VFR Discussion: My Tire Patch Kit - VFR Discussion
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
My Tire Patch Kit
#1 User is offline   BaileyRock
  • Back in the Saddle!
  • View gallery
  • Group: Forum Moderator
  • In My Garage::02 Vtec
    04 vtec track pig
    07 SYM Fiddle 50
    about 3 bikes worth of pieces!
  • Signed Flaf:
Thank You's: 30
Excellent
Posted 16 January 2009 - 07:57 PM
I just thought I would post up what I carry on my bike for flat tire repair, it's packed in my tail bag for every ride and I've used it several times recently. It worked like a charm. :cool:
I found a cheap plastic bodied air compressor at Wally World for less than $20 which is small and light along with a simple glue less plug kit. I modded the power cord end so that it plugs right into either of my two BMW type power outlets. These plugs are super sticky rope type plugs that need NO cement, I've been very happy with the results using them so far. Here's what I have boxed up and stored in my tail bag.
Posted Image
My last use/need was at the 375 mile mark of my Fort Donelson ride last Dec. where I found a gash in the base of tread that was approximately 3/8" long which took two plugs to seal, but 3 weeks later it's still holding full pressure after getting me safely home.
Posted Image
Simple, cheap and effective!
What are you guys using/carrying if any?
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
"If everything seems under control, your just not going fast enough" Mario Andretti
current bikes
02 VFR BLACK, 77,050 miles(no Valve check yet), SB-II exhaust , 15t, Penske w/20kg, AfterShocks forks w/.95 kg, V1, heated grips, Pilot Power front/ Road 2 rear, No surge or Vtec transition problems! Mobil 1 15w-50 or Shell Rotella T Syn., Buell pegs.
01 VFR (brother's) crashed
07 GSXR 750(SOLD!)
02 F4i Track Bike(GONE!)
93 Yamaha WR250(in a box)
04 VFR track pig project(fast & crashed)
0
#2 User is offline   maddog
  • World Superbike Racer
  • PipPipPipPip
  • Group: Members
  • In My Garage::2000 VFR
Thank You's: 2
Neutral
Posted 16 January 2009 - 08:20 PM
I've got a Slime pump and rope plugs/tools. I use some glue on mine, though, just to be sure. Helps to have a very sharp knife to trim off the excess. That's where my Gerber multi-tool came in handy.
Used it once in Oregon, worked fine and lasted. Fortunately, I caught the offending sharp object while doing a tire inspection following a brisk :biggrin: ride with some like minded crazies. Nice to fix a puncture in the motel parking lot while drinking a beer offered by a fellow rider.
I need to find some sort of container/bag to hold everything together. Those reamers are pointy little devils. No room under the seat, and often not in the tankbag. Time for a new tailbag.
0
#3 User is offline   vfrcapn
  • Race Team Owner
  • View gallery
  • Group: Forum Contributor
  • In My Garage::'99 VFR800
    '85 VF1000R
    '84 VF1000F
Thank You's: 10
Good
Posted 16 January 2009 - 08:21 PM
I was going to go out shopping this weekend for one of those air compressors, thanks for the suggestion. For flats I'm using a mushroom plug style kit. I know I've seen a site where someone disassembled the compressor in order to ditch the plastic body and save space, just keeping the guts.
Gumball...
"Don't be afraid to make mistakes; if you don't make mistakes, you're not reaching far enough." – David Packard
0
#4 User is offline   BaileyRock
  • View gallery
    04 vtec track pig
    07 SYM Fiddle 50
  • Signed Flaf:
Thank You's: 30
Excellent
Posted 16 January 2009 - 08:26 PM
That's funny, I couldn't find anything sharp enough to cut the excess plugs off the tire. I plan to carry a set of side cutters from now on! :blush:
Cortech Sport tail bags are awesome and cheap at newenough.
