VFR Discussion: Anyone Tried The Pirelli Diablo Rosso's - VFR Discussion
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   Silver#788
  • A.K.A. "The Midnight Rider"
  • View gallery
  • Group: Forum Contributor
  • In My Garage::1998VFR800FI , 08 KLR650 , 2003 SV1000S , 97 CBR600F3
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 15 March 2008 - 11:36 PM
I just got a pair from my local shop at cost to try them out and give a review. Not a 2C tire like the mich. 2ct's.
Posted ImagePosted ImagePosted ImagePosted ImagePosted Image
*Black Bird Rear Shock*Garmin Zumo 550 * K & N Filter * PCIIIUSB * Corbin Seat * DarthBling's GSXR Mirrors w/Lobster extenders* BMW Blue Powder coated 8 Spoke Rear Wheel, Frame, Rear Sets, and every other small metal part * Vista Cruize * Datel Volt Meter * 06 R1 Regulator Rec. * Heli-bars * Pilot Power 2CT*
0
#2 User is offline   marid2apterbilt
  • KneeDragging Novice
  • View blog
  • View gallery
  • Group: Volunteer
  • Location:western north carolina. not far from deal's gap
  • In My Garage::BLACK 06 vfr800 (Lysandra)
  • Signed Flaf:
Thank You's: 6
Neutral
Posted 16 March 2008 - 12:34 AM
I ran across them tonite n posted a topic too then saw this one..
Are they dual compound, The Pirelli website didnt actually state that they were but implied the rear will wear with the front so you dont have the problem of replacing the rear before you toast the front.. Or as they basically put it the problem of running 1 worn n 1 new..
Posted Image Posted Image
I have gone to look for myself,
If i should return before i get back keep me here,
Otherwise leave your name n number and as soon as i find myself i will return your call.
Thank you.
So many fun roads, Only 1 lifetime to try n ride them all.
0
#3 User is offline   Silver#788
  • View gallery
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 16 March 2008 - 01:39 AM
I looked around a bit...
This is what I found
Product Description
* The new concept tire from Pirelli is called the Diablo Rosso. Instead of using multi- compounds, they use what is called EPT (Enhanced Patch Technology) to ensure a better grip and better performance on the road.
* Based on their leading experience in the motorcycle racing world, they produced this tire for the street legal (super)sports motorcycles. Sports motorcycles have been increasing their power and torque over the last decade, and the tires need to follow this trend. Current tires are limited, hence the reason Pirelli came out with a new concept.
* The structure design is aimed to maximize - at every lean angle and every speed - the contact patch; in terms of area, shape and pressure. This combination supports the tread to reach an unbeatable level of grip and stability. The tire structure has been designed in order to get the set synchronized into balanced behavior, with the 2 tires perfectly matched in dynamic use.
* The patented Zero Degrees steel belt below the tread keeps the tires in the most suitable shape at all times and yet provides enough elasticity for a very progressive feedback and behavior in lean, allied to unbeatable bump absorption. With the support of the compound the zero degrees steel belt also guarantees huge braking stability.
0
#4 User is offline   marid2apterbilt
  • View blog
  • View gallery
  • Group: Volunteer
  • Signed Flaf:
Thank You's: 6
Neutral
Posted 16 March 2008 - 07:49 AM
Duh , oops I must have read the first paragraph too fast..
Let us know how long they last you and if the rear actually lives as long as the front..
Not to be skeptic but i'm real curious If the front wears even or not..
Thank you.
0
#5 User is offline   kwr8728
  • Motorcycle Racing Legend
  • View blog
  • View gallery
  • In My Garage::2002 VFR 800
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 16 March 2008 - 07:43 PM
I had them on my bike for the last 250 miles. While i didn't get to really get them tested, i did go thrash them a little. Turn in isn't as agressive as the power, but seemed a little faster then the M3. Front didn't seem to provide feedback like a Power or M3. One thing that did impress me was the lack of wheel spin at full throttle while leaned over... 2nd gear around 9k i opened it completely up while exiting a turn. The front got super light, but the rear stayed planted. I did also mess with some trail braking. That is where the tire felt most vague to me. Either i wasn't pushing it enough or the front is just that vague.
