Adding Superbike Bars To Your Bike
#41
Posted 13 June 2012 - 02:53 PM
If you want to go middle-of-the-road on price, buy the Spiegler bar and extended line kit as spec'd in their kit. Then adapt to your triple clamp using your own aftermarket risers.
Sebastian Live to mod, mod to live... the best you know is the best you've ridden... adventures suck when you're having them...
2005 VFR800 - Winning Red -- 1996 VFR750 - secret project -- 1995 XR250R - little beasty
1983 VF750F - hot rod resto -- 1981 CB900F - hot rod build/resto -- 1976 BMW R60/6
-- 1996 XR400R -- 2000 XR70R -- 2003 CRF150F
Gone but not forgotten - 01 F4i - 84 VF500F - 02 954 - 96 VFR750F![]()
#42
Posted 13 June 2012 - 03:05 PM
Tag or Driven brand risers are a good place to start, bars are pretty universal, as long as the riser and bar sizes match. 7/8" vs 1 1/8"
Thanks Seb!
Looking on ebay Tag didn't really show up, I'll try the other.
I bought a set of these, they are 22mm rise so i'm not sure of what bend of bars I would want or need yet.
http://www.ebay.com/...984.m1497.l2649
I was thinking of wider flatter bars to get more leverage on the bars (less effort) and even more upright than my Heli's.
Guess I need a Wing!
BR
02 VFR w/99,000 miles plus! Penske, revalved forks, V1, PP/PR2's
Thinking about a valve check at 100k, NOT!
#43
Posted 13 June 2012 - 03:17 PM
You'll need a new pair of mounting bolts, those are too long. No big deal, you just go to the hardware store for the bolts, then load them in your poor man's lathe.
The riser bolts have a "D" shape so you need to turn down the hex head and then grind a flat on it. Just use the old ones as a guide like I did here:
#44
Posted 13 June 2012 - 03:38 PM
#45
Posted 13 June 2012 - 09:37 PM
If you're born in America, you get a front row seat.
George Carlin
#46
Posted 13 June 2012 - 10:51 PM
LOL!
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle’s handling, stability and braking, making it unsafe to ride.
#47
Posted 13 June 2012 - 11:53 PM
Choke cable is an issues so still hunting for the long ones.
#48
Posted 14 June 2012 - 05:22 AM
Interesting lathe Seb. I see you have met Necessities Mother of Invention.
Cheers Lee, I have a real lathe now but the press worked the few times I really needed it! I also used it to kill a couple things, but that got kind of hairy at times.
#49
Posted 14 June 2012 - 06:12 AM
#50
Posted 14 June 2012 - 03:42 PM
With the ST1100 cables I am stuck because the bracket that holds the threaded ends in place is too far. I took it to my fathers machine shop and brought it forward about an inch, but I haven't had a chance to install yet because of work. For the choke you can try removing the airbox and rerouting the cable directly to the left handle bar on top of where the throttle cables run through to goto the right hand side. I tested this from lock to lock with my spiegler kit and it does not bind.
That's because the carb bike cables have more free length in the cable. (ST11 was FI, right?)
Check to make sure you get 100% throttle use with that cable.
Rules