Posted Image
current bikes
07 GSXR 750(SOLD!)
0
#5 User is offline   VFRgenius
  • Privateer
  • PipPip
  • View blog
  • Group: Members
  • In My Garage::Red 98'
    Bone stock
Thank You's: 0
Neutral
Posted 16 January 2009 - 08:36 PM
I carry a compressor that I got from autozone or somthing for less than 20 bucks thats supposed to plug into a car outlet but got an adapter with clamps so that I can hook it up right to my battery($5)and a plug kit that uses no cement and a pair of dikes to cut off the excess. From experience ive noticed that the plugs that use cement just seem to come out. Started carrying my kit when I got a flat on the way to the airport during the holidays. Just filled the tire with air at a gas station and parked at the airport to worry about when I came back because I was running a little late. I put the kit in a backpack for now because of no tank bag yet.
0
#6 User is offline   BaileyRock
  • View gallery
    04 vtec track pig
    07 SYM Fiddle 50
  • Signed Flaf:
Thank You's: 30
Excellent
Posted 16 January 2009 - 08:44 PM
After reading your post I went ahead and popped open the case to see what kind of space I might save and I don't think it's a worthwhile venture on this unit, here's a pic.
Posted Image
The compressor unit is only 5 1/2x 4 1/2x 2 1/2 as is and I pack everything in a 7x7x3 cardboard box that easily fits if the tail bag. The whole thing weights maybe 1.5 lbs. :happy:
current bikes
07 GSXR 750(SOLD!)
0
#7 User is offline   davy_a
  • Local Racer
  • Pip
  • View blog
  • Group: Members
  • In My Garage::'98 VFR
Thank You's: 0
Neutral
Posted 16 January 2009 - 08:45 PM
A word of warning regarding tire plugs:
Don't use canned 'fix-a-flat' to try and improve an old plug that is starting to leak. It is a long story that I won't bore you all with, but ultimately there was no damage and no injury. The 'fix-a-flat' slime simply lubricated the plug, shot it out and I had sudden loss of all pressure at 80 mph while surrounded by semi-trailers. Fortunately it was on the rear tire or I probably wouldn't be a current VFRD member.
Dave
This post has been edited by davy_a: 16 January 2009 - 08:45 PM
0
#8 User is offline   FotoMoto
  • Grammer Nazi
  • View gallery
  • In My Garage::96RCBVFR
  • Signed Flaf:
Thank You's: 13
Good
Posted 16 January 2009 - 08:47 PM
Kevin,
I carry pretty much the same kit except for the pump. It's a foot pump as the last few bikes I've had I've never gotten around to installing a dc outlet like I had on my last vtec. Anyway, the foot pump takes about as long as the small electric compressors do but with a lot more muscle effort. LOL It's reasonably compact but not near as small as yours (I'm still talking about air compressors here folks!). :)
I'll looke for that model the next time I'm at wallyworld. BTW, I've read some threads were they took the plastic covers off and reduced the overall size even less. Edit: you all ready check!
Doug
06 Speed Triple
96 RCBVFR 750
last six:
05 RC51 Da' Black Beast
02 VFR800
98 VTR1000F SuperBling
98 Bandit1200S
02 VFR800
94 VFR750F
0
#9 User is offline   Joe Foe from Buffalo
  • Moto Grand Prix Racer
  • PipPipPipPipPip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 16 January 2009 - 09:05 PM
I took my wally world/cheap/small type mini compressor out of it's plastic case to save on space. Also took the on/off switch and pressure gauge off and beefed up the wires a little and made the wires just long enough to reach the front and rear tires to save on space and I have easy to use battery alligator clips on the wires. Entire set up the size of my fist that I have in a stuff sack the same size with plug/patch kit.
Joe Foe from Buffalo ?:-)
Sound of my 1997 VFR:
http://tinyurl.com/488uv
Pictues of my VFR.
http://tinyurl.com/6f74h
0
#10 User is offline   vfrcapn
  • Race Team Owner
  • View gallery
    '85 VF1000R
    '84 VF1000F
Thank You's: 10
Good
Posted 18 January 2009 - 02:18 AM
I was at an auto parts place and they had the Slime unit which seemed about as small and compact as I could get so I picked that up. Comes with cigarette lighter plug, direct battery connects or alligator clips for the battery, plus about a 4' extension cord for all of the connectors. $29 at Autozone. I just added a cigarette lighter outlet to my tank bag for my cell phone/ipod/video camera charger, works great for this.
