VFR Discussion: Wire In Tires! - VFR Discussion
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Wire In Tires! What is it!!
#1 User is offline   Bent
  • Race Team Owner
  • View blog
  • Group: Forum Contributor
  • In My Garage::2006 VFR, LeMond Buenos Aires, et al.
  • Signed Flaf:
Thank You's: 7
Neutral
Posted 01 September 2008 - 07:49 AM
Two months later, I find yet another piece of TINY wire in the tread of one of my rear tires. I pull it out and really didn't think it penetrated all the way through. It did. Tire is losing 7# of air overnight.
The wire is much finer than a staple, as in REALLY tiny. I just pumped the tire back up to where I wanted the pressure yesterday and rode it and hard in some places. Checked it when I got home and all air was in it.
Anyone know what this very tiny wire is??? If I knew what it is, I might be able to go where it "isn't". Last occurance cost me a good rear tire. The patch job was botched.
I would take a pic but the wire is too small to show up!!
THX,
Bent... :)
Posted ImagePosted ImagePosted Image
"If you can't have fun, don't show up."
~Bent 2001
"Where ever I go, fun follows me"
~R. Rowan
"Beware of the Shark Knife"
"If you think you're in a bind, you're in a bind"
~Bent 2010
0
#2 User is offline   spud786
  • Race Team Owner
  • PipPipPipPipPipPip
  • View blog
  • Group: Members
  • In My Garage::2006 interceptor abs
Thank You's: 4
Neutral
Posted 01 September 2008 - 08:09 AM
I stopped running this one road, and cut flats by 98%
is this a rear application? than small of hole, I think you be impressed just installing 7 or ounces of slime.
I know its hard to consider that, just try it and chew my A$$ later, but I think you'll be okay
0
#3 User is offline   FlaminV4
  • ROLEM
  • View blog
  • View gallery
  • In My Garage::2003 Honda Interceptor VFR800A Custom Paint R.I.P. 08/01/2008
    2007 RWB
    2009 Audi Q7
Thank You's: 0
Neutral
Posted 01 September 2008 - 08:34 AM
I haven't used the slime yet but have heard goood things about it. If the hole is that small and you didn't mark it, good luck finding it now. The slime should work well plus it cleans up with water.
"Semper Fidelis" - "Always Faithful"
Posted Image Posted Image
0
#4 User is offline   Stéphane
  • Motorcycle Racing Legend
  • View blog
  • View gallery
Thank You's: 0
Neutral
Posted 01 September 2008 - 09:36 AM
Park your bike mate,
I believe it is the steel from your tire coming out because the "belt" is breaking apart. You need a new tire. Haven't you picked up a vibration with that?
0
#5 User is offline   bluedragon
  • I will kill you until you die from it!
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • In My Garage::silver 2003 vfr 800,2006 Black and silver kawi ninja 650(my womans bike)
Thank You's: 0
Neutral
Posted 01 September 2008 - 10:22 AM
its obviously piano wire, stop riding through piano stores
911 WHERE IS YOUR EMERGENCY?
check me out! myspace.com/bluedragon1096
Posted Image
0
#6 User is offline   motogpfan
  • World Superbike Racer
  • View blog
  • View gallery
  • In My Garage:: 99 vfr,RX 8 white pearl,10ae mazda miata turbo@240 rwhp
Thank You's: 0
Neutral
Posted 01 September 2008 - 11:29 AM
:+1:
From what you said about the wire size could be a defective steel belt.
0
#7 User is offline   mojopolo
  • Mojo-Polo
  • PipPipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::02 VFR 800 FI ABS
Thank You's: 0
Neutral
Posted 01 September 2008 - 11:30 AM
Sounds like the wire from the cords of the tire?? How many miles do you have on this thing? Could be you have a bad tire.
0
#8 User is offline   oyama
  • Lean it like you mean it!
  • View blog
  • In My Garage::Red 2004 Interceptor ABS with 26,570 miles
    Orange 1998 Suzuki GS500E with 5,800 miles
  • Signed Flaf:
Thank You's: 0
Neutral
Posted 01 September 2008 - 11:42 AM
If this is true then it would explain your wild ride in a turn a few days ago...
www.farkasbalint.com Posted Image Posted Image Posted ImagePosted ImageHow to pronounce my first name How to pronounce Oyama
“There’s the V-4 thing: there’s just something about it that inline 4s don’t have, and V-twins have too much of.”
