VFR Discussion: 929/954 Shock Install (5th Gen) - VFR Discussion
  • (6 Pages)
  • 1
  • 2
  • 3
  • Last »
  • You cannot start a new topic
  • You cannot reply to this topic
929/954 Shock Install (5th Gen) How-To Rate Topic: -----
#1 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Group: Forum Moderator
  • In My Garage::2010 Honda GL800RR-SP2
    Back in business baby!
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 13 December 2005 - 05:46 PM
Posted Image
Reason, the 954 shock has a remote oil reservoir that makes the oil last longer and regulates heat better, also the shock is fully adjustable. The vfr stock shock only has rebound adjustment and not compression, also it does not have a remote oil reservoir.
OK, never one to let fear and good judgment stand in my way, here we go:
Prop up tank and undo the upper shock mount:
Posted Image
Undo the bolt that holds the top mount to the shock:
Posted Image
Undo the lower triangle linkage:
Posted Image
Jack up the swing arm for clearance:
Posted Image
Out she comes:
Posted Image
954/VFR shocks side by each:
Posted Image
VFR upper shock bracket with bolt removed, plus 954 shock bracket for reference, man is that hollow bolt ever beefy:
Posted Image
Need to extend the VFR upper shock bracket approximately 42mm, so I got a 1/2" extra-heavy pipe collar, shortened it to suit like this:
Posted Image
It was bolted together in preparation for welding.
After welding and painting:
Posted Image
An M10x120mm bolt was needed to hold the modified mount in place. You'll note the washer, trimmed to clear the frame cross member. This is because I didn't want the pipe collar bearing directly against the aluminum frame, I wanted to spread the load over a larger area, hence the washer. Plus, I deliberately cut the collar a tad short so I could make up more ride height as required, limited by the lower dog bone/shock eye clearance issue. I found I'll need at least two more washers added:
Posted Image
Posted Image
I wound up shortening the bolt to 114mm, cleaned up the end threads with a die plus I ground down the bolt head to .175" (for adequate clearance of the upper shock eye) which is still thicker than the stock VFR mount bolt head was. Also used a Nylock nut to keep things attached.
Reinstall modded upper mount, bolt shock into place:
Posted Image
Reattach the triangle linkage:
Posted Image
Voilà! Shock install complete! Actually, I still need to add another couple of shims. Ride height is not quite where I want it.
Posted Image
Rob McKinnon
'99 GL800RR-SP2
http://s13.photobuck...eefer800canuck/
Quote
We strongly recommend that you use only genuine Honda accessories that have been specifically designed and tested for your motorcycle. Because Honda cannot test all other accessories, you must be personally responsible for proper selection, installation, and use of non-Honda accessories.
Quote
We strongly advise you not to remove any original equipment or modify your motorcycle in any way that would change its design or operation. Such changes could seriously impair your motorcycle's handling, stability, and braking, making it unsafe to ride
0
#2 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 13 December 2005 - 05:49 PM
I had originally done Ver 1.0 of the upper mount:
Posted Image border='0' alt='user posted image' />
But I decided it wasn't beefy enough, only 3mm wall thickness, and the OE shock bracket is 5mm.
So I fabbed Ver 2.0, but there's a wiring harness right there, and I was concerned about rubbing with the square tubing:
So ultimately I went with Ver. 3.0 which has 6mm wall thickness and no possibility of rubbing on the wiring harness:
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#3 User is offline   dr.toto
  • Dr.toto
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • In My Garage::99 VFR800, 05 cbr1000rr, 02 Dr650
Thank You's: 0
Neutral
Posted 13 December 2005 - 11:49 PM
The 2 differences in the 954 and 929 shocks are: spring rate and location of the gas canister. I used a 954 and changed it out for the 929. I only weight 140 lbs. The spring rate wasn't a problem. The 929 canister is farther away from the exhaust pipe. I felt more comfortable about that. The tech at Penske said that the oil temp in the shock is more controlled by the usage of the shock rather than it's environment. Either works fine.
0
#4 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 14 December 2005 - 07:45 AM
VFR2X, on Dec 13 2005, 07:40 PM, said:
Nice write up, very well informed. Question didn't the 54 shock resivoir get in the way? must not have or you would have said something. also this is on your VFR right?? Hmm wonder what is different between yours and a 4G? still a good job explaining.
