VFR Discussion: Tire Pressure - VFR Discussion
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Tire Pressure I searched and found nothing this may be a repeat
#1 User is offline   sigsauer33
  • Kill or be Killed
  • PipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::02 VFR 800
Thank You's: 0
Neutral
Posted 17 February 2008 - 09:41 PM
I was riding today and noticed that my ties felt like they were loving to hug the turns. I got home and check the tire pressure and realized that it was low. So I let the tires cool down for a few hours and re checked the pressure and still they were low. I normally run them at the Max PSI as stated on the rubber (42psi) my tires were at 35. Now granted I have no engineering degree but it king of makes sense to me that a lower pressured tire would tend to mold and hug more to the contour of the road.
Any input so that I dont kill myself in the future thinking that i know all! :)
-Sig
USMC
SEMPER RIDING
SEMPER DEPLOYED
"IF A MAN HAS NOT FOUND SOMETHING HE IS WILLING TO DIE FOR, HE IS NOT FIT TO LIVE"
Posted Image
0
#2 User is offline   slowf2337
  • fool
  • PipPipPipPip
  • View blog
  • Group: Members
  • In My Garage::vespa
Thank You's: 0
Neutral
Posted 17 February 2008 - 09:51 PM
I usually run my PP's at 32-35 psi on the street. Less pressure allows for more flex in the rubber and lets the tire carcass heat up faster and maintain heat better. I do raise the pressure if I'm commuting though since it will wear faster with lower pressure. On the track when I used to run PP's I would start with 29f 28r psi cold and I got great wear and handling out of them but the pressure rise when hot got them up to 33psi hot. The Pirelli's I run now start at 27f 26r cold. The psi molded on the side of the tire is an inflation pressure when your operating at max load.
0
#3 User is offline   Gap Trash
  • Race Team Owner
  • PipPipPipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::1995 VFR 750
    92 F-150 4X4 extended cab
    1997 Toyota Avalon
    2008 Suzuki DRZ 400 SM
Thank You's: 0
Neutral
Posted 17 February 2008 - 10:17 PM
I've been told that I'm somewhat anal about my tire pressure. I am known to adjust tire pressure quite often. I normally run about 34 on the street when I am riding some hard twisties. If I have to get out on the interstate BLAH, I run the highest pressure possible, usually about 42. I will run about 40-42 when commuting, but when it comes down to it I'm probably going to commute at whatever the last pressure in my tire was, just depends on the last thing that I was doing. If I am on the track I'm going to run 30-32, just depending on the conditions, ask around at the track and see what pressures others are running and what kind of feedback they are getting. BTW I keep a small analog gauge under my seat.
[color="#FF0000"]:Andrew:
2008 Suzuki DRZ-400SM, rejetted, 3X3 airbox mod, uncorked exhaust! Acerbis handgaurds.
1995 VFR 750
Current Mods: Hindle Carbon Fiber Slip on, BMC Air Filter, Corbin Seat, Silver Star Bulbs, RaceTech springs, -1+2 520 chain conversion, rejetted, fresh Ferrari red custom paint.
Posted ImagePosted ImagePosted ImagePosted Image
Ride with Gap Trash: smokeymountainmototours.com
0
#4 User is offline   sigsauer33
  • Kill or be Killed
  • PipPipPipPip
  • View blog
  • View gallery
  • Group: Members
Thank You's: 0
Neutral
Posted 17 February 2008 - 10:30 PM
Some nice info here thanks a lot for the quick reply!
-Sig
USMC
SEMPER RIDING
SEMPER DEPLOYED
Posted Image
0
#5 User is offline   jeremy556
  • I AM THE STIG
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::02 ABS
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 17 February 2008 - 10:37 PM
Honda recommends 36/42 f/r, IIRC. In twisties I run 34/38 or so.
Posted Image Posted Image Posted Image
0
#6 User is offline   MuddDawg
  • Gear-Driven
  • View blog
  • View gallery
  • Group: Forum Contributor
  • In My Garage::2000 VFR 800
    2005 DRZ 400S/SM
    2002 XR100R (Son's)
    2001 XR-70R (Daughters's)
Thank You's: 1
Neutral
Posted 17 February 2008 - 11:29 PM
My question is what does the Motorcycle manufacture know about whatever tire your running? Shouldn't you go by the tire manufacturer's recommendations since they designed the tire with whatever rubber compound?
Posted Image
0
#7 User is offline   wera803
  • Rolling Chicane........
  • View blog
  • View gallery
  • In My Garage::2001 Red VFR, 2006 GSXR600
  • Signed Flaf:
Thank You's: 3
Neutral
Posted 18 February 2008 - 08:16 AM
They don't know. They recommend the pressures for the one or two tires they recommend for the bike. Of course how does a tire manufacturer know what bike you are puting the tires on either?? Should the pressures be the same for a Hayabusa and GSXR-600?? There is quite a bit of weight difference between the two.
I think it is just one of those things that you have to play with to see what works best for you, your bike, and your riding style.
-My life style determines my death style.
