • Group: Forum CEO
  • In My Garage::2010 VFR1200F
    2001 XR650R
  • Signed Flaf:
Thank You's: 39
Excellent
Posted 05 June 2009 - 03:40 PM
Posted Image
That makes sense, I usually completely remove anything on my rear - however I will have 3/4 to 1/2 inch left on my front tire. I usually dont trail brake ever, preferring to brake before the turn the powering trough as I reach the turn. I also have a habit of dragging the rear brake on very tight turns so that probaly makes the it worse.
Webmaster :: vfrdiscussion.com :: admin@vfrdiscussion.com
VFRD Rallys
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
"May The Road Rise To Meet You"
Miguel Mayo
0
#7 User is offline   turtlecreek
  • Ham Fisted Fat Bastage
  • View gallery
  • In My Garage::Silver 2003 VFR
    2005 Sir Squidly Gixxer 750 Track Bike
    Gone: 1997 YZF600r, 2005 Yamaha Roadstar
Thank You's: 5
Neutral
Posted 05 June 2009 - 04:15 PM
Posted Image
+1 first time in my life, my front had NO strips and the rear had a small one on my track bike....definitely trail braking and the rear was the wrong size/pressure, causing it to fold improperly on the rear. on the VFr, i almost never trail brake and i have 1/2+ on the front.
thanks for explaining that.
I learned a long time ago, best way to realize the danger of your pace is when it goes from that speed to zero really abruptly.......mighta' been faster than I thought......Skuuter Posted Image
"Courage is almost a contradiction in terms. It means a strong desire to live taking the form of a readiness to die. 'He that will lose his life, the same shall save it' is not a piece of mysticism for saints and heroes. You must seek life in a spirit of furious indifference to it; you must desire life like water and yet drink death like wine." GK Chesterton
MODS: Givi Windscreen Factory Windscreen due to Dragon Bite, Sargent Seat, Headlight Modulator, Heli Bars, Padded Grips, PCIII USB, 30 Amp Fuse Upgrade, Fender Eliminator, Evap Canister Removed, PAIR Valve Removed, Flapper Mod, De-Snorkled, O2 Sensor Removed/Plugged, BLS Footpeg Mod, .95 Racetech Springs and Ohlin Valves, F4 Shock Rebuilt/Resprung to 950lb for Fat Arse, '99 Catless Headers, 15T Front Sprocket, Vecky5 Gutted Exhaust, Riv's Hugger, 12v meter, VFRharness w/ relay block, Speedohealer
0
#8 User is offline   Pete McCrary
  • View blog
    2001 KTM Duke II
    1996 Yamaha V-Max
Thank You's: 15
Good
Posted 05 June 2009 - 04:42 PM
I'm wondering if it has more to do with the aspect ratio of the tires (i.e., the cross section).
The rear tire on a VFR is a 180/55 while the front is a 120/70. Perhaps if both tires were /55 or /70 in aspect ratio the stripes would be the same. The rear, being a /55, is actually "flatter shaped" than the front tire.
The reason this topic interests me so much, is that I had a "track day rider/racer" tell me that if you have more chicken stripes on the front than you do the rear, it means you need to jack the rear of the bike up. Well I did that on my KTM. Problem is my riding style is to really crank it over quick entering a turn (Keith Code style). I had several instances where the rear stepped out on me when I flicked it over quick and hard. However, my chicken stripes at the end of the day were all the way to the edge front and rear.
0
#9 User is offline   SEBSPEED
  • float like a goldwing, sting like a gixxer
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::Mini Honda dealership
  • Signed Flaf:
Thank You's: 48
Excellent
Posted 05 June 2009 - 05:34 PM
Tires can tell you a lot. For example, if you don't have any strips on the back, but have quite a bit on the front, your ride height is probably off. To fix that, you raise the rear. (provided sag is set, tires are at correct pressure, etc)
They shouldn't be perfectly even, you want an 1/8 to a 1/4 inch on the front when the rear is to the edge. (for up to say, 8/10ths riding pace)
That's my 2 cents, based on what I've read and heard. I'm no expert though!
Sebastian - **Yankee Railer**
1983 VF750F 2,997 original miles, undergoing full hot-rod restoration- K&N, Accel coils & wires, Megacycle Stage 1 cams, jetted, Works shock, CBR F2 wheels, VF1000R forks, RaceTech Gold Valve Emulators, Sonic 1.0 springs, Chevy S-10 'clear' headlight, fender chop, Maier dark smoke screen, Vance and Hines full 2-2 system, 96 VFR clip ons, much more in the works!
