Coolant Smell Question.. Looking for relatively inexpensive debug options...
#1
Posted 11 May 2009 - 01:50 PM
2 Years ago I lowsided at the track, my bike did drip some coolant out of the overflow lines after being righted and pushed back to the garages.
I pulled all the bodywork off at the time and ended up replacing most of the right side controls & the right side plastic & front/upper cowl.
I did not see any damage to the radiators or hoses at the time...
However ever since then when the thermostat opens around 175F I will get a faint hint of coolant smell until the bike cools off and closes thermostat. (Obviously you can't smell this while riding)
It has been 2 years and I have not seen any appreciable drop in coolant level since then, I've never had to add coolant.
But the smell still drives me crazy. Call me anal but it gives me this odd feeling something is still wrong and someday the bike will let me down
because I didn't track this down.
I'm curious what I could try. I was thinking of getting a dealer to pressure test it, but I'm guessing that might cost a pretty penny.
Otherwise what could I do that is simple and wouldn't involve draining all the coolant or spending big money?
Only thing I saw in the search was maybe try replacing the radiator cap. (The bike fell on the right side, same side that has a cap)
Thanks,
Ben
#2
Posted 11 May 2009 - 01:53 PM
Cured me up, I had the same prob.
If not, check the weep hole on the waterpump, then the O-ring on the thermostat housing. Also, the coolant hoses flowing to the wax unit for the fast idle.
Rob McKinnon
'99 GL800RR-SP2
http://s13.photobuck...eefer800canuck/
Quote
Quote
#3
Posted 11 May 2009 - 01:58 PM
Or do you only get the smell?
I had a little leak in between the cylinders, after a thermostat change(which was not needed), I tightened it up and problem solved.
Did you have water in the system, or coolant at the track?
#4
Posted 11 May 2009 - 02:38 PM
#5
Posted 11 May 2009 - 02:44 PM
That is what mine did; it was a loose hose clamp under my throttle bodies. It seeped just enough, then evaporated, to create the smell, but not enough to drop my coolant level or show a leak anywhere on the bike or under it.
There are a number of possibilities for the small leak; here is a pic of mine, with the hoses off. You can see the dried coolant on the fitting. I just posted this pic on another leak thread here.
#6
Posted 11 May 2009 - 03:46 PM
I would be surprised if it was something inside the V of the engine, but who knows, my nose has really tried to convince me it's something up near the front of the bike. Could be wrong though. (I did look for it with all the plastic off once before)
Thanks for the advice!
#7
Posted 11 May 2009 - 04:19 PM
The heat from the engine rising wafts the smell up and to the front of the fuel tank and into the rider envelope behind the fairing.
I would smell the coolant on mine when I was slowing alsmost to a dead stop.
Turned out, just about every hose clamp on the bike needed snugging up.
Some of the ones in the center of the V were hard to reach, but I was able to get them with patience, did not have to remove the throttle bodies.
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
#8
Posted 11 May 2009 - 05:15 PM
#9
Posted 12 May 2009 - 12:20 AM
Thanks,
Ben
So replace the radiator cap and get back to us.
2002 VFR800A.
#10
Posted 12 May 2009 - 12:33 PM
Thanks,
Ben
Bring your bike's rad cap to the auto store and look for ones that fit Isuzus and Toyotas with the same pressure rating.
That's what I did. 5 years later, it's all good.
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
#11
Posted 10 May 2010 - 10:27 AM
I lived with this for the last year.. (didn't get to ride much)
I am starting to work on this again. (Got the plastics off, etc..)
I am curious since Veefer800Canuck mentions it.. what was involved in getting to the hose clamps in the Vee without taking the throttle bodies off?
Should I take the gas tank + airbox off and then try to reach through the spaces in the throttle body?
I'm 99% convinced it's something in the Vee now.
Borrowing from ChiAlex's thread, I have some coolant here:
Also, should I be draining the coolant before starting any of this?
I did have to add about 1 cup of coolant last week.
#12
Posted 12 May 2010 - 12:44 PM
Help
MultiQuote