Posted Image
I popped it open also to see if I could save some space but it just didn't seem to be worth it so I kept it together as a unit.
Posted Image
My plug kit is the Aerostich mushroom style. I removed the CO2 canisters to save space and the Slime electrical wires fit right in. I do use glue with these mushroom plugs btw. I had a flat about a year and a half ago about 100 miles from home at 11pm at night, 40 degrees F, and 3 of my CO2 canisters only got the tire up to ~20 psi. Enough to get me a few miles to the next gas station but not good, especially if there hadn't been a service station nearby, which is why I've wanted to add a compressor.
Posted Image
The Slime unit just barely fits under the seat. Aerostich kit is in the rear tail.
Posted Image
Tire repair kit. Done.
Gumball...
0
#11 User is offline   Beck
  • Race Team Owner
  • PipPipPipPipPipPip
  • Group: Members
Thank You's: 2
Neutral
Posted 18 January 2009 - 06:02 AM
I have a "Stop and go" tubless tire repair kit in my bikes tail (Its bag just fits in the small space right on top of the tail/brake lights), plus I got myself six 16 gram CO2 cartriges that go with a small inflator from a bicycle shop. The 4th's gen limited under seat space does not let me carry anything as big as an electric pump, plus, I do not like to stress my bike's electrics with it anytime.
I back my tire repair system with a small Yamaha aerosol can tire repair in my tank bag. That's only for when conditions will not allow me to stop long enough to do a proper tire plug installation with the "Stop and go" kit. The Yamaha aerosol stuff already saved me once already on my previous bike, when I picked up a big roofing nail. It acutally kept the tire air tight for the next year after the pundture, till I had to replace it because of tread wear.
My dad and older brother have had very good experience with the "Stop and go" tire repair kit and it was my brother that gave me the kit as a gift last year.
Beck
95 VFR
0
#12 User is offline   Joe Foe from Buffalo
  • PipPipPipPipPip
  • View blog
  • Group: Members
Thank You's: 0
Neutral
Posted 18 January 2009 - 09:23 AM
Has anyone tried to use a Stop n Go Engine-Air Pump as detailed on this page on a VFR?
http://www.stopngo.c...rcycle/1015.asp
I have one lol never tried it since it looked like it would be a pain the butt to use compared to the way I have gone and detailed on this page.
http://www.webbikeworld.com/Motorcycle-tec...icles/air-pump/
Pictues of my VFR.
0
#13 User is offline   johnmark101
  • Power is nothing without control.
  • View gallery
Thank You's: 2
Neutral
Posted 18 January 2009 - 10:17 AM
I have the "Stop & Go" tire plugging kit and the Slime pump. Only had to use it once and it got me home just fine. Replaced the tire however as I did not feel the plug was safe for "spirited" riding. I carry it in my Ventura sport bag on every ride.
2003 Honda VFR in silver, Staintunes, Sargent seat, Helibars, Power Commander USB III, Penske rear shock, Traxxion front forks, Ventura luggage system, Pazzo levers, Speedohealer and a 45 tooth rear sprocket.
2007 CBR 600RR blue and silver, R&G frame sliders, Carrozzeria wheels, Spiegler brake lines, Puig tinted screen, Pazzo levers.....amazing machine for street and track use.
Track days are like heroin.......so addictive!!!
0
#14 User is offline   SEBSPEED
  • float like a goldwing, sting like a gixxer
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::Mini Honda dealership
  • Signed Flaf:
Thank You's: 48
Excellent
Posted 18 January 2009 - 06:05 PM
Same setup here - only I haven't had to use mine yet. *knocks on wood*
I did use the pump once to bump my tire pressure.
Sebastian - **Yankee Railer**
1983 VF750F 2,997 original miles, undergoing full hot-rod restoration- K&N, Accel coils & wires, Megacycle Stage 1 cams, jetted, Works shock, CBR F2 wheels, VF1000R forks, RaceTech Gold Valve Emulators, Sonic 1.0 springs, Chevy S-10 'clear' headlight, fender chop, Maier dark smoke screen, Vance and Hines full 2-2 system, 96 VFR clip ons, much more in the works!
