VFR Discussion: Cornerspin School - VFR Discussion
Riding Technique
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Cornerspin School "Road racing in the dirt".
#1 User is offline   hlf
  • Epee
  • View blog
  • View gallery
  • Group: Forum Contributor
  • In My Garage::02 VFR,
    06 GSXR 600 (Track)
Thank You's: 0
Neutral
Posted 18 February 2008 - 06:45 PM
I spent this past weekend attending Aaron Stevenson’s Cornerspin school; “Roadracing in the Dirt”. (Cornerspin School). This is a road racing school taught on dirt. Flat track and motard riding techniques are used with drills specifically applicable to road racing.
Great road racers like Kenny Roberts, the Hayden brothers, Colin Edwards, Tony Elias, Sete Gibernau, Valentino Rossi, and Casey Stoner all learned riding on small dirt bikes and continue to train using dirt bikes.
Using a small dirt bike really allows you to feel the how your body position, weight transfer, throttle and brake inputs, etc., effect the bike. Working with the relatively low traction of dirt allows you to slide the front and rear of the bike easily. Since these bikes weigh only about 150 lbs., everything you do on the bike is magnified, making it pretty obvious how you are impacting the motorcycle’s dynamics. The lower speeds minimize the pain of errors (well, this is mostly true, anyhow).
Aaron Stevenson is the guy behind the Cornerspeed road racing school at Virginia International Raceway. His Cornerspin school is run at his facility just outside Salisbury, NC (about 30 miles north of Charlotte). On the facility, the first track you come to is a mini-flat track, with 50 foot straights connecting turns about 50 feet in diameter, on a clay like surface. Down the hill a bit is a football sized field just filled with intersecting tracks that twist and turn all over the place. There have to be at least 20 course variations in this maze. The tracks are typically about 10 feet wide. There are all sorts of turns and combinations; flat, banked, off-camber, constant radius, decreasing radius, increasing radius, with all sorts of elevation changes. The track had areas of sticky clay and very slippery dry dirt. Some of the turn combinations made you wonder how one could even get a bike around (yet, we were all able to do one-handed by the end of the school!).
Arriving early Saturday morning, I met the other 6 students. Few of us had every ridden a dirt bike before. (The school is limited to 6 students on school bikes, plus 2 more students who must bring their own bike.) Aaron Stevenson is the chief instructor (road racing National Champion), assisted by Mike Dillion (former AMA pro flat tracker and road racer), Jean ? (flat tracker, road racer, and snowmobile racer), and Phillip Doyle (class A enduro rider, GNCC road racer). I rented off-road riding gear (man, are off-road boots heavy!!!), so all I had to bring were gloves and helmet. The school provides the dirt bikes (mostly Honda XR100’s, with a few Yamaha and Suzuki 125 4-strokes).
The day’s first drills were braking drills; rear brake only, front brake only, then both. Sliding a little; then sliding a lot. On these small bikes you really feel how the chassis moves under front vs. rear braking. You also get to feel the front sliding/locking and how to modulate the pressure.
Next up was the “Circle of Confusion”. This is a circular track about 30 feet in radius with some elevation and camber changes. We learned proper body position and how to properly place your inside foot down to avoid injury (really turn your toes toward the inside of the turn). We practiced sliding the rear wheel, feeling how the changes in elevation, camber, and dirt surface affected the amount of slide. On a dirt bike, you need to sit very far forward and on top of the bike, pushing the bike down under you. As a road bike rider, I’ve worked hard to get my upper body to the inside of a turn, so this was pretty awkward for me. But when you do it wrong on these dirt bikes, the bike can be very communicative: you find yourself on the ground in an instant! Like all the drills at Cornerspin, we rode the circle in both directions to make sure we got the drill both to the left and right. The instructors would demonstrate each drill, and then keep watching and correcting.
The rest of the day was spent running through different track configurations, working on throttle control, braking, body position, relaxation, allowing the bike to move under you freely, etc. Aaron teaches you to hold the handlebars “screw driver” fashion. This means that you hold the bars with your forearm almost parallel to the bar, similar to the way you’d typically hold a screwdriver in your hand, instead of the common hand position where the forearm is almost perpendicular to the bar. Using the “screw driver” hold forces you to keep your elbows bent in a more relaxed position. You also have more finesse with the throttle. The instructors were constantly reminding us to “bend your elbows”, “move forward”, “get on the gas”, etc. They were great.
A couple of things really struck me the first day. One was how much your body position can affect the traction on the front vs. the rear. Being 2 inches too far back will cause you to lose the front (and crash, which is pretty effective feedback!). The other was how critical it is to get on the gas quickly after braking into a turn. Some of the tracks we followed had incredibly tight turns, and the only way you could get around was to be off the brakes and on the gas quickly; coasting would invariably cause you to run wide.
