VFR Discussion: 190/55 Dunlop On A 94-97 Swingarm? Does It Fit? - VFR Discussion
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   cbrizzle
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
  • In My Garage::05 R6 race WSMC #551, 83 VF750F
Thank You's: 0
Neutral
Posted 25 April 2009 - 07:03 PM
Hey guys, here's the situation. I have a non-NTech Dunlop 209GP 190/55 rear tire take-off from my R6 race bike from a couple of years ago (many, if not most 600's run 190's on the rear when club and pro racing these days). Furthermore, the non-Ntech tire grows at speed, making any already big tire even bigger, which was why Dunlop came out with the Ntech 209GP's the next year. So I just finished installing a 94-97 VFR750 swingarm on my 98 900RR. Do you guys know whether the tire will clear the swingarm? I don't want to mount and balance the tire only to realize that it won't fit.
I know the 190/55 tire will fit my 5.5" 90-93 wheel. I also installed a 07 CBR600RR shock, which was about 5mm shorter than the 900RR shock. Coupled with the longer swingarm of the VFR, which increased my wheel base by at least 2 inches, I figure the 190/55 will help maintain the trail. Actually, the main reason is that I just have a rear tire with a lot of meet sitting around and I want to use it :laugh:
TIA!
0
#2 User is offline   Laurent91580
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
  • In My Garage::1994 vfr RC36-II 101000 kilometers (627330 miles)
    Color : Red, of course !
Thank You's: 0
Neutral
Posted 25 April 2009 - 07:23 PM
Hello ,
Forget it !
Dunlop tires are generaly "oversized" : a 170 is near to 180mm width, and a 180 near to 190 mm; I have had a D207 installed on a 5.5 inches rim (of a 3rd gen VFR) ; in theory the width of the tyre was 180 , but I saw that the edge of the D207 have slightly rubbed the swingarm and leave a print (small) in it !
It will be worse with a 190 !
And if you drive "hard" , the VFR Swingarm is a little bit "light" for a 180, compared to the swingarm of a 900RR !
0
#3 User is offline   Gap Trash
  • Race Team Owner
  • PipPipPipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::1995 VFR 750
    92 F-150 4X4 extended cab
    1997 Toyota Avalon
    2008 Suzuki DRZ 400 SM
Thank You's: 0
Neutral
Posted 25 April 2009 - 07:44 PM
I have a 95 VFR and I once mounted a 190 Dunlop, it was close on the clearance but it worked, BTW I ride pretty hard and never had any problems. That said my best advice is to skip the Dunlop unless you are just getting a great deal on it or something.
[color="#FF0000"]:Andrew:
2008 Suzuki DRZ-400SM, rejetted, 3X3 airbox mod, uncorked exhaust! Acerbis handgaurds.
1995 VFR 750
Current Mods: Hindle Carbon Fiber Slip on, BMC Air Filter, Corbin Seat, Silver Star Bulbs, RaceTech springs, -1+2 520 chain conversion, rejetted, fresh Ferrari red custom paint.
Posted ImagePosted ImagePosted ImagePosted Image
Ride with Gap Trash: smokeymountainmototours.com
0
#4 User is offline   cbrizzle
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 26 April 2009 - 03:42 AM
^ Do you remember if your Dunlop was a 190/55 or 190/50??
What do you by 'hard' and 'light' when referring to swingarms? Do you mean that the VFR may not handle the stress or forces of a 190 tire somehow?
I guess I am getting a pretty good deal on the tire because it's free :laugh: Well, technically, I paid $420 for the set and only did 20 laps on it -- but saying it's free makes me feel better about it :biggrin:
0
#5 User is offline   cbrizzle
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 26 April 2009 - 03:44 AM
Oh and I just thought of this:
Although I don't have a tire changer, I can throw tire around the rim, I just won't be able to seat the tire on the wheel. Then, I can mount the tire and wheel on the swingarm and it'll give me a much better idea of how much space I have to work with.
With a single sided swingarm, I should move the hub as close to the front of the bike as possible before I measure and cut for the chain, correct?
0
#6 User is offline   Tightwad
  • Race Team Owner
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::2002 VFR800 w/ABS....somewhat stock, but farkles are taking over...
