VFR Discussion: My Diy Rack And Panniers Under $60 Ammo Cans *pics* - VFR Discussion
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   ke5aux
  • Local Racer
  • Pip
  • View blog
  • Group: Members
  • In My Garage::96 VFR
Thank You's: 0
Neutral
Post icon  Posted 25 February 2009 - 06:12 PM
I recently sold my car and the tractor is now my main form of transportation, thus I needed to increase its cargo capacity. Being a pretty odd and old bike (1996 Honda VFR750) the only commercial option I saw were the Givi cases and mounts. Even the most basic set up would cost me over $600. So I decided to make my own.
Making and mounting panniers for under $50, little to no tools, and almost zero fabrication experience.
First, I set out to look for the actual boxes. After much research and indescision at various stores I settled for US Army ammunition cans. The 11X16X5 in 60mm mortar ones. Why ammo cans?
* Cheap at $10 per box
* Airtight and durable
* Come in a variety of shapes and sizes
* Many places to get replacements
So here are the said cans.
Posted Image
I then continued to see how they would fit on the VFR by using bungee cords.
Posted Image
Posted Image
Satisfied with the looks I now needed a sturdier replacement for the bungee cords. Thus I pulled off the plastics and was surprised to see two holes in the frame already pre-drilled and threaded.
Posted Image
Posted Image
Obviously, the plastics of the bike would not allow me to attach the panniers directly to these holes, so I decided to make L -shaped brackets from aluminum (aluminium). Scroll down to the test fitment part if you're impatient.
I went to my local hardware store, in this case, ACE Hardware and picked up some aluminum square tubing, L - shaped door brackets, and nuts and bolts to hold everything together and WASHERS. Lots and lots of washers. I can not stress the importance of those enough when putting together anything that requires tension.
Posted Image
I chose aliminum vs steel because it was cheaper, much lighter, and a lot easier to cut and drill. Steel would be weldable and stronger.
Using a folded sticky note as my 45 dedree angle I started making the actual rack. The pictures below are out of order, but the point is to test fit as many times are you can.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
A few things happened on the way. First, the plastics would not go on over the brakets, so I ended up having to cut out bits and pieces of it to make it fit. The whole thing looked crooked and did not line up properly. Turns out - the plastics were not on straight and the previous owner that installed the turn signals and tail light also but it on croocked.
Posted Image
Posted Image
Posted Image
Posted Image
I tested the whole thing by trying to break of the racks with my weight, but they worked out just fine.
To attach the ammo boxes, I simply drilled holes and used very large washers along with rubber ones to spread the stress.
Posted Image
They were then bolted to the bike.
Posted Image
Posted Image
Posted Image
Here is the final product. I added a flex-bar to prevent the cans from bending inward .The front is supported by the passeneger pegs.
Posted Image
Posted Image
Posted Image
0
#2 User is offline   V-FORE
  • World Superbike Racer
  • View gallery
  • Group: Forum Contributor
  • In My Garage::'94 VFR, '80 CX500D, '72 Vegza
  • Signed Flaf:
Thank You's: 2
Neutral
Posted 25 February 2009 - 06:27 PM
It looks as though now you will be able to carry more, I do like the ingenuity & cost of your bags!
IGNORANCE + FORCE = RESULTS
It got me hooked!
Posted Image/Posted ImagePosted ImagePosted ImagePosted Image
0
#3 User is offline   Tightwad
  • Race Team Owner
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::2002 VFR800 w/ABS....somewhat stock, but farkles are taking over...
  • Signed Flaf:
Thank You's: 11
Good
Posted 25 February 2009 - 06:28 PM
I like it...but what stops your stuff from spilling out while you load the boxes? Are they removable?
Posted Image Posted Image
Creator of the R/R "VFRness" Harness kits:Click here for the Original Discussion and here for 90-97 models (Click the Picture):Posted Image
For questions regarding the simple 6th gen headlight mod, check out this link: Click here for the discussion and pictures
Check out my Website for wiring needs and discounts on VFR farkles from Powerlet, Bikebolts and Speedbleeder products...i love a challenge...if you can describe it, I can build it! If it's for the VFR, I am even happier to help!
WWW.WireMyBike.com
0
#4 User is online   YoshiHNS
  • Race Team Owner
  • View blog
  • View gallery
  • In My Garage::71 Suzuki MT50
    93 Honda ST1100
    96 Honda VFR750F
    98 Honda VFR800
    02 Honda ST1100
    07 RWB VFR800
  • Signed Flaf:
Thank You's: 8
Neutral
what are you doing for waterproofing?
Most people make a project out of a broken bike, while Yoshi makes it a career.
Its a NACA thing. You wouldn't understand.
0
#5 User is offline   ke5aux
  • Local Racer
  • Pip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 25 February 2009 - 06:34 PM
When parked, the boxes are at about 5 degrees. Stuff doesn't spill out much. They are removable by taking off 4 bolts. Still working on that.