– Murray Duncan
"If loud pipes save lives, imagine what learning to drive that thing would do."
0
#9 User is offline   FlaminV4
  • ROLEM
  • View blog
  • View gallery
    2007 RWB
    2009 Audi Q7
Thank You's: 0
Neutral
Posted 01 September 2008 - 12:11 PM
:+1:
The belts in a tire are much larger than a staple unless they are coming untwined but if I had to guess, I wouldn't think that the belt is coming apart and actually punctured your tire. I would get it fixed and see how it is. IMO
0
#10 User is offline   dutchinterceptor
  • Black on Black on Black on Black
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::What Garage???
    2004 Asphalt Interceptor
  • Signed Flaf:
Thank You's: 14
Good
Posted 01 September 2008 - 12:51 PM
A lot of my bicycle flats have been from tiny wires like you mentioned. I figured it was from car/truck tire pieces that littered the roads I ride on.
"Ride Lots"......E. Merckx
Dutch Photographic
VFRD Rallies: Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted ImagePosted Image
Elka 3-Way Shock, Race Tech Front Springs, Sargent Saddle, Gutted Exhaust, Throttlemeisters, Symtec Grip Cookers, Centech Fuse Block, Powder Coated Various Parts, Zero Gravity Dark Smoke Windscreen, Speedohealer, Lightech Billet Gas Cap, Beltronics Vector 995(Stealth Mount), Marc Parnes LEDs, Honda Side Cases, Ken's Luggage Rack(Flush Mounted), Honda Top Case, Light-n-Bolts, Clear Lens Swap, Stebel Nautilus, Custom Fender Eliminator, Electropods Hyper-Lites Tailight Mod, Signal Dynamics Voltage Monitor, Ampliryder Audio, Koss Helmet Speakers, Corbin Saddle, More to Come...
0
#11 User is offline   Bent
  • Race Team Owner
  • View blog
  • Signed Flaf:
Thank You's: 7
Neutral
Posted 01 September 2008 - 04:47 PM
I think you have it Dutchy. James and I did ride through a broken up car or truck tread yesterday...no choice.
Balint, this tire wasn't on the same bike I had the "fun time" with day before yesterday. That bike was the 5th gen. The wire was in my 6th gen. rear tire.
No, it isn't a bad steel belt because Avon Storms don't have steel belts.....Aramid fiber belts. After pumping the tire back up yesterday, I rode it about 125 semi-hard miles in the twisties and it lost no air during that session. Since the rear tire is on it's way to being worn out, I think I'll just pump it up and wear it out fairly close to home. I carry a Slime compressor and plug kit.
I'm also going to start carrying my gun in case I need to shoot the darn thing.... :goofy:
Thanks for all the good input and possibilities. I'll probably never really know for sure but will avoid areas with blown up tire carcasses. :rolleyes:
~Bent 2001
~R. Rowan
~Bent 2010
0
#12 User is offline   DougFromIndy
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::3 Hondas: 03 silver vfr800 : 98 CR500 : 89 VTR250
    3 Yamaha-has: 92 TDM850 : 95 XT600e: 03 TTR125l
  • Signed Flaf:
Thank You's: 3
Neutral
Posted 01 September 2008 - 08:21 PM
"Little wires, pliers, tires....They turn me on..." FZ Joes Garage
Sorry, nobody will understand this unless you are a true Zappa fan like myself. :biggrin:
Heres the Mat Mladin post again....I love it, what a great rider.
http://www.youtube.c...h?v=JzVPY2p5Org
0
#13 User is offline   Bent
  • Race Team Owner
  • View blog
  • Signed Flaf:
Thank You's: 7
Neutral
Posted 03 October 2008 - 10:14 AM
Conclusion to issue: The tire would hold air all day long, so I just rode the thing (and rode it hard) till it wore out last weekend. It has a new, yet to be scrubbed in tire on it now. Tomorrow, the other VFR gets a new rear tire....two to scrub in. Why do they all wear out at the same time? :(
~Bent 2001
~R. Rowan
~Bent 2010
0
#14 User is offline   SEBSPEED
  • float like a goldwing, sting like a gixxer
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::Mini Honda dealership
  • Signed Flaf:
Thank You's: 48
Excellent
Posted 03 October 2008 - 10:23 AM
"No one plans to fail, most just fail to plan..."