  • Signed Flaf:
Thank You's: 11
Good
Posted 26 April 2009 - 08:33 AM
If you can get the tire on the wheel, why can't you seat the bead? That is the easy part....just add air.
Posted Image Posted Image
Creator of the R/R "VFRness" Harness kits:Click here for the Original Discussion and here for 90-97 models (Click the Picture):Posted Image
For questions regarding the simple 6th gen headlight mod, check out this link: Click here for the discussion and pictures
Check out my Website for wiring needs and discounts on VFR farkles from Powerlet, Bikebolts and Speedbleeder products...i love a challenge...if you can describe it, I can build it! If it's for the VFR, I am even happier to help!
WWW.WireMyBike.com
0
#7 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Group: Forum Moderator
  • In My Garage::2010 Honda GL800RR-SP2
    Back in business baby!
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 26 April 2009 - 10:06 AM
I've seated the beads on a newly installed 180/55-17 using a cheap little portable/emergency 12v air compressor before.
Worked fine, just don't expect NASCAR pit crew times to do it.
Posted Image
Rob McKinnon
'99 GL800RR-SP2
http://s13.photobuck...eefer800canuck/
Quote
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. Because Honda cannot test all other accessories, you must be personally responsible for proper selection, installation, and use of non-Honda accessories.
Quote
We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle's handling, stability, and braking, making it unsafe to ride
0
#8 User is offline   jeremy556
  • I AM THE STIG
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::02 ABS
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 26 April 2009 - 11:38 AM
That 209GP is a different animal than any Dunlop street tire; I would take it over a Pilot Power any day.
Are you sure it is a 190/55? I thought the 209s only came in 190/60.
Posted Image Posted Image Posted Image
0
#9 User is offline   cbrizzle
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 26 April 2009 - 01:43 PM
^ yes, thank you for correcting me. It's been a while since I ran dunlops or the 209's. It's one reason why I am afraid it won't fit w/o rubbing.
0
#10 User is offline   cbrizzle
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 26 April 2009 - 01:48 PM
I mean getting one side/lip of the tire on the wheel. Getting the other side/lip of the tire on, would require a tire changer and irons.
btw, how do you balance a single sided wheel? You can't use a traditional balancer, like this right?...
http://tbn2.google.com/images?q=tbn:w5Wmrw...ncer-handle.jpg
0
#11 User is offline   Beck
  • Race Team Owner
  • Group: Members
Thank You's: 2
Neutral
Posted 26 April 2009 - 02:15 PM
The squeezed sidewalls I had with Dunlop 207s on my 4th gen's 5 inch rims (which was OEM to the 4th gen) really felt weird and almost unsafe at times when I had my bike leaned over in the tight stuff. Felt really vague/unstable at full lean on the resulting very steep sidewalls. IIRC, even Dunlop themselves admitted that there was a problem with their oversized 170's then and actually later came up with a version of their 170 section 207s that were actually more like 170's than 180's width-wise, so it fits the 5" rims better on bikes like the 4th gen VFRs.
All I can say is, I wouldn't recommend doing it.
BecK
95 VFR
0
#12 User is online   vfrcapn
  • Race Team Owner
  • View blog
  • View gallery
  • Group: Forum Contributor
  • In My Garage::'99 VFR800
    '85 VF1000R
    '84 VF1000F
Thank You's: 10
Good
Posted 26 April 2009 - 03:42 PM
You have to buy or make an adapter to fit in the backside of the wheel. Harbor Freight is selling one now for the VFR and other ss wheels. There are also cone adapters that fit on either side of the wheel and center it.
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=65079
Or something like this:
http://www.marcparnes.com/Honda_Motorcycle...el_Balancer.htm
Gumball...
"Don't be afraid to make mistakes; if you don't make mistakes, you're not reaching far enough." – David Packard
0
#13 User is offline   gr8vfr
  • Factory Team Rider
  • PipPipPip
  • View blog
  • Group: Members
  • In My Garage::Y2K VFR800fi
    09 Kawi C-14
    08 Ducati 848
    02 Suzuki SV650s
    05 Suzuki SV1Ks
    03 Yamaha Kodiak 400
Thank You's: 0
Neutral
Posted 26 April 2009 - 03:57 PM
The only question that comes to mind about this whole thread is:
WHY?