2001 Red VFR - Garmin Zumo 550, Autocom, Valentine One, Heli-bars, Corbin Beetlebags, Corbin Seat, Givi Trunk, Puig Double Bubble Windscreen, AK-20 Axxion Cartridge Kit, Wilbers Shock, Heated Grips, Sargent tank bra, Powerlet outlet, air horns, Datel Volt Meter, VFRness, Vista Cruise, K&N Air filter, PCIII, Micron Slip-on, Cat-less exhaust, 16 tooth front sprocket, Factory Pro Evo Shift STAR kit, Blue Sea fuse box, bar-end helmet locks, Silver wheels, black rotors, Radar's frame sliders, Speedohealer, and Pro-grip grips.
2006 GSXR600 - Track Bike
Previous bikes.......
1997 GSXR750, 1997 Red YZF600R, 1999 Black VTR Superhawk, 1993 White VFR750, 1995 ZX-6R, 1989 FZR600, 1996 GSXR1100, 1978 GL1000, 1975 Yamaha 650
Posted Image
0
#8 User is offline   jeremy556
  • I AM THE STIG
  • View blog
  • View gallery
  • Group: Volunteer
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 18 February 2008 - 09:51 AM
They don't, but the tire manuf. doesn't know what bike you are putting it on either and it's power, weight, etc.
I also don't know of many tire companies that give recommended pressures at all (except race tire distributors). The pressure listed on the sidewall is a maximum pressure, not a necessarily recommended one.
0
#9 User is offline   spud786
  • Race Team Owner
  • View blog
  • Group: Members
  • In My Garage::2006 interceptor abs
Thank You's: 4
Neutral
Posted 18 February 2008 - 11:03 AM
33psi cold is bout the lowest I run on the street on the front, that way I go blow through potholes and such without rim damage , any where around 40psi on the rear
0
#10 User is online   Monk
  • Race Team Owner
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::Honda VFR 08'
    Jeep Wrangler 94'
  • Signed Flaf:
Thank You's: 37
Excellent
Posted 24 May 2009 - 10:58 AM
Take the cold tire pressure.
Ride the bike normally to heat up the tires...
Take the Hot Pressures of your tires.
You should be looking for a 5 % to 10% increase from cold to hot.
If you have more than 10% increase,,,, add air.
Example:40x5% is 2 pounds air ; 40x10% is 4 pounds air.
So if it reads 45 pounds of air. I need to add enough air ( how much ? ) to keep it under 10% increase ( 1 pound at a time,till I know what MY bikes cold tyre pressure is on a average temp. day ).
This is a tyre formula that was posted on here somewhere. Now I've been playing with it the last couple of days, and for it to work on my bike I've had to go up to 44lbs. on the rear cold to keep it under 10%(4 lbs.) when warm. The front tyre is right on at 36, and is only 38 warm(5%).
What I'm wondering is 42lbs. is suppose to be the max, but it runs cooler at 44 (according to formula). P.S. I weigh 230 lbs......
Has anyone worked with this "type of formula", and to what results?
I'm also 50/50 smooth to bumpy roads so I'm wondering about lack of tyre flex?
Anyone have any ideas? ..... Monk
This post has been edited by Monk: 24 May 2009 - 10:59 AM
Monk (John)
Riding defensively is a pro-active must. VFR MOD's : PuppyGrips;ThrottleBoss;NepThottlelock;LowCutBra;BubbleMirrors;HondaBags;GPS TomTomRider2ndEd(Powered,W/Tightwad'sPowerletSystem);SargentSeat w/silver piping;StockWindscreenW/LaminarLip;
3-M BlackReflectiveTape;FirstGearSilverMiniTankBag;GezaHalfCover;AxioSilverHardshellTailbag;
HeldSpeedySeatBag;KuryakynLEDBatteryGauge;TyresMichPR2's;NWS Hugger;RedWheelTape;RedRadiatorGrills;CustomWinterGripCovers;
Posted ImagePosted Image Posted Image
0
#11 User is offline   Ryanme17
  • Race Team Owner
  • View blog
  • View gallery
  • In My Garage::2002 VFR800A, 1969 Plymouth Roadrunner.
Thank You's: 5
Neutral
Posted 24 May 2009 - 11:39 AM
What is bad about a 10% increase in tire pressure? A 3-4 pound increase in PSI is completely normal as the tire heats up. So what's the problem with that? If I'm running 34 psi I expect it to gain more than 3.4 psi as it warms up...
Also, although pressure does affect tire shape and contour, the main thing that affects traction is the heat of the tire. Hot tires grip better and wear quicker. Cold tires don't have as much grip but last longer. Lower pressures heat up quicker and stay hot through the twisties. Higher pressure tires might never get up to temp. Most people lower their tire pressures to run a track day or in the twisties. Obviously this is only affective to a point. If you're running only 20 psi your tire will handle worse than it will at 28 or 30 psi.
Ryan.
2002 VFR800A.
0
#12 User is online   Monk
  • Race Team Owner
  • View blog
  • View gallery
  • Group: Volunteer
    Jeep Wrangler 94'
  • Signed Flaf:
Thank You's: 37
Excellent
Posted 24 May 2009 - 02:28 PM
[/quote]
[/quote]
I saw this formula and thought I'd try it. I took it out for a ride with the "quote/unquote" proper cold/hot settings today. As I said the front comes out ok with 36 cold.
The rear is much to hard/bouncey, so I'm going back to 42 cold.
The formula wasn't trying to stop the temp. from going up, it was just trying to put it in the correct range.
I was gaining 4.5 at 42 cold ( I'll just stay with it, I haven't had any problems at 42 cold).......... thx...... Monk
Monk (John)
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