<{POST_SNAPBACK}>
Well, the reservior is sort of close to the exhaust system, like slightly less than an inch.
If you rotate it, there's interference between the plastic undertray and the reservoir, plus the damping adjuster screws would then face the wrong way and be obscured.
I thought about spinning the shock, but the part of the plastic undertray that interferes is a shield for the main wiring harness to/from the rear of the bike (ECU, etc) and I didn't feel comfortable cutting that away. Also there's a mount for a fuse ahead of the battery that sprouts off that plastic and you'd lose that too if you cut it away to make clearance for the reservoir.
ULEWZ, on Dec 13 2005, 07:34 PM, said:
Very nice. I wonder if the spring is heavy enough as the 954 weighs about 100 lbs less then the VFR.
<{POST_SNAPBACK}>
All in all, on a 5th gen, a 929 shock would probably be a better choice, fitment wise and spring rate wise. 929=15.3kg/mm, same as the VFR, 954 = 14.6kg/mm
As for the 4th gen, I can't say. Probably possible, but somebody else will have to chime in.
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#5 User is offline   BaileyRock
  • Back in the Saddle!
  • View blog
  • View gallery
  • In My Garage::02 Vtec
    04 vtec track pig
    07 SYM Fiddle 50
    about 3 bikes worth of pieces!
  • Signed Flaf:
Thank You's: 29
Excellent
Posted 14 December 2005 - 11:03 AM
Nice post Rob ! :thumbsup:
For my spacer, I just used a piece of 1" aluminum 6 sided bar stock(solid) and drilled a hole in it for the bolt. Light, strong, easy.
Posted Image
:thumbsup:
I also agree the the 929 shock is the better way to go for this swap !
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
"If everything seems under control, your just not going fast enough" Mario Andretti
current bikes
02 VFR BLACK, 77,050 miles(no Valve check yet), SB-II exhaust , 15t, Penske w/20kg, AfterShocks forks w/.95 kg, V1, heated grips, Pilot Power front/ Road 2 rear, No surge or Vtec transition problems! Mobil 1 15w-50 or Shell Rotella T Syn., Buell pegs.
01 VFR (brother's) crashed
07 GSXR 750(SOLD!)
02 F4i Track Bike(GONE!)
93 Yamaha WR250(in a box)
04 VFR track pig project(fast & crashed)
0
#6 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 14 December 2005 - 12:11 PM
baileyrock, on Dec 14 2005, 10:03 AM, said:
I also agree the the 929 shock is the better way to go for this swap!
<{POST_SNAPBACK}>
:beer: Like this one perhaps:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=4596249503
This post brought to you by Safe-T and Auctionsniper.com :salesman:
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#7 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 14 December 2005 - 03:42 PM
rmcobb, on Dec 14 2005, 02:15 PM, said:
If a guy was going to get the 929 or 954 shock resprung and revalved, is the 929 still a better way to go than the 954......or does it matter?
From what I've been picking up, it seems that the 929 is easier to fit??
Randy
<{POST_SNAPBACK}>
It's all in the way the reservoir faces.
See this post here for pics:
http://www.vfrdiscussion.com/forum/index.p...ndpost&p=186175
I thought I could find a way around it, and 954 shocks are newer, with the possibility of finding a mint one easier, so I got one, but there isn't an easy solution to the reservoir interference without cutting the undertray. Even then, the adjuster screws would face the wrong way and be obstructed.
But yea, 929 is a better fit physically and spring rate wise.
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#8 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 14 December 2005 - 05:14 PM
FotoMoto, on Dec 14 2005, 03:48 PM, said:
You can back off the pre-load, place the top end in a vice or somehow restrain it, thread a screwdriver though the eyelet of the bottom end, and rotate the bottom 180.
<{POST_SNAPBACK}>
The problem still remains that either the 954 shock reservoir will reside close to the rear cylinder's exhaust pipes if faced to the right, or interfere with the plastic undertray ahead of the battery if faced to the left. I thought about facing it rearward by rotating the upper shock mount, but that puts the compression damping adjuster screw facing the aft cylinder head.
And rotating the lower shock eye only moves the rebound damping adjustment screw, not the compression damping adjustment screw which is located at the top.