1986 VFR700F 900RR forks w/ Racetech .90's, CBR F3 front wheel, 900RR rear wheel, PARTING OUT - PM FOR PARTS INQUIRIES
198x VF500F GONE
1996 VFR750 frame and swingarm, possible track bike?
1996 VFR750 secret project...
1996 VFR750 31k miles, K&N, otherwise stock - SOLD
2001 CBR600F4i GONE
2005 VFR800 Sargent seat, NEP throttle lock, Symtec heated grips, Powerlet, DIY fender eliminator, oem hard bags, modded passenger pegs, Garmin Nuvi 750, Ohlins 46DRS, .90 RaceTech fork springs, Staintunes, Rivcyko double secret probation CF hugger, CF Bug Buster, UNI filter mod, PC3 USB w/ Cozye's map, Speed Bleeders, ATE Super Blue brake fluid, coming soon - RaceTech Gold Valves, catless headers, VFRness &...
***Bailey-san sez, zip-tie a rim protector to your HF bar on your HF changer to keep from scratcha rim***
Posted Image Posted Image Posted ImagePosted Image Posted Image
0
#15 User is offline   Bad Boy
  • Rides with scissors
  • PipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::02 VFR800, 85 CB700SC Nighthawk S, 08 DRZ400
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 21 January 2009 - 03:30 PM
BR has the right stuff. I carry the same Campbell Hausfeld pump. Walmart $10 and a plug kit. I like the gummy rope type plugs used w/ glue. I have had to use it 4 times in 4 years. Rear tire goes flat in the middle of nowhere and I am back on the road in half an hour. I soldered in a coax connector so I can connect to the same fused coax harness I connect my heated jacket controller or battery charger. I have been riding 17k miles per year up to 2k miles from home. It is great being self sufficient.
Where am I going and how did I get in this hand basket?
0
#16 User is offline   boog
  • Local Racer
  • Pip
  • View blog
  • Group: Members
  • In My Garage::05 VFR,200 KTM, 70 Bonneville,600RR, 07 Wee-Strom
Thank You's: 0
Neutral
Posted 21 January 2009 - 03:55 PM
I have a fair amount of experience with flats between myself and my riding compatriots since we are high mileage riders. I have found the worms more effective than the mushrooms, especially with steel belted tires. The steel belts tend to cut the mushrooms leading to failure. I have also learned thru experience to not depend on CO2 cartridges. If your repair doesn"t work and all your CO2 is gone, you are out of luck.I always carry a Slime pump and worms.
0
#17 User is offline   Macs06VFR
  • In My Garage::I plead the 5th
Thank You's: 1
Neutral
Posted 21 January 2009 - 04:22 PM
I have a cheapy pump too (looks very much like Bailey's), as well as a simalar plug kit. Great minds think alike? I took the plastic off and cut the cig plug. Saved some space.
Haven't had to use it yet, but it's tested fine each time I check. (Maybe once a month or so?) It should do it's job though.
0
#18 User is offline   BaileyRock
  • View gallery
    04 vtec track pig
    07 SYM Fiddle 50
  • Signed Flaf:
Thank You's: 30
Excellent
Posted 22 January 2009 - 04:09 PM
I have never used cement on the type of plugs I'm using (worms/strings/rope plugs?) Do you guys have better luck using it along with the(non-glue) plugs. :huh:
current bikes
07 GSXR 750(SOLD!)
0
#19 User is offline   Knife
  • Race Team Owner
  • View gallery
  • In My Garage::1998 Honda VFR800FI Interceptor, Red (the fastest color)
Thank You's: 10
Good
Posted 22 January 2009 - 04:37 PM
I carry the following...
Cycle Pump Combo Kit
• Adventure Model Cycle Pump
• Cords, Plug Adaptors- Standard & BMW style
• EZ Air Gauge
• Pocket Tire Plugger Kit
I've had to use the pump only once. Slow, but effective.
Posted ImagePosted ImagePosted Image
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
