Heated Grips Who Has The Best Price/quality?
#1
Posted 24 September 2007 - 07:49 PM
#2
Posted 24 September 2007 - 08:19 PM
"If everything seems under control, your just not going fast enough" Mario Andretti
current bikes
02 VFR BLACK, 77,050 miles(no Valve check yet), SB-II exhaust , 15t, Penske w/20kg, AfterShocks forks w/.95 kg, V1, heated grips, Pilot Power front/ Road 2 rear, No surge or Vtec transition problems! Mobil 1 15w-50 or Shell Rotella T Syn., Buell pegs.
01 VFR (brother's) crashed
07 GSXR 750(SOLD!)
02 F4i Track Bike(GONE!)
93 Yamaha WR250(in a box)
04 VFR track pig project(fast & crashed)
#3
Posted 24 September 2007 - 08:34 PM
scout18, on Sep 24 2007, 06:49 PM, said:
I ride through all kinds of nasty cold weather, including the occasional snow in Alberta. Down to 0C, heated grips are fine, below freezing, heated gloves are in order. I use "Hot Grips" http://www.hotgrips.com/. Good quality and you never have to remember to bring them (which is an issue with heated gloves). Heated grips do nothing about the back of your hands.
For gloves I used heated units from Widder which are ok. There is a significant loss of throttle feel with heavier insulated gloves, but it is also hard to get much throttle feel when your hands are frozen.
I use an Airvantage electric vest from Rider Wearhouse. You put it on and blow it up and it fits perfectly. Great unit. http://www.aerostich.com/catalog/US/Aerost...st-p-18911.html (expensive).
For wiring everything up, I got a great 5 fuse pannel from Rider Wearhouse (the Areostitch people). It mounts perfectly under the seat beside the rear brake resevoir. Use a relay (so that the unit is only energized when your bike is on) and take the power directly from your battery).
Stay warm
2002 VFR
#4
Posted 24 September 2007 - 08:37 PM
Dutch Photographic
VFRD Rallies:
Elka 3-Way Shock, Race Tech Front Springs, Sargent Saddle, Gutted Exhaust, Throttlemeisters, Symtec Grip Cookers, Centech Fuse Block, Powder Coated Various Parts, Zero Gravity Dark Smoke Windscreen, Speedohealer, Lightech Billet Gas Cap, Beltronics Vector 995(Stealth Mount), Marc Parnes LEDs, Honda Side Cases, Ken's Luggage Rack(Flush Mounted), Honda Top Case, Light-n-Bolts, Clear Lens Swap, Stebel Nautilus, Custom Fender Eliminator,
#5
#6
Posted 25 September 2007 - 11:05 AM
This is where I got mine right down the road from work, Once you get heated grips you will love it! Very easy to install. Good Luck
#7
Posted 25 September 2007 - 11:18 AM
I just noticed that the Symtec kit, from CA Sport Touring seems to have the same componants, yet it already comes with the rocker switch for less than the price of the dual star kit that required the rocker switch be added on at an additional charge.
Has anyone seen the two kits side by side in person?
#8
Posted 25 September 2007 - 11:19 AM
#9
Posted 25 September 2007 - 11:22 AM
dutchinterceptor, on Sep 24 2007, 09:37 PM, said:
1983 VF750F 2,997 original miles, undergoing full hot-rod restoration- K&N, Accel coils & wires, Megacycle Stage 1 cams, jetted, Works shock, CBR F2 wheels, VF1000R forks, RaceTech Gold Valve Emulators, Sonic 1.0 springs, Chevy S-10 'clear' headlight, fender chop, Maier dark smoke screen, Vance and Hines full 2-2 system, 96 VFR clip ons, much more in the works!
1986 VFR700F 900RR forks w/ Racetech .90's, CBR F3 front wheel, 900RR rear wheel, PARTING OUT - PM FOR PARTS INQUIRIES
198x VF500F GONE
1996 VFR750 frame and swingarm, possible track bike?
1996 VFR750 secret project...
1996 VFR750 31k miles, K&N, otherwise stock - SOLD
2001 CBR600F4i GONE
2005 VFR800 Sargent seat, NEP throttle lock, Symtec heated grips, Powerlet, DIY fender eliminator, oem hard bags, modded passenger pegs, Garmin Nuvi 750, Ohlins 46DRS, .90 RaceTech fork springs, Staintunes, Rivcyko double secret probation CF hugger, CF Bug Buster, UNI filter mod, PC3 USB w/ Cozye's map, Speed Bleeders, ATE Super Blue brake fluid, coming soon - RaceTech Gold Valves, catless headers, VFRness &...