None of these problems exist with the 929 shock. So I'm switching to the 929 unit as soon as it arrives. Good thing they're cheap and plentiful. 26 bucks!
Dr. Toto made the call on the 954 shock interference and I thought I could carve out a way around it, but not without making compromises I didn't feel comfortable with. The interference between the reservoir and the undertray when faced to the left is greater than 1/2", maybe closer to 3/4"
Isn't Bodging fun??? :rolleyes:
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#9 User is offline   COS_VFR
  • Factory Team Rider
  • PipPipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::'96 VFR 750 Red
    '83 XJ650LK Silver (Yamaha)
  • Signed Flaf:
Thank You's: 0
Neutral
Posted 19 December 2005 - 01:33 PM
I am planning on doing this mod over the winter. I have been thinking of making an adjustable spacer. What do you think?
shock spacer
The outside dimension is 25mm across the flats. The small hole is 10mm threaded to fit the bracket mounting bolt. The Large hole is 18mm threaded to provide the adjustabe length. Minimum length is 30mm. Maximum is approximately 42mm with the half of the threaded portion inside. My first choice for material is aluminum since it would be easy to machine. Not sure if it would strong enough.
What do you think?
Gordon 96 VFR
No sense in being pessimistic, it wouldn't work anyway.
Posted Image
0
#10 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Post icon  Posted 30 December 2005 - 04:42 PM
So, I went out and installed the 929 shock in place of the 954 unit today.
I feel somewhat better about having the correct spring rate, (15.3kg/mm Vs 14.6) and a lot better about how the reservoir is not so close to the exhaust system anymore. Good thing EBAY CBR shocks are cheep!
What I did discover was that the 929 shock is approximately 4mm longer than the 954 shock. At least the Erion 929 unit is. (The one with the white spring Vs. yellow)
I slid the shock home without tightening up any of the bolts and checked the unweighted ride height with the longer shock and modded upper mount. I had wanted to increase it further after the initial install of the 954 shock, so with the longer unit, it seemed prudent to check first.
I wound up with 12mm more ride height as compared to stock but I figured I could still obtain a tad more yet, so I removed the shock and upper mount again and added a second washer in addition to the one shown in this pic:
The second washer all by itself gave me approximately 3mm more ride height.
Glad now that I made the modded upper mount on the short side to begin with.
There isn't really any easy way to increase it further, I could possibly slide in 1 more washer without having the lower shock eye contact the dogbone, but the forward mounting bolt of my hugger would contact the inside surface of the LH peg bracket. I could remove the peg bracket and relieve it in that spot, but it didn't seem important enough to try. Also, with a new rear tire and full tread, the rear tire will probably be either only a couple mm off of or maybe even lightly resting on the ground with the bike on the centerstand anyway. Can't go much more than that in any practical sense.
SO, after all is said and done, I've got 15mm more rear ride height than stock and 11mm less ride height in the front. Mind you, this is completely based on unweighted measurements IE: wheels totally off the ground in each case, measuring from the axle to a reference point on the frame.
This should nullify the effects of the greater trail from the RC51/954 triple clamps and once I get a fresh rear tire it should steer as quick as or quicker than stock.
Hurry Spring! :wheel:
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#11 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 31 December 2005 - 01:52 AM
Barmy, on Dec 30 2005, 11:39 PM, said:
Wonder if I might ask a couple questions, since I now have time to work on the VFR. Mine ('98 purchased in september) is purported to have been computracked and modded. I do think my rear is higher, and it has an Ohlin shock. Apparently, the dogbone and lower bracket are off a 929 which some suspension guru did.
Did you use the other components, or just the shock?
Are there a part numbers stamped on the components that allow me to verify the orignal application?
Lastly, is the purpose of your mod simply to gain a more efficient shock, or are you "tweaking" things for handling?
Thanx, Rick
<{POST_SNAPBACK}>
The shock is off an Erion edition 929, the triangle linkage and dogbone are standard VFR800 items.
The 929 coincedentally has the same spring rate as the VFR, 15.3 kg/mm
The reason for the shock install is to complement the front end which has been swapped out for RC51 forks and brakes.
The 929 shock is 3-way adjustable and has the same stroke length as the VFR shock.
So I gain compression damping adjustment and an external reservoir.
I'd surely like an Ohlins or HyperPro or WP shock, but this rear shock is a real bargain compared to an aftermarket unit.