1986 VFR700F 900RR forks w/ Racetech .90's, CBR F3 front wheel, 900RR rear wheel, PARTING OUT - PM FOR PARTS INQUIRIES
198x VF500F GONE
1996 VFR750 frame and swingarm, possible track bike?
1996 VFR750 secret project...
1996 VFR750 31k miles, K&N, otherwise stock - SOLD
2001 CBR600F4i GONE
2005 VFR800 Sargent seat, NEP throttle lock, Symtec heated grips, Powerlet, DIY fender eliminator, oem hard bags, modded passenger pegs, Garmin Nuvi 750, Ohlins 46DRS, .90 RaceTech fork springs, Staintunes, Rivcyko double secret probation CF hugger, CF Bug Buster, UNI filter mod, PC3 USB w/ Cozye's map, Speed Bleeders, ATE Super Blue brake fluid, coming soon - RaceTech Gold Valves, catless headers, VFRness &...
***Bailey-san sez, zip-tie a rim protector to your HF bar on your HF changer to keep from scratcha rim***
Posted Image Posted Image Posted ImagePosted Image Posted Image
0
#10 User is offline   Bent
  • Race Team Owner
  • In My Garage::2006 VFR, LeMond Buenos Aires, et al.
  • Signed Flaf:
Thank You's: 8
Neutral
Posted 05 June 2009 - 05:59 PM
Posted Image
Dale, if you would lose some weight, you might have some chicken strips. You still using six ply tires?? :laugh: :laugh:
The smart ass is back..... :ph34r: :beer:
Posted ImagePosted ImagePosted Image
"If you can't have fun, don't show up."
~Bent 2001
"Where ever I go, fun follows me"
~R. Rowan
"Beware of the Shark Knife"
"If you think you're in a bind, you're in a bind"
~Bent 2010
0
#11 User is offline   Pete McCrary
  • View blog
    2001 KTM Duke II
    1996 Yamaha V-Max
Thank You's: 15
Good
Posted 05 June 2009 - 10:44 PM
But everyone on this site thinks you are! :biggrin:
0
#12 User is offline   BusyLittleShop
  • Have a Wheelie Nice Day
  • View gallery
  • In My Garage::HONDA RC45 RC30...
  • Signed Flaf:
Thank You's: 14
Good
Posted 06 June 2009 - 12:30 AM
A question was raised on what creates disparity of wear
between the front and rear...
I drafted a scale drawing of a set of tires to find the answer...
A... shows a 120 / 70 / 17...
B... shows a 190 / 50 / 17...
C... shows the disparity between the front and rear...
I believe tire disparity exist because the front's edge rest above the
ground higher than the rear's edge... As you can see as both edges are
leaned towards the asphalt... rear edge (B) will be first to kiss the
asphalt before the front edge (A)... the amount of disparity is
represented by ( C )...
So... if your rear tire is worn to the edge but the front shows a small
chicken strip??? it's ( C ) tire disparity... To erase that last bit of chicken
strip go to a race track... it's too hair ball on the street...
Posted Image
Larry L
94 RC45 #2
90 RC30 #44
VFR PEG LOWERING BLOCKS
http://www.vfrdiscus...showtopic=44940
Have a wheelie NICE day...
Lean & Mean it in every corner of your life...
If it wasn't for us the fast lane would rust...
V4'S are music to the seat of my pants...
1952 De Havilland Chipmunk...
Yank and bank your brains loose...
http://members.ebay....aboutme/-xlax-/
http://home.comcast.net/~netters2/
http://www.fox302.co...g&user=netters2
http://www.flickr.co...s/10503451@N07/
Busy Little Shop Photo Gallery
0
#13 User is offline   dendron
  • Moto Grand Prix Racer
  • PipPipPipPipPip
  • View gallery
  • Group: Members
  • Location:Jacksonville, FL the ‘Anti-Dragon’, 9 curves in 874.3 sq. miles, not counting the cloverleafs.
  • In My Garage::'02 VFR800, '05 Acura RSX-S, 21-speed Mongoose mountain bike, (6) shovels, (3) rakes.
Thank You's: 2
Neutral
Posted 06 June 2009 - 01:09 AM
Uh, dude, you just aint leanin' that sucker enough...wheeee!
~ d ~
Mods so far: Staintunes, PCIII, K&N, O2 eliminator, Ohlins 46 DRS, custom fender eliminator, OEM fork gutted & rebuilt by Race Tech, de-PAIRed, de-snorkled, de-flappered, Puig light smoke DB windscreen, NEP throttle lock, Bridgestone BT-016's (freakin' awesome!).
"I know you'll ride responsibly, you always do. It's the bastards out there
that will get you if you're not careful."