I did not get to try them out in the rain. I was skeptical of what the rear was going to be like in the rain. It is a slick on the outer 3/4" of rubber. Think DOT race rubber. I will try another set. I want to see what they are capable of mileage wise... and up in the mountains!
Posted Image Posted Image Posted ImagePosted ImagePosted ImagePosted Image
If you are in the Atlanta, Ga area and need your bike worked on, PM me with what you need done.
0
#6 User is offline   turtlecreek
  • Ham Fisted Fat Bastage
  • View gallery
  • In My Garage::Silver 2003 VFR
    2005 Sir Squidly Gixxer 750 Track Bike
    Gone: 1997 YZF600r, 2005 Yamaha Roadstar
Thank You's: 5
Neutral
Posted 05 September 2008 - 01:42 PM
any updates on this tire? i recently road the diablo to the ozarks and LOVED them. they were extremely light up front and quick to turn in (felt much quicker then the pp's i normally run). assuming life is short like everyone else said, maybe the new rosso will be better.
so has anyone run the diablo and the diablo rosso and can compare? any mileage update on the rosso?
I learned a long time ago, best way to realize the danger of your pace is when it goes from that speed to zero really abruptly.......mighta' been faster than I thought......Skuuter Posted Image
"Courage is almost a contradiction in terms. It means a strong desire to live taking the form of a readiness to die. 'He that will lose his life, the same shall save it' is not a piece of mysticism for saints and heroes. You must seek life in a spirit of furious indifference to it; you must desire life like water and yet drink death like wine." GK Chesterton
MODS: Givi Windscreen Factory Windscreen due to Dragon Bite, Sargent Seat, Headlight Modulator, Heli Bars, Padded Grips, PCIII USB, 30 Amp Fuse Upgrade, Fender Eliminator, Evap Canister Removed, PAIR Valve Removed, Flapper Mod, De-Snorkled, O2 Sensor Removed/Plugged, BLS Footpeg Mod, .95 Racetech Springs and Ohlin Valves, F4 Shock Rebuilt/Resprung to 950lb for Fat Arse, '99 Catless Headers, 15T Front Sprocket, Vecky5 Gutted Exhaust, Riv's Hugger, 12v meter, VFRharness w/ relay block, Speedohealer
0
#7 User is offline   TonySanchez
  • Factory Team Rider
  • View blog
  • View gallery
  • In My Garage::2005 VFR800
Thank You's: 0
Neutral
Posted 05 September 2008 - 01:50 PM
I just put some on this morning and will be (hopefully) going to indy on them next week. I'll try to remember to give some feedback when I get back.
There are three types of people in this world: Those who can count, and those who can't.
0
#8 User is offline   billyjackjimbob
  • Kentucky "Viffer" Kid
  • PipPipPipPipPip
  • View gallery
  • Group: Members
  • In My Garage::07 Honda VFR800 Interceptor 25th RWB
  • Signed Flaf:
Thank You's: 0
Neutral
Posted 05 September 2008 - 02:44 PM
I have around 2500 on my set. (I know I said I would never run anything put Pilot Power 2cts... but they didn't have any) Very good tires. Good grip and the wear looks very good so far. One odd thing, I can't get the last 1/4 of chicken strip off these dang things. Usually the first trip through the Gap and the Mich. Man's head is gone. Must be a profile thing. The turn in is not as quick as the Powers but all in all, these are the 2nd best tires I've had, next to the 2cts that is.
Kevin
"There is no worse tyranny than to force a man to pay for what he does not want merely because you think it would be good for him."
Robert A. Heinlein
0
#9 User is offline   danny
  • New Member
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::vfr 800 '98
Thank You's: 0
Neutral
Posted 23 September 2008 - 11:28 PM
got the Pirelli Diablo Corsa for about 5000 km/ Great tires !!!!!!
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