The ammo cans are waterproof and airtight by themselves, when I drilled the holes I used rubber gaskets and RTV. They are still waterproof. I have had the cans on for about 2 months now and no issues as of yet.
I also had the misfortune of crash testing them. Dropped the bike while parking - very embarassing.
The cans held up well although they took the hit, just some scratches and the bike was saved.
This post has been edited by ke5aux: 25 February 2009 - 06:34 PM
0
#6 User is offline   Auspaņol
  • True Blue
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::Honda VFR800FI 1998 Silver: Sold
    Honda VFR800 VTEC 2003,
    Lapiz Metallic Blue: current ride.
Thank You's: 1
Neutral
Posted 25 February 2009 - 07:17 PM
Hehehe, very entertaining... a misers (mis)adventures in ingenuity.
Maybe you should paint the bike to suit... :ph34r:
The best thing is the domain exists... still under construction, but is a solid calling card, you can see the quality of your IT work.
What about bicycle wheel quick-release mechanisms for adding removability??
This post has been edited by Auspaņol: 25 February 2009 - 07:18 PM
Confucius says: Everyone's different, except me!!
Posted Image
Friend of dale-j on the 6th gen VFR: "That thing looks like an alien love child with buck teeth"
0
#7 User is offline   timmythecop
  • Deported to Maryland, Says he's not from there!
  • View gallery
  • Group: Volunteer
  • In My Garage::aint got one of your fancy-pants garages!
  • Signed Flaf:
Thank You's: 21
Excellent
Posted 25 February 2009 - 07:30 PM
Personally, I like it, but my taste has been called into question as it pertains to home made stuff.
Never stop!
Flat black is the new black.
Can I convince you to paint it flat black....?
Thanking you in advance, Timmy
2000 VFR800Fi, D&D shorty, EBC HH pads, Sargent Seat, Pazzo Levers, Symtech Grip Heaters, Lobster's Extenders, Givi Wingrack 2, Givi E28 and E360 Bags, Dubious Chinese Double Bubble, Kung-Fu GPS, Blue MotoCross Grips, Dirt.
0
#8 User is online   YoshiHNS
  • Race Team Owner
  • View blog
  • View gallery
    93 Honda ST1100
    96 Honda VFR750F
    98 Honda VFR800
    02 Honda ST1100
    07 RWB VFR800
  • Signed Flaf:
Thank You's: 8
Neutral
Posted 25 February 2009 - 07:37 PM
eh? Show me what you're referring to.
0
#9 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Group: Forum Moderator
  • In My Garage::2010 Honda GL800RR-SP2
    Back in business baby!
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 25 February 2009 - 07:40 PM
Behold, bicycle wheel skewers:
Posted Image
Posted Image
Rob McKinnon
'99 GL800RR-SP2
http://s13.photobuck...eefer800canuck/
Quote
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. Because Honda cannot test all other accessories, you must be personally responsible for proper selection, installation, and use of non-Honda accessories.
Quote
We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle's handling, stability, and braking, making it unsafe to ride
0
#10 User is offline   vfrdreamer
  • Club Racer
  • PipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::-01 vfr
    -93 ninja 250
    -90 nissan 240sx (2)
    -94 sc300 (5spd)
Thank You's: 0
Neutral
Posted 25 February 2009 - 08:48 PM
wow i love them thats awsome man!
the style looks alot more klr ish.... but i love klr's!
if u ever dinged it up... drab green rattle can would look sweet in my opinion (my old drift car was camoflouge!)
lovin the duct tape seat repair, do u have the lower fairings?
This post has been edited by vfrdreamer: 25 February 2009 - 09:05 PM
0
#11 User is offline   timmythecop
  • View gallery
  • Group: Volunteer
  • Signed Flaf:
Thank You's: 21
Excellent
Posted 25 February 2009 - 09:25 PM
I'm still trying to give away some olive drab motocross bars..............................................
0
#12 User is offline   SEBSPEED
  • float like a goldwing, sting like a gixxer
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::Mini Honda dealership
  • Signed Flaf:
Thank You's: 48
Excellent
Posted 25 February 2009 - 09:30 PM
Timmy, I think if he painted the bike flat black, he could be your long lost brother!
Is that an LED taillight from a trailer as your taillight? Did you buy the bike like that or did you mod the tail yourself at some point?
Sebastian - **Yankee Railer**
1983 VF750F 2,997 original miles, undergoing full hot-rod restoration- K&N, Accel coils & wires, Megacycle Stage 1 cams, jetted, Works shock, CBR F2 wheels, VF1000R forks, RaceTech Gold Valve Emulators, Sonic 1.0 springs, Chevy S-10 'clear' headlight, fender chop, Maier dark smoke screen, Vance and Hines full 2-2 system, 96 VFR clip ons, much more in the works!