At the end of the day (close to 8 hours of riding), I was completely exhausted! I do a lot of cycling, so I was thinking I was in decent shape. Wrong! By mid-day I could hardly get my feet on the pegs, let alone hold my inside leg out straight, so had to do much of the afternoon riding feet on the pegs. It felt like I was wearing lead boots! I skipped the late afternoon free practice, since I was beat and my left forearm was about twice normal size due to swelling from one of my many falls. I left that day burnt out, with my arm in ice, wondering what I was thinking to be doing this. My only hope was Aaron’s words that the first day overwhelms you with information, but the light bulb comes on the 2nd day.
Sunday morning, I woke up so sore that I needed to lift my feet with my hands to put on socks! Ice and Advil tamed the left arm swelling, so still not fully understanding why I was going back, I headed to the Cornerspin facility. And I’m glad I did!
With no legs left, I decided I would just ride feet up the 2nd day. Fortunately, this was fine (even encouraged; this is a road racing school). We started on the mini-flat track, working on transferring weight to get the rear to hook up. We were practicing squaring off the double apex turns; braking hard to about the mid-point of the turn, turning hard to maximize the straight length, and shifting our weight on the pegs to get the spinning rear tire to hook up. It’s pretty cool to be power sliding out of the turn and have a small weight transfer give you more traction, enough to start lofting the front wheel.
We spent the rest of the day trying to put it all together on a myriad of course configurations, with every imaginable type of turn and turn combination. Backing it in, and power sliding out. One really neat exercise was a braking drill where we approached a turn with a large mound of dirt in the “braking” zone. You could brake easily on the up-hill side of the mound, but you’d be too slow on the rest of the entrance to the turn. The fastest way was to brake lightly just before the crest, get off the brakes as the bike was unweighted over the top, and then get on the brakes again when the track flattened out just before making a tight turn. You really get to appreciate how elevation affects braking! We also ran this mound as a turn exit, so you accelerated out of a turn up the mound, and then had to modulate your throttle as you crested the mound and unweighted the bike. Definitely cool.
The instructors were awesome to watch demonstrating techniques. There is so much to learn about bike handling and how precise one needs to be. Mike was particularly interesting talking about how fantastic flat tracking can be; the seemingly simple oval track, yet how hard it is to do it prefectly. He talked about how stoked he was to qualify 21st for his first AMA pro event; he was only 0.005 seconds off pole! Talk about small margins!
After another 7-8 hours of riding, I was definitely finished. I could hardly lift by feet onto the pegs they were so tired. (I guess if you going to be stupid, you have to be tough!) I had to skip the free practice time. In any event, I had learned a lot about how bikes behave when you are near and over the traction limits. I had a ton of new information to integrate into my track and street riding.
This was definitely a wonderful learning experience. The Cornerspin school is an incredible value, only $500 for 2 days including the bike! Sorry I don't have any photos, but there are plenty on the schools website.
I now need to buy a small dirt bike to keep learning!! I just hope I recover from my current feeling that I've been run over by a bus!
Eschew obfuscation!
Posted ImagePosted Image
0
#2 User is offline   Gatekeeper
  • Track, Street, Dirt. Just ride!
  • PipPipPip
  • View blog
  • Group: Members
  • In My Garage::.
    75 CT-90
    77 CB-750K with Sidecar
    05 CRF250X
  • Signed Flaf:
Thank You's: 0
Neutral
Posted 18 February 2008 - 09:57 PM
TRIM
I've got a YZ125 that I play with every weekend in the dirt. I ALWAYS come home very tired, sore and happy.
I really wanna do that school after seeing the videos of the school. (Learned a lot from those short minutes)
I hate the gym and use the bike and the dirt as my exercise. Single track trails in the hills, Too much fun!
Glad to hear of your great time, makes me wanna go even more!
0
#3 User is offline   turtlecreek
  • Ham Fisted Fat Bastage
  • View blog
  • View gallery
  • In My Garage::Silver 2003 VFR
    2005 Sir Squidly Gixxer 750 Track Bike
    Gone: 1997 YZF600r, 2005 Yamaha Roadstar
Thank You's: 5
Neutral
Posted 18 February 2008 - 10:21 PM
i have heard nothing but awesome reviews of this school. glad you had such a fun AND useful weekend! :thumbsup:
I learned a long time ago, best way to realize the danger of your pace is when it goes from that speed to zero really abruptly.......mighta' been faster than I thought......Skuuter Posted Image
"Courage is almost a contradiction in terms. It means a strong desire to live taking the form of a readiness to die. 'He that will lose his life, the same shall save it' is not a piece of mysticism for saints and heroes. You must seek life in a spirit of furious indifference to it; you must desire life like water and yet drink death like wine." GK Chesterton
MODS: Givi Windscreen Factory Windscreen due to Dragon Bite, Sargent Seat, Headlight Modulator, Heli Bars, Padded Grips, PCIII USB, 30 Amp Fuse Upgrade, Fender Eliminator, Evap Canister Removed, PAIR Valve Removed, Flapper Mod, De-Snorkled, O2 Sensor Removed/Plugged, BLS Footpeg Mod, .95 Racetech Springs and Ohlin Valves, F4 Shock Rebuilt/Resprung to 950lb for Fat Arse, '99 Catless Headers, 15T Front Sprocket, Vecky5 Gutted Exhaust, Riv's Hugger, 12v meter, VFRharness w/ relay block, Speedohealer
0
#4 User is offline   theoxmole
  • The human frame slider
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::2003 Honda Interceptor
    1974 Honda CB350F
    2007 CRF230F
    2006 CRF150F
    2001 XR 70
  • Signed Flaf:
Thank You's: 2
Neutral
Posted 18 February 2008 - 10:29 PM
I have my son's XR100 out in the garage. I can see what you're saying about learning a lot about control riding something like that. I have learned things about riding his that I have carried over to my CRF450. There's a lot to be learned there without the fear of getting really hurt. :thumbsup:
If I die and come back I want to be the pillion seat of a CBR1000RR. . . .
