VFR Discussion: 6th Gen Wheels Interchangability - VFR Discussion
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
6th Gen Wheels Interchangability what other gen's or bikes fit a 6th gen ???
#1 User is offline   marid2apterbilt
  • KneeDragging Novice
  • View blog
  • View gallery
  • Group: Volunteer
  • Location:western north carolina. not far from deal's gap
  • In My Garage::BLACK 06 vfr800 (Lysandra)
  • Signed Flaf:
Thank You's: 6
Neutral
Posted 08 October 2008 - 10:28 AM
Im sure this has been covered but cant seem to find it..
What other bikes and generation vfrs wheels fit a 6th gen 02+
Also any modifications needed.
Im looking for a second set of rimsto mount on the 06 vfr so I can just swap tires/wheels as needed.
Do 5th gen wheels swap with 6th gen. ??
I have heard 4th gen rears are wider and rub the swingarm ??
Are f4i fronts plun n play for a 6th gen ??
Posted Image Posted Image
I have gone to look for myself,
If i should return before i get back keep me here,
Otherwise leave your name n number and as soon as i find myself i will return your call.
Thank you.
So many fun roads, Only 1 lifetime to try n ride them all.
0
#2 User is offline   FotoMoto
  • Grammer Nazi
  • View gallery
  • Group: Forum Contributor
  • In My Garage::96RCBVFR
  • Signed Flaf:
Thank You's: 13
Good
Posted 08 October 2008 - 10:39 AM
4gen rear are 5.0 wide
3gen front require 3gen rotors
5/6gen will be plug and play for you
going backwards on rear wheel swaps: 5/6gen wheel onto a 3/4 gen swingarm require modding to clear brake rotor bolts
3/4gen rears will bolt to 5/6 gen swingarm without mods.
No other rears bolt on to any gen vfr without major mods (ducati, triumph, rc30/45, etc).
cbr600f3 fronts will fit and same rotors.
F4i and superhawk fronts will work and use same rotors but design won't match (3 spoke).
Doug
06 Speed Triple
96 RCBVFR 750
last six:
05 RC51 Da' Black Beast
02 VFR800
98 VTR1000F SuperBling
98 Bandit1200S
02 VFR800
94 VFR750F
0
#3 User is offline   BaileyRock
  • Back in the Saddle!
  • View gallery
  • Group: Forum Moderator
  • In My Garage::02 Vtec
    04 vtec track pig
    07 SYM Fiddle 50
    about 3 bikes worth of pieces!
  • Signed Flaf:
Thank You's: 30
Excellent
Posted 08 October 2008 - 10:56 AM
I don't think the F3 rotors are the same, but the 99-00 F4 rotors are exactly the same and would be a bolt up deal other then the 3 spoke like FM said.
Also F4i's use different rotors than the VFR, but should work if you use the wheel with rotor combo.
;p
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
"If everything seems under control, your just not going fast enough" Mario Andretti
current bikes
02 VFR BLACK, 77,050 miles(no Valve check yet), SB-II exhaust , 15t, Penske w/20kg, AfterShocks forks w/.95 kg, V1, heated grips, Pilot Power front/ Road 2 rear, No surge or Vtec transition problems! Mobil 1 15w-50 or Shell Rotella T Syn., Buell pegs.
01 VFR (brother's) crashed
07 GSXR 750(SOLD!)
02 F4i Track Bike(GONE!)
93 Yamaha WR250(in a box)
04 VFR track pig project(fast & crashed)
0
#4 User is offline   marid2apterbilt
  • View blog
  • View gallery
  • Group: Volunteer
  • Signed Flaf:
Thank You's: 6
Neutral
Posted 08 October 2008 - 11:25 AM
;p
a few more questions..
How wide is a 6th gen rear.. ?? 5.5" ??
what years are 4th gens ??
And a little clarity about the fronts
99-00 f4 wheel with 99-00 f4 rotors will work
f4i wheel with ??vfr ?? rotors ??
5th fronts are plug n play (yes)
Are 4th gen fronts ??? plug n play ??
These will all use the 6th gen front axle and spacers ?????
Thank you.
0
#5 User is offline   BaileyRock
  • View gallery
    04 vtec track pig
    07 SYM Fiddle 50
  • Signed Flaf:
Thank You's: 30
Excellent
Posted 08 October 2008 - 11:37 AM
Yes!
94-97 and there 5" wide
Yes, may need different spacers(3 spoke).
If you use wheel & rotors it should work(3 spoke)
Yes, front & rear.
No!
current bikes
07 GSXR 750(SOLD!)
0
#6 User is offline   SEBSPEED
  • float like a goldwing, sting like a gixxer
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::Mini Honda dealership
  • Signed Flaf:
Thank You's: 48
Excellent
Posted 08 October 2008 - 11:41 AM
Some definites that I can add:
- the VFR axle will hold the F4i wheel in the VFR(6th gen), I do not know if the VFR spacers will properly center the wheel, or if the F4i rotors will line up.
- F4i wheel needs F4i rotors
- 5th & 6th gen VFR wheels need F4 or 5th or 6th gen rotors.
- 5th & 6th gen VFRs run a 5.5" rear wheel
Sebastian - **Yankee Railer**
1983 VF750F 2,997 original miles, undergoing full hot-rod restoration- K&N, Accel coils & wires, Megacycle Stage 1 cams, jetted, Works shock, CBR F2 wheels, VF1000R forks, RaceTech Gold Valve Emulators, Sonic 1.0 springs, Chevy S-10 'clear' headlight, fender chop, Maier dark smoke screen, Vance and Hines full 2-2 system, 96 VFR clip ons, much more in the works!
1986 VFR700F 900RR forks w/ Racetech .90's, CBR F3 front wheel, 900RR rear wheel, PARTING OUT - PM FOR PARTS INQUIRIES
198x VF500F GONE
1996 VFR750 frame and swingarm, possible track bike?
1996 VFR750 secret project...
1996 VFR750 31k miles, K&N, otherwise stock - SOLD
2001 CBR600F4i GONE
2005 VFR800 Sargent seat, NEP throttle lock, Symtec heated grips, Powerlet, DIY fender eliminator, oem hard bags, modded passenger pegs, Garmin Nuvi 750, Ohlins 46DRS, .90 RaceTech fork springs, Staintunes, Rivcyko double secret probation CF hugger, CF Bug Buster, UNI filter mod, PC3 USB w/ Cozye's map, Speed Bleeders, ATE Super Blue brake fluid, coming soon - RaceTech Gold Valves, catless headers, VFRness &...
***Bailey-san sez, zip-tie a rim protector to your HF bar on your HF changer to keep from scratcha rim***
Posted Image Posted Image Posted ImagePosted Image Posted Image
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