1986 VFR700F 900RR forks w/ Racetech .90's, CBR F3 front wheel, 900RR rear wheel, PARTING OUT - PM FOR PARTS INQUIRIES
198x VF500F GONE
1996 VFR750 frame and swingarm, possible track bike?
1996 VFR750 secret project...
1996 VFR750 31k miles, K&N, otherwise stock - SOLD
2001 CBR600F4i GONE
2005 VFR800 Sargent seat, NEP throttle lock, Symtec heated grips, Powerlet, DIY fender eliminator, oem hard bags, modded passenger pegs, Garmin Nuvi 750, Ohlins 46DRS, .90 RaceTech fork springs, Staintunes, Rivcyko double secret probation CF hugger, CF Bug Buster, UNI filter mod, PC3 USB w/ Cozye's map, Speed Bleeders, ATE Super Blue brake fluid, coming soon - RaceTech Gold Valves, catless headers, VFRness &...
***Bailey-san sez, zip-tie a rim protector to your HF bar on your HF changer to keep from scratcha rim***
Posted Image Posted Image Posted ImagePosted Image Posted Image
0
#13 User is offline   Gap Trash
  • Race Team Owner
  • PipPipPipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::1995 VFR 750
    92 F-150 4X4 extended cab
    1997 Toyota Avalon
    2008 Suzuki DRZ 400 SM
Thank You's: 0
Neutral
Love it! I've been looking around for a while for something like this and had considered ammo cans. If you can get past their appearances (I can) they are quite functional and very cheap. Would you mind possibly sketching your design and giving dimensions? I think this is something that I would be interested in implementing myself.
[color="#FF0000"]:Andrew:
2008 Suzuki DRZ-400SM, rejetted, 3X3 airbox mod, uncorked exhaust! Acerbis handgaurds.
1995 VFR 750
Current Mods: Hindle Carbon Fiber Slip on, BMC Air Filter, Corbin Seat, Silver Star Bulbs, RaceTech springs, -1+2 520 chain conversion, rejetted, fresh Ferrari red custom paint.
Ride with Gap Trash: smokeymountainmototours.com
0
#14 User is offline   SEBSPEED
  • View blog
  • View gallery
  • Group: Volunteer
  • Signed Flaf:
Thank You's: 48
Excellent
Posted 25 February 2009 - 09:36 PM
I dare you to paint them red. :biggrin:
198x VF500F GONE
2001 CBR600F4i GONE
0
#15 User is offline   ke5aux
  • Local Racer
  • Pip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 26 February 2009 - 04:57 AM
The duct tape is also an amazing theft deterrent.
I bought the bike with no fairings. Honestly, I like it better that way - the 4th gen fairing look too wide to me.
Bought with the light. It's actually a motorcycle brake light with high-powered LED's.
I'm working on a dead charging system right now, but I'll measure the brackets.
0
#16 User is offline   Trinith
  • Factory Team Rider
  • PipPipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::1998 VFR800FI
    2000 Dodge Dakota
Thank You's: 0
Neutral
Posted 26 February 2009 - 06:22 AM
Talk about ingenuity, wow. Very well done!
1998 VFR800FI - Corbin seat, -2/+1 sprockets, speedohealer, Powerlet, VFRNess
Driven, not ridden through:
0
#17 User is online   YoshiHNS
  • Race Team Owner
  • View blog
  • View gallery
    93 Honda ST1100
    96 Honda VFR750F
    98 Honda VFR800
    02 Honda ST1100
    07 RWB VFR800
  • Signed Flaf:
Thank You's: 8
Neutral
Posted 26 February 2009 - 09:30 AM
Posted Image
Not quite sure how I would implement that. Only way I can think of is having another tab on the case, and then having the nut off of the skewer rigidly attatched to the luggage rack. Then it would be just a matter of dropping the cans on, screwing in the shaft, and locking it down. Not sure if that thing could take the beating though. For my pelican cases, I couldn't do larger than 1/4 inch. Must do some testing...
0
#18 User is offline   vanion2
  • Wife hate's it when I call it sexy...but I can't help it
  • View blog
  • View gallery
  • In My Garage::2002 Honda VFR
Thank You's: 4
Neutral
Posted 26 February 2009 - 09:42 AM
Are the pics still up? For some reason I cannot see them (maybe work computer related)... :mellow:
2002 Honda VFRA
Mods: Paint scheme - Pair block off - Flapper deactivated - 02 Sensor Mod - Stebel Nautilus - Evap Can removed - VFRness - Yamaha R1 Titanium mufflers
Posted Image
Posted Image
0
#19 User is offline   ke5aux
  • Local Racer
  • Pip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 26 February 2009 - 12:18 PM
Yes they are.
Try this page http://petrolpowered.com/?page=tech
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