"Every mile a memory. . ." - Dierks Bentley
Posted Image Posted ImagePosted ImagePosted Image
Posted Image
Posted Image
0
#5 User is offline   V4 Rosso
  • Race Team Owner
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::VFR750FP
  • Signed Flaf:
Thank You's: 12
Good
Posted 19 February 2008 - 06:56 AM
What a great review, thanks :thumbsup:
I want to get myself a drtbike for the same reasons: to become a better street rider and because it looks like a lot of fun.
0
#6 User is offline   dirty
  • Local Racer
  • Pip
  • View blog
  • View gallery
  • Group: Members
    76 cb750
    00 cr250r
Thank You's: 0
Neutral
Posted 05 March 2008 - 04:37 PM
yep, riding in the dirt has definitely improved my street abilities with things like weight transfer, throttle steering, etc... just the medium that you're riding on is so unforgiving, you really have to have some finesse
I wish I was closer, that sounds like a fun weekend class!
0
#7 User is offline   BaileyRock
  • Back in the Saddle!
  • View blog
  • View gallery
  • Group: Forum Moderator
  • In My Garage::02 Vtec
    04 vtec track pig
    07 SYM Fiddle 50
    about 3 bikes worth of pieces!
  • Signed Flaf:
Thank You's: 29
Excellent
Posted 05 March 2008 - 05:36 PM
Nice write-up hlf ! :thumbsup:
Someone else did this last year too and had a good write-up on it too! :thumbsup:
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
"If everything seems under control, your just not going fast enough" Mario Andretti
current bikes
02 VFR BLACK, 77,050 miles(no Valve check yet), SB-II exhaust , 15t, Penske w/20kg, AfterShocks forks w/.95 kg, V1, heated grips, Pilot Power front/ Road 2 rear, No surge or Vtec transition problems! Mobil 1 15w-50 or Shell Rotella T Syn., Buell pegs.
01 VFR (brother's) crashed
07 GSXR 750(SOLD!)
02 F4i Track Bike(GONE!)
93 Yamaha WR250(in a box)
04 VFR track pig project(fast & crashed)
0
#8 User is offline   soichiro
  • VTEC POLICE!
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::04 vfr,
    81 silverwing,
    05 crf100f,
    1996 rm125
  • Signed Flaf:
Thank You's: 3
Neutral
Posted 06 March 2008 - 08:08 PM
Very cool. The track and school are very close to me. I spoke to Aaron for maybe an hour recently. He is a very nice guy and knows his stuff. We talked and I was surprised when he told me I was half way there. It doesnt hurt that I raced MX and actually have a crf100 in the garage.
That little bike will teach skills. I had fun today on a 10hp bike in first gear. I pulled the crf out and practiced balance manuvers. I would hold the bars against the lock and try ride complete circles. It took a few trys but after a minute I was riding circles with bars against the lock. It's harder than you think. Everything transfers over to street riding. 2 wheels is 2 wheels.
I would love to do the school.
RUBBER IS CHEAPER THAN PLASTER
RC46 #888
"BRAVERY IS THE CAPACITY TO PERFORM PROPERLY, EVEN WHEN SCARED HALF TO DEATH"
GEN. OMAR BRADLEY
Posted ImagePosted ImagePosted ImagePosted Image
0
#9 User is offline   thx1139
  • World Superbike Racer
  • View blog
  • View gallery
  • In My Garage::1996 VFR750
    1988 HawkGT
    1991 CB-1
    1999 KDX200
    2003 CRF100
  • Signed Flaf:
Thank You's: 0
Neutral
Posted 06 March 2008 - 09:39 PM
I had so much fun at American Supercamp, I bought my own CRF100 and a grooving tool to make flattrack tires.
Unfortunately now I got no place to ride it, so I still suck.
This school is so close to my current location, I'll have no excuse not to be backing it like a Hayden.
Or not. -but at least I'll have fun trying.
Definitely gonna check Cornerspin out.
:wheel:
Thanks for the post!
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