***Bailey-san sez, zip-tie a rim protector to your HF bar on your HF changer to keep from scratcha rim***
#10
Posted 25 September 2007 - 12:50 PM
JMOs
Beck
95 VFR
#11
Posted 25 September 2007 - 01:10 PM
#12
Posted 25 September 2007 - 02:11 PM
ZoomerAB, on Sep 25 2007, 01:34 AM, said:
+1 on Hotgrips They are a local company here in NH (close to where WDGAH is held). I added the variable valve controller to allow more choice than high/low/off. The controller allows you to set the temperature like you would on a heater in your car, just turn the knob.
Cost a bit more, but I've never had a problem in 4+ years
00 VFR800
#13
Posted 25 September 2007 - 02:23 PM
Heated grips and vest are a must for multi day trips in the cold. I wired them into a relay controlled aux fuse box.
#14
Posted 25 September 2007 - 02:46 PM
#15
Posted 25 September 2007 - 03:53 PM
Have thought about heated grips but like having the heat on the back of my hands so I opted for the heated gloves instead.
GypsyCat
#16
Posted 25 September 2007 - 05:21 PM
Thanks
#17
Posted 25 September 2007 - 11:17 PM
#18
Posted 25 September 2007 - 11:38 PM
Tim
#19
Posted 25 September 2007 - 11:56 PM
I am going to give them a try this winter and will report back as to how the install went and how they work.
http://www.symtec-in...m/heatdemon.htm
#20
Posted 26 September 2007 - 01:47 AM
Beck, on Sep 25 2007, 06:50 PM, said:
FYI, the individual ST1300 heated grips (UKP31 ea.) and controller are available separately from Honda (if not in the USA, then at least from David Silver Spares in the UK). The rather expensive kit (UKP160) also includes some wiring, wire ties and different bar ends. (The electronic controller isn't cheap, but it sure is nice!) I installed them on my ST1300, which is actually the bike they were designed for, but I'm sure they'll fit others.
Ciao,
So.Cal., USA/London, UK
http://www.vsource.org
RS250; CBR400RRN; RVF400RT; VFR400RL; VFR444RN; VFR750FL; VFR800FiY; VFR837FP; CBR1000FP; ST1300A4 (and counting...)
#21
Posted 26 September 2007 - 01:52 AM
was very cheap on ebay, see cyclebitz I think, mine was a lucky $39 , a great kit
http://www.youtube.c...h?v=2mTLO2F_ERY MR W
http://www.youtube.c...h?v=i8FXBnzTqCs James Bond Chase xt500s
#22
Posted 28 September 2007 - 06:58 PM
#23
Posted 28 September 2007 - 07:38 PM
That looks pretty good! I like the look of those controls.
Might be a bit tricky to drill the holes for the wires on the aluminum clip-ons. Note that these are shown installed on regular tubular bars. Still something to check out though, just in case it could be made to work on VFRs.
Beck
95 VFR
#24
Posted 24 October 2007 - 07:04 PM
#25
Posted 24 October 2007 - 08:22 PM
Titanium Two Brothers C5 S/O, K&N Airfilter, Hotgrips, Sargent Seat, Power Commander III, Barnett Kevlar Clutch By Dave Dodge
Odometer reading as of 1/16/08... 32,803 miles and counting.
#26
Posted 24 October 2007 - 08:32 PM
Beck, on Sep 25 2007, 05:50 PM, said:
JMOs
Beck
95 VFR
Just read this for the first time. What did you do?
Here is a source for cheaper ST1300 grips. Lots cheaper but still pricy.
hondadirectlineusa.com
I bought my Honda grips for the Goldwing from these folks - works great with big lettering for the demographic
Controller on the right!
I happy with the Symtec heaters on my VFR but you never know..............
#27
Posted 29 October 2007 - 10:36 AM
Help
MultiQuote