Maybe eventually if I find a used shock in good shape I'll pick it up, but I didn't have a grand for Ohlins or even 500 for a HyperPro. Translate that from USD to Cdn and it's $$$ quick.
And raising the rear ride height is to compensate for the increased trail due to fitting the RC51/CBR954 triple clamps.
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#12 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 01 January 2006 - 03:35 PM
Barmy, on Jan 1 2006, 01:33 PM, said:
OK, thanx. I kinda understood, but I am new to the VFR fold. Just sold my BMW RT.
P.S. That's nice, but are you sure you can still call it a VFR?? :lol:
<{POST_SNAPBACK}>
Actually, i'm calling it a GL800RR-SP2 now. :goofy:
GL = Goldwing for the touring mods
800 = obvious
RR = for the performance mods
SP2 = for the RC51 forks
Hope you enjoy the smoothness of the VFR. I rode passenger on a BMW Boxer once and I'm not sure how anyone could stand the vibration. I figured an opposed motor would be smooth, but I guess it needs to be a 4 or a 6 like the 'wing or a Volkswagen or a Subaru.
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#13 User is offline   dude
  • The Flaf Originator!!!!!!
  • View blog
  • View gallery
  • Group: Forum Contributor
  • In My Garage::A lot of crap
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 09 January 2006 - 01:47 PM
Hey Doc
Heres a side by side comparison. The springs are the same diameter.
929 shock
2000, Staintune highmount, Sargent Seat, K&N filter, Metzler z'6's, Gorilla Alarm, Ek Gold Chain, ZG DB Screen, All Balls Tapered Bearings, Fenderectomy with LED light, Givi Top Box, EBC brake pads, pro grip 719's, 929 rear shock mod, vista cruise throttle lock, stickerless
0
#14 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 12 April 2006 - 01:05 PM
TurboPackMule, on Apr 12 2006, 11:57 AM, said:
Is it just me, or does that 929 shock look wayyy shorter than the original?
You ever get this sorted? (I see this post is several months old...)
<{POST_SNAPBACK}>
Yes it is shorter, but has almost identical shock stoke length. IIRC, 57mm Vs 58mm
It's shorter because of the design on the shock, Internal reservior for the VFR Vs external reservior for the CBR.
The longer upper shock mount takes care of the difference in length.
It's sorted (using a 929 shock, not a 954) and working fine in the limited ride time I've had (75km).
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#15 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 25 April 2006 - 07:09 PM
bigguido, on Apr 16 2006, 01:34 PM, said:
Will a SHock from a 2002 gixxer 1000 work seems to look the same as the 929?
<{POST_SNAPBACK}>
I have absolutely no idea. Let me have a look.
<disappears into the internet>
:joystick:
<reappears armed with facts>
:idea3:
First off, the '99 VFR shock spring rate is 15.3kg/mm, the 929 is coincidentally, exactly the same.
2002 GSXR1000 is only 7.7 kg/mm.
So right off the hop, your spring is like half as stiff as it needs to be.
Need: new spring. And revalving to suit said spring.
Length: GSXR shock = 329mm, which is longer than a VFR800 shock by 4mm. Probably would fit and raise the rear of the bike by approx. 10mm overall with the stock upper shock mount. This is a good thing in and of itself.
Shock stroke length, GSXR= 74mm Vs VFR800 which is only 58mm.
So you'd have waay too much wheel travel and the swingarm would extend upwards too much at full compression. Like an extra inch and a half more upwards travel. 6.6" Vs 5.1" Not good.
The only way I could see it working is to respring the shock, revalve it for the new twice as stiff spring, and fit some sort of internal stop to limit the shock's travel to 58mm of stroke.
Probably it's doable by a professional suspension shop like Racetech, Aftershocks, Lindemann, Traxxion, etc, but by the time you did all that, you could buy an aftermarket shock and be off riding.
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#16 User is offline   Trace
  • Railer of the Interstates
  • View blog
  • View gallery
  • Group: Volunteer
  • In My Garage::2000 VFR
    2000 RC51
    2003 Z-06
  • Signed Flaf:
Thank You's: 7
Neutral
Posted 25 April 2006 - 08:29 PM
<{POST_SNAPBACK}>
Oooh....oooooh! I have a picture like that! [of course, I learn't it from veefer, HS, BR and other pioneers here! :thumbsup: ]
Finished Shock Extention Tack Welded to OEM Bracket, and with Top Washer Tack Welded too, for Load Bearing on Frame Mount, and a Flat Spot on Washer for Clearance at Mount
Pokes with stick.
