Installing Front Wheel
#1
Posted 22 May 2009 - 09:51 PM
Thanks.
Craig
#2
Posted 22 May 2009 - 10:20 PM
First off, you never need to remove the rotors for a tire install! Stop that!
Second there are small arrows on each rotor for direction ID and one arrow on one side of the wheel, you can use any light/med loctite you wish.
No worries!
PS Haynes manuals sux, you can download the Honda Factory manual right here in the download section of VFRD!
"If everything seems under control, your just not going fast enough" Mario Andretti
current bikes
02 VFR BLACK, 77,050 miles(no Valve check yet), SB-II exhaust , 15t, Penske w/20kg, AfterShocks forks w/.95 kg, V1, heated grips, Pilot Power front/ Road 2 rear, No surge or Vtec transition problems! Mobil 1 15w-50 or Shell Rotella T Syn., Buell pegs.
01 VFR (brother's) crashed
07 GSXR 750(SOLD!)
02 F4i Track Bike(GONE!)
93 Yamaha WR250(in a box)
04 VFR track pig project(fast & crashed)
#3
Posted 22 May 2009 - 10:56 PM
Many states and provinces left. I should probably order another set of tires...
#4
Posted 22 May 2009 - 11:35 PM
Peto, on May 22 2009, 09:56 PM, said:
Sure enough. Little arrows....doh! Thanks guys. The Haynes manual had me thinking I had to line up the bolt holes in the rotor and wheel exactly like they were before I removed them. If I reuse the original bolts, do I have to clean off the original locking compound? I tried some light scrubbing, but it won't come off.
Thanks for the downloading tip. The Honda service manual is a lot better.
Cheers.
#5
Posted 23 May 2009 - 03:33 PM
Cheers.
Clean bolts with a bench grinder wire wheel if you have one, if not use a wire brush, and when you put the rotor bolts back on be sure to torque to spec. ....... 2 reasons, so they won't come undone, and less chance of warping the rotor (use what ever colour locktight that was on the bolt when you took it off) ........ Monk
Riding defensively is a pro-active must. VFR MOD's : PuppyGrips;ThrottleBoss;NepThottlelock;LowCutBra;BubbleMirrors;HondaBags;GPS TomTomRider2ndEd(Powered,W/Tightwad'sPowerletSystem);SargentSeat w/silver piping;StockWindscreenW/LaminarLip;
3-M BlackReflectiveTape;FirstGearSilverMiniTankBag;GezaHalfCover;AxioSilverHardshellTailbag;
HeldSpeedySeatBag;KuryakynLEDBatteryGauge;TyresMichPR2's;NWS Hugger;RedWheelTape;RedRadiatorGrills;CustomWinterGripCovers;
#6
Posted 23 May 2009 - 03:48 PM
1983 VF750F 2,997 original miles, undergoing full hot-rod restoration- K&N, Accel coils & wires, Megacycle Stage 1 cams, jetted, Works shock, CBR F2 wheels, VF1000R forks, RaceTech Gold Valve Emulators, Sonic 1.0 springs, Chevy S-10 'clear' headlight, fender chop, Maier dark smoke screen, Vance and Hines full 2-2 system, 96 VFR clip ons, much more in the works!
1986 VFR700F 900RR forks w/ Racetech .90's, CBR F3 front wheel, 900RR rear wheel, PARTING OUT - PM FOR PARTS INQUIRIES
198x VF500F GONE
1996 VFR750 frame and swingarm, possible track bike?
1996 VFR750 secret project...
1996 VFR750 31k miles, K&N, otherwise stock - SOLD
2001 CBR600F4i GONE
2005 VFR800 Sargent seat, NEP throttle lock, Symtec heated grips, Powerlet, DIY fender eliminator, oem hard bags, modded passenger pegs, Garmin Nuvi 750, Ohlins 46DRS, .90 RaceTech fork springs, Staintunes, Rivcyko double secret probation CF hugger, CF Bug Buster, UNI filter mod, PC3 USB w/ Cozye's map, Speed Bleeders, ATE Super Blue brake fluid, coming soon - RaceTech Gold Valves, catless headers, VFRness &...
***Bailey-san sez, zip-tie a rim protector to your HF bar on your HF changer to keep from scratcha rim***
#7
Posted 24 May 2009 - 09:35 PM
SEBSPEED, on May 23 2009, 02:48 PM, said:
I used blue, it's all I could find, although the original bolts had red. The bolts are bloody expensive to buy brand new. The wire brush worked, but it did take a while.
Thanks again.
#8
Posted 03 June 2009 - 07:25 AM
Help
MultiQuote