A 180 on a 5th gen wheel on a 4th gen bike makes it handle the best.
Even a 180 on the 4th gen wheel makes the once stable VFR twitchy.
But I guess, do what you want. It is your bike.
Most riders aren't skilled enough to tell the difference how a bike should handle... :(
This post has been edited by gr8vfr: 26 April 2009 - 03:58 PM
http://www.RideWNC.com _ Why is there never enough time to do it right the first time, but always enough time to do it over?
0
#14 User is offline   jeremy556
  • I AM THE STIG
  • View blog
  • View gallery
  • Group: Volunteer
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 26 April 2009 - 04:12 PM
WHY?
That tire is a DOT race tire, it is a 190/60 with a taller profile than a 180/55, and should have no problem fitting on a 5.5" rim. :fing02:
0
#15 User is offline   cbrizzle
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 26 April 2009 - 05:39 PM
View Postgr8vfr, on Apr 26 2009, 03:57 PM, said:
WHY?
If you read above, I'm only contemplating it cause it's 'free' :biggrin: I can't really sell it as a take-off cause no one wants to use a non-ntech dunlop race tire when the ntech 209's and 211's are available.
Again, my major concern is swingarm clearance. I know a 190 race tire (which are all 55's or 60's) will fit a 5.5" rim. If it ends up rubbing, I guess I will end up having a slick on the left side of my tire :laugh: jk
0
#16 User is offline   cbrizzle
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 26 April 2009 - 05:42 PM
Wow, I surprised HB has this!! Thank you for the info. I don't have a balancer, but I've always wondered how these wheels were balanced on a static balancer.
0
#17 User is offline   jeremy556
  • I AM THE STIG
  • View blog
  • View gallery
  • Group: Volunteer
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 26 April 2009 - 06:29 PM
WHY?
It is a pretty common post on this forum of people wanting to install 190/50 rear tires on their VFRs because they are into the "wide" look. The stock advise is, of course, that it is a bad idea because our wheels are too narrow so it squeezes the tire, the clearance issues, and that it will handle like crap. It was my first instinct when clicking on this thread as well, until I read that the tire was a 209.
0
#18 User is offline   cbrizzle
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 26 April 2009 - 07:24 PM
WHY?
icic. I guess there are no clearance issues when people mount 190's on 5th and 6th gen VFR's? Not that it would really apply apply to me since I have a 4th gen swingarm, just curious.
I don't know why more people don't use take-offs. Most racers sell them for under 75 bucks a set and they usually have less than a 100 miles on them! I am still able to get thousands of miles on them and they stick fine for commuting and canyon purposes and don't slide out as quickly as regular tires.
0
#19 User is offline   cbrizzle
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 28 April 2009 - 02:14 AM
So I mounted the wheel and tire w/ the Dunlop 190/60. Fits great with plenty of clearance! Thanks all for your advice.
http://i90.photobuck...rf/IMG_0126.jpg
http://i90.photobuck...rf/IMG_0125.jpg
I still need to purchase a rear SS or kevlar line, which seems to require the rear hugger... but the stock rear hugger is so bulky and hideous!! Are there any mods or aftermarket hugger/fenders that I can purchase for a 90-97 swingarm??
0
#20 User is offline   The Phantom
  • Quieta non movere
  • Group: Volunteer
  • In My Garage::1994 VFR750
    1995 VFR750
    2001 Cannondale Super V
    1984 CCM Autobike
  • Signed Flaf:
Thank You's: 8
Neutral
Posted 28 April 2009 - 03:28 AM
Hi,
Yes you can get huggers, but before you spring for one check out the 'flipped eccentric' mod - which allows you to play with your geometry and alter rear ride height and swingarm angle of attack. A hugger on a flipped eccentric looks bad as there ends up being 30-40mm of gap between hugger and tyre.
You could run the rear brakeline inside the swingarm...
Regarding chain length - yes you do want to have the eccentric as close to the swingarm pivot as possible to take your measurements before cutting the chain.
Lots of chain, sprocket, hub info in this topic.
Posted Image
Sorry baby, but I had to crash that Honda
Vir prudens non contra ventum mingit!
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