:rolleyes:
Sebastian - **Yankee Railer**
1983 VF750F 2,997 original miles, undergoing full hot-rod restoration- K&N, Accel coils & wires, Megacycle Stage 1 cams, jetted, Works shock, CBR F2 wheels, VF1000R forks, RaceTech Gold Valve Emulators, Sonic 1.0 springs, Chevy S-10 'clear' headlight, fender chop, Maier dark smoke screen, Vance and Hines full 2-2 system, 96 VFR clip ons, much more in the works!
1986 VFR700F 900RR forks w/ Racetech .90's, CBR F3 front wheel, 900RR rear wheel, PARTING OUT - PM FOR PARTS INQUIRIES
198x VF500F GONE
1996 VFR750 frame and swingarm, possible track bike?
1996 VFR750 secret project...
1996 VFR750 31k miles, K&N, otherwise stock - SOLD
2001 CBR600F4i GONE
2005 VFR800 Sargent seat, NEP throttle lock, Symtec heated grips, Powerlet, DIY fender eliminator, oem hard bags, modded passenger pegs, Garmin Nuvi 750, Ohlins 46DRS, .90 RaceTech fork springs, Staintunes, Rivcyko double secret probation CF hugger, CF Bug Buster, UNI filter mod, PC3 USB w/ Cozye's map, Speed Bleeders, ATE Super Blue brake fluid, coming soon - RaceTech Gold Valves, catless headers, VFRness &...
***Bailey-san sez, zip-tie a rim protector to your HF bar on your HF changer to keep from scratcha rim***
Posted Image Posted Image Posted ImagePosted Image Posted Image
0
#15 User is offline   Flightar
  • View blog
  • View gallery
  • In My Garage::2004 VFR, 2007 Ninja 650R, 2008 Moto Guzzi Breva 750
Thank You's: 1
Neutral
Posted 03 October 2008 - 10:49 AM
What we need on this board is a little Green Rosetta...and a green Roseetie too!.....FZ.
Lowside
0
#16 User is offline   WERA910
  • V-Force Fanatic
  • Group: Members
  • In My Garage::'03 Aprilia Tuono, '05 GSX-R 600 Track Ho
  • Signed Flaf:
Thank You's: 0
Neutral
Posted 03 October 2008 - 12:15 PM
One thing I learned early in racing is that whenever you cut off safety wire, throw it away immediately. If you didn't put it in the trash can, you'd find it in your tire. If you got it in the wrong place in the tire, it would leak.
Have you been anywhere that would use small gauge safety wire? It's all over airplanes as well as racing vehicles.
Michael
Michael
Street: 2003 Aprilia Tuono, Magnet Grey, Almost street nirvana... wish it had a V4!
Track: 2005 GSXR600, vortex sprockets, Traxxion springs, frame sliders, Power Race PRC's
SuperMotard: 2003 Yamaha YZ450F, Sun Rims, Braking caliper and rotor, lowered, 248lbs....
New toys: 1996 Ninja 250 E-superbike racer in training... and a Z50
Gone but not forgotten:
'00 YZ426F Supermoto, '98 VFR800 Pearl White and trick!, '97 YZF1000R Thunderace Track tool (RIP), '88 VTR250 Interceptor, '00 CBR929RR Streetfighter, '99 CBR600F4 Racebike, '89 CB-1 CB400F, '98 VFR800 red, '93 CBR600F2 Race bike, '87 ZX1000R Ninja, '84 KZ700A, '91 ZX6 New, '89 EX500?New, '87 EX250 Ninja, and an '80 XL185S
0
#17 User is offline   Bent
  • Race Team Owner
  • View blog
  • Signed Flaf:
Thank You's: 7
Neutral
Posted 03 October 2008 - 12:42 PM
Michael
No, Michael, I haven't been near any of these type places. In fact, this wire was way too small to be used as a safety wire. Smaller than steel belted tire cord even. I have no idea what the application of this small a piece of wire would be, but it's happened twice now with the same size wire.
Good thought though. Thanks for the info.!! :fing02:
~Bent 2001
~R. Rowan
~Bent 2010
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
