Tyres, Temperatures And Pressures Effects of the Universal Gas Law
#1
Posted 10 October 2008 - 06:06 AM
I think I am experiencing a slow leak from the tyre, but its so slow and inconsistent I got to thinking about the ambient temperatures I'm operating in and how that might have affected the tyre measurements. Like everyone I know that we measure the tyre when its cold, but how cold is too cold, and how much affect will the ambient temperature have on my measurements.
Would a 10C difference in temperature equate to a 0.1PSI change, 1PSI, 10PSI etc??
I measure the tyre at the same time each morning and the only two variables are the air temp and the actual pressure in the tyre (though you should probably include atmospheric pressure??) the readings are all over the place for the front tyre, but reasonably steady on the back, hence the reason I think I have a leak. I have also had the valve changed, and the readings don't seem to have settled down.
But what about the bike weight? If I have the preload high on the rear and full or empty tank???
Am I thinking into this too much?
#2
Posted 10 October 2008 - 06:45 AM
Flashbacks to college. piv equal nert. Or rather PV = nRT.
Yes, temp will affect the pressure. But enough to actually feel it? I didn't sign up for the math.
'00 VFR - Yellow Submarine/School Bus - Berkshires MA, USA
Custom Mirror Extenders, Dual-Star Heated Grips, High mount MIG Indy, Sargent seat, Stebel Compact Nautilus with compressor relocation, Sonic .90 Fork Springs, 929 Rear Shock, UNI Foam Filter MOD, VTR Fan, SuperBlue Brake Fluid
WDGAH VI, WDGAH X
#3
Posted 10 October 2008 - 06:58 AM
#4
Posted 10 October 2008 - 08:17 AM
A 10K temp difference equates to about half a psi, depends on what the start temp was. That is too small to be bothered by it. But if you do, you should include atmospheric pressure variation into the eqation
But more important is where do you fill up the tires? At home, or do you have tot ride to the gas station? If you fill up the tires at a gas station the tempareture in the tires may have made the tire pressure go up by several psi already. Also do you allways fill up at the same gas station?
#5
Posted 10 October 2008 - 08:18 AM
Action
This post has been edited by Action: 10 October 2008 - 08:26 AM
#6
Posted 10 October 2008 - 08:25 AM
At zero degrees Celcius
A cubic centimetre of air
consists of
45,000,000,000 time 1,000,000,000 molecules
so start counting tose that are in your tyre.....
You can ring my be-e-ell, ring my bell
"Come So Far, Yet Still So Far to Go"
#7
Posted 10 October 2008 - 03:03 PM
Answers to the other questions.
- I had used that valve over a whole bunch of tyre changes, but its been changed now.
- I check it at home, but have to ride about 500m to the nearest petrol station to top it up. I put in whatever I decided at home.
Thanks all, I'll keep monitoring it and see if the valve changed has fixed it.
#8
Posted 22 October 2008 - 10:02 AM
My front tire has felt very sluggish each morning this week. The morning temp has dropped to 30F-35F here most mornings. Once warmed up a bit the tire feels better, but it's definitely low when I start out.
So my question is what psi should my "cold" inflation be set to, considering I don't want it to 'balloon' to 50+ psi once the tire is warmed up? It seems wrong to set my cold inflation all the way to my normal 40-42 psi when I know the tire is going to warm up substantially after a few miles.
What's the general consensus on setting 'cold' inflation levels in freezing ambient temps? Should I up it a few psi or just deal with an underinflated/sluggish tire for 5-10 minutes each morning?
"VFRs aren't dirtbikes." - tpierce(MP)
#9
Posted 22 October 2008 - 10:10 AM
2004 VW GTI VR6-the tow rig
2001 BMW R1150GS
2001 Suzuki DR650SE
Past:
CB650SC, a few VFRs, K12RS, FZ6
#10
Posted 22 October 2008 - 10:18 AM
Where can I score a blue 6th gen in the States?
Creator of the R/R "VFRness" Harness kits:Click here for the Original Discussion and here for 90-97 models (Click the Picture):
For questions regarding the simple 6th gen headlight mod, check out this link: Click here for the discussion and pictures
Check out my Website for wiring needs and discounts on VFR farkles from Powerlet, Bikebolts and Speedbleeder products...i love a challenge...if you can describe it, I can build it! If it's for the VFR, I am even happier to help!
WWW.WireMyBike.com
#11
Posted 22 October 2008 - 10:30 AM
#12
Posted 22 October 2008 - 10:54 AM
Bottom line.....just do what I do and check/adjust your pressures before every ride. I find myself adding at least a little every couple weeks to keep them at the spec I use of 42/36.
2002 Interceptor
Sargent Seat, OEM Hard Bags, Garmin Nuvi, Autocomm, PR2's, MRA VarioTouring Screen, '06 Clear signal lenses, Silverstars, BMC Air Filter, GenMars, NEW FRONT/REAR WIRING HARNESSES.
46,000 miles with no valve check...
#13
Posted 22 October 2008 - 10:58 AM
#14
Posted 22 October 2008 - 11:06 AM
2002 Interceptor
#15
Posted 22 October 2008 - 11:10 AM
http://home.comcast....r_tires_FAQ.htm
WWW.WireMyBike.com
#16
Posted 22 October 2008 - 11:52 AM
Nitrogen is a gas and adheres to the ideal gas law just like nitrogen and oxygen in regular air.
The reason it is used in aircraft tires is because of risk of fire from compressed oxygen.
#17
Posted 22 October 2008 - 11:57 AM
TimC, on Oct 22 2008, 11:02 AM, said:
42psi is the maximum rated pressure for the tire, it is not the pressure you should be running.
Factory recommended is 36 psi, IIRC.
#18
Posted 22 October 2008 - 12:38 PM
My front Diablo sidewall says max cold pressure is 42 psi, but I don't normally run max pressure in the front.
So are we supposed to go by the tire's max psi, or the wheel (which like Jeremy said is 36 psi IIRC, but wouldn't that have been for the OEM tires)?
Man, I feel like an idiot asking these questions.
(BTW, thanks for the info, Travis!)
#19
Posted 22 October 2008 - 12:45 PM
2001 BMW R1150GS
2001 Suzuki DR650SE
Past:
Help
MultiQuote
