From http://www.motorcycl...read.php?t=3737:
Roger from The Motorcyclist Cafe Forum said:
I have decided to someday soon buy a Nomar tire changer, however I had already started the mods on my HF machine, so I finished them.
Here's my HF in stock form, with my MoJo lever from Mitch, it works pretty good BTW, once you figure it out.
I coated the rim hold downs with the plasticote you see and an old inner tube. Worked OK, but we can do better.
Here's the FrankenRog HF machine now:
Please excuse my messy garage
I ground off the rim scratching hold downs
I did manage to set my golf bag on fire...just a couple of small burn holes.
Safety Note...DON"T do this in shorts....I know better, but stupidy came over me, I WAS wearing my safety glasses.
Here's the HDPE (high density polypropylene plastic) I used and the now scratch free rim hold downs
That's right...a 1/2 cutting board...2 for 7 bucks at the local grocery store. I cut it up and glued them together to make a block 1 1/2" thick.
I put a 5/8 inch radius in the block, be perfect to hold the wheel
one 1/4 bolt to hold it on...it's solid. I always used a ratching tie down to keep the wheel from spinning in the hold downs, and I might not need to now.
Breaking the bead is a great way to scratch a wheel..DAMHIK...so I covered that also
You can't see it, but all the bolt heads are recessed, no metal will come in contact with the wheel at any time during the tire change.
As far as my pivot point for using the MoJo lever, it is a 3/4 OD thickwall pipe. 3 feet long.
That bad boy is solid....I dare you to bend it. Now you can walk the lever around the machine without that arm in the way.
I have 3 anchors sunk into floor of my big garage to mount the machine to during a tire change.
I'm thinking this HF machine might work pretty good now. Feel free to copy my ideas, or add to them. Did I leave anything out?
All these mods cost me less than 25 bucks, and a few hours of my time.
I'll do a tire change pictorial soon.
Yeah!!! Pretty awesome.
Help
MultiQuote