- my Mom -
~This site is protected by various provisions of Title 18, U.S. Code. Safety goggles may be required during use. Sanitized for your protection. Sealed for your protection, do not use if the safety seal is broken. If a copyright is indicated on a photo, graphic, or any other material, permission to copy these materials must be obtained from the original source. See label for sequence. Shading within a garment may occur. Sign here without admitting guilt. Simulated picture. Ribbed for your pleasure. Please pick up after your pet.
For site security purposes and to ensure that this service remains available to all users, we employ software programs to monitor traffic to identify unauthorized attempts to upload or change information, or otherwise cause damage. In the event of authorized law enforcement investigations, and pursuant to any required legal process, information from these sources may be used to help identify an individual. Slightly enlarged to show detail. Slightly higher west of the Rockies. Slippery when wet. Falling rocks. Smoking these may be hazardous to your health.~
0
#14 User is offline   RIDER_44
  • Privateer
  • PipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::1995 VFR 750F
Thank You's: 0
Neutral
Posted 06 June 2009 - 01:12 AM
Posted Image
Great diagram. I always enjoy your provided visual stimulation. You certainly have more time on your hands than you need. :biggrin::) I do agree with it but, the tire is not always in a continuos static state, flex in the tires occur and is created from the momentum and forces of transferred weight either by applying the brakes before or into a corner and out of a corner the tire will load/release and flex to cope with these forces, not to mention the difference in width and height of the tire selections, air pressure, compound, suspension, etc. Though that is probably the correct way to describe this effect with the majority of the VFR riders, due to the fact that they are not even close to being as aggressive on the street as they would be a track and that is a good thing. I will also have to concur that, playing on the edge is for the track...not the street.
0
#15 User is offline   dendron
  • PipPipPipPipPip
  • View gallery
  • Group: Members
Thank You's: 2
Neutral
Posted 06 June 2009 - 01:27 AM
Posted Image
My God, that was technical...yet, I'm still playing for the edge, track or not
~ d ~
- my Mom -
0
#16 User is offline   ccnaylor
  • Chris
  • View blog
  • View gallery
  • In My Garage::2002 Honda VFR800, 1983 Honda Nighthawk 650SC (not for long)
Thank You's: 0
Neutral
Posted 06 June 2009 - 02:42 AM
Threads like these are why I love this forum! Lots of smart people :comp13:
For the first time, on any bike, my rear only has 1/4 inch showing on the edge (I've been pushing myself this year to ride better and harder so I improve).
:lurk:
VFRoom-VFRoom...
Somebody remind me to check my air pressure...
0
#17 User is offline   BusyLittleShop
  • View gallery
  • Signed Flaf:
Thank You's: 14
Good
Posted 06 June 2009 - 03:06 AM
I don't play for edge on the street... it just happens on Mr.RC45...
All street miles... no track...
Posted Image
Posted Image
Larry L
94 RC45 #2
90 RC30 #44
0
#18 User is offline   turtlecreek
  • View gallery
Thank You's: 5
Neutral
Posted 06 June 2009 - 05:58 AM
Posted Image
first how am i going to lose weigt if i keep having chicken strips? second, i might try some, except evertime i go to bea's with you, you clean the chicken plate before it ever gets around to me! :laugh: welcome back!! :biggrin:
0
#19 User is offline   SEBSPEED
  • View blog
  • View gallery
  • Group: Volunteer
  • Signed Flaf:
Thank You's: 48
Excellent
Posted 06 June 2009 - 06:58 PM
Welcome back Jim!! We've missed ya! (I have anyway)
For the first time ever, I have zero strips front or rear. It took a trip down NC28 to take care of that! I am loving the PP/PR2 combo!
198x VF500F GONE
2001 CBR600F4i GONE
0
#20 User is offline   Bent
  • Race Team Owner
  • Signed Flaf:
Thank You's: 8
Neutral
Posted 08 June 2009 - 09:48 AM
Ya gotta point there, Dale. I heard Bea's is near Chapter 11 because we haven't been there in too long. We need to go help them out!
Seb, Hwy. 28 is a blast but you're supposed to have a little bit of strip on the front. Those rock banks are hard! Those Hogs on the way to The Gap must be pushing you up 28 at a high rate of speed..... :laugh:
~Bent 2001
~R. Rowan
~Bent 2010
0
#21 User is offline   SEBSPEED
  • View blog
  • View gallery
  • Group: Volunteer
  • Signed Flaf:
Thank You's: 48
Excellent
Posted 08 June 2009 - 10:12 AM
Hey, don't talk about Bailey like that, he might ban ya!! :ph34r: :biggrin:
198x VF500F GONE
2001 CBR600F4i GONE
0
#22 User is offline   Pete McCrary
  • View blog
    2001 KTM Duke II
    1996 Yamaha V-Max
Thank You's: 15
Good
Posted 08 June 2009 - 10:44 AM
Posted Image
Excellent explanation and drawing.
No sarcasm intended, I didn't know anyone knew how to draw by hand anymore except myself (I'm real old school, literally). We've got this little program here at work called AutoCad.
0
#23 User is offline   Pete McCrary
  • View blog
    2001 KTM Duke II
    1996 Yamaha V-Max
Thank You's: 15
Good
Posted 08 June 2009 - 10:46 AM
Posted Image
Posted Image
Same with me on my Duke II.
0
#24 User is offline   Buttonhook
  • PipPipPip
  • View blog
  • Group: Members
  • In My Garage::07 rwb abs interceptor
    07 650R ninja (just sold)
    09 250r ninja
    82 Suzuki GS300LZ
Thank You's: 0
Neutral
Posted 08 June 2009 - 11:24 AM
Posted Image
Me too,
for small stuff sometimes it's still faster to draw by hand
However I have been teaching alot of invertor lately
This post has been edited by Buttonhook: 08 June 2009 - 11:27 AM
this is my like new 1982 gs300l and my former 650r ninja w/reflective ghost flames
0
#25 User is offline   TimC
  • Lead Trumpet
  • View gallery
  • Signed Flaf:
Thank You's: 7
Neutral
Posted 08 June 2009 - 11:53 AM
I'm no engineer, but I would think heat play a role in this, too. The rear tire, with more weight on it plus friction from accelerating on the pavement, would tend to flatten out a bit more than the front. As we've seen from the diagram above (nice work BTW!) there's a much larger contact patch with the rear tire to begin with. Add weight and friction to the larger contact patch and the rear tire probably more easily loses it's cold/rounded shape than does the front tire.
Also, I'm wondering in the front and rear ends of the bike could be leaning at two different angles, with the front end a bit more upright than the rear. When you're countersteering, you're turning the front wheel in the opposite direction of the bike's travel. Think of a left-hander: If you're steering slightly right but the bike is moving to your left, the front tire's contact patch is actually more toward the center of the tread while the rear tire's contact patch is on the left side of the tire.
To illustrate, sit on your bike while stationary. Turn the bars to full lock one way or the other. The bike will lean over (probably in the opposite direction) and the rear tire will lean with it, while the front tire is mostly still on its centertread because the fork it's mounted on is pivoting, not leaning.
Thinking about that pivot idea, I'm guessing that the greater the fork rake and trail (and the longer the wheelbase), the less the front tire falls over while countersteering. If that's true, I'd also think that shorter wheelbase/quicker steering bikes like supermotards would show more front tire wear away from the centertread.
Does that make sense? :huh:
AMA Member 973972
"VFRs aren't dirtbikes." - tpierce(MP)
0
#26 User is offline   Pete McCrary
  • View blog
    2001 KTM Duke II
    1996 Yamaha V-Max
Thank You's: 15
Good
Posted 08 June 2009 - 12:06 PM
My Duke would lend support to that portion of your theory.
0
#27 User is offline   Pete McCrary
  • View blog
    2001 KTM Duke II
    1996 Yamaha V-Max
Thank You's: 15
Good
Posted 08 June 2009 - 12:18 PM
Speaking of tires, lean angles, etc- I am hearing more and more about Goldwing riders running small automotive tires on the rear of their bikes as opposed to motorcycle tires. Yikes!
Supposedly in search of the elusive 50,000 mile motorcycle tire.
0
#28 User is offline   sckego
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 3
Neutral
Posted 08 June 2009 - 01:14 PM
That one's been beaten to death; do a google search for "darkside riders." Some guys swear by it, others tell them they're crazy. Anyways, I'm enjoying this thread as is, let's not drag the darkside debate into it...
Kegan - IBA #41999
0
#29 User is offline   BusyLittleShop
  • View gallery
  • Signed Flaf:
Thank You's: 14
Good
Posted 08 June 2009 - 01:40 PM
An automotive tire is a mere rim protector on a motorcycle... before you can see 50K miles it will send
your ass in the giggle bushes...
Larry L
94 RC45 #2
90 RC30 #44
0
#30 User is offline   Bent
  • Race Team Owner
  • Signed Flaf:
Thank You's: 8
Neutral
Posted 08 June 2009 - 01:43 PM
I just assumed I was banned.... :laugh:
~Bent 2001
~R. Rowan
~Bent 2010
0
Share this topic:
  • (2 Pages)
  • 1
  • 2
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