0
#17 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 26 April 2006 - 02:55 PM
magellan, on Apr 26 2006, 12:33 PM, said:
Okay, shop monkeys, it's time to stop showing off welding skills and talk about seat of the pants riding impressions!  :P
Is there significant improvement in feel and control?
<{POST_SNAPBACK}>
Well, the ride is certainly more "taut" for lack of a better description.
I still haven't foodled with all the adjustments yet. I've only been through one tank of fuel so far this year.
I've basically got the 929 shock set at the factory default settings (for a 929 that is).
When I get some more time, I'll mess with it more. But I have absolutely no idea when I'll have more time. :pissed:
Somebody wanna send me some? :joystick:
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#18 User is offline   vifferluv
  • The Ultimate Slow Poster
  • PipPip
  • View blog
  • View gallery
  • Group: Members
Thank You's: 0
Neutral
Posted 27 June 2006 - 12:20 AM
Rob, thanks for your great write-up! I was inspired by reading it and decided for this season to upgrade to a 929 strut.
My parts list:
'00 929RR Erion Edition shock ($21 shipped from *bay)
1/2" x 4" galvanized steel plumbing pipe ($3 from Lowes)
M10 x 1.50 x 110mm bolt ($2.75 from local supplier)
3 steel washers ($0.48 from Lowes)
M10 x 1.50 lock nut ($1.45 for two pack from Lowes)
2 1/4" alternator spacer from '64-'76 V8 Mopar (on hand)
Hint: if you can find a M10 x 1.25 x 110mm bolt, you could use the the stock lock nut, which has a metal lock instead of nylon. They were out of stock locally...
Pulling the stocker was a snap thanks to jacking up the swing arm!
Getting the tack welded bolt off the VFR mount was a b*tch. I used an air saw then the Chevy tool (32oz hammer) with the mount in a vice to encourage the welds to let go. Here's what came out:
Posted Image
(sorry the image isn't clearer, using a borrowed camera)
After measuring and re-measuring, I cut my spacer pipe to ~37mm (1.455" according to the dial caliper). With the reservoir barely touching the undertail, rear height is up ~12mm. My 3 stack of washers measured 0.241" for a total additional spacing of ~43mm (1.696") from stock.
Here is the mount before priming and paint:
Posted Image
And here's the alternator spacer inside the pipe. It pressed in easily with the vice:
Posted Image
The shock will slip into place with the new spacer/mount already attached (don't torque fully until it is in place).
I used these guidelines to preset the shock:
http://www.sportrider.com/bikes/146_suspen...ngs/index4.html
Hope this helps somebody else looking to do the same update.
Tomorrow will be setting the sag and going on a check ride. Wish me luck!
Helmet side up, rubber side down.
0
#19 User is offline   vifferluv
  • PipPip
  • View blog
  • View gallery
  • Group: Members
Thank You's: 0
Neutral
Posted 27 June 2006 - 10:59 PM
Riding Impressions
This is a whole nuther bike. Everything feels more stable: in the turns, over rough road, putting power to the ground. I feel like I'm riding slow because of the difference from stock.
I've ridden a buddy's track prepped '01 R1 quite a bit. It has an Ohlins. I would say the 929 rear suspension setup on my VFR is equally confidence inspiring.
Of course, now the front suspension's limitations seem even more pronounced. I can only imagine the handling prowess and stopping power of an RC51 fork/brake swap. Hoping to at least go Race Tech springs/valves with F3 cartridge meld.
I would suggest this update to anybody not timid of the detailed steps. Even if you don't have access to a welder, you can measure everything and have a local shop weld the spacer in place.
Also, I checked the price on the upper mount ($9.89) just in case I needed to fall back to the stocker. Might be a good backup for anybody on the fence:
http://www.ronayers.com/browseparts.cfm?se...g=50233-MZ7-000
Now there are no excuses ;)
0
#20 User is offline   Drizzt
  • World Superbike Racer
  • PipPipPipPip
  • View blog
  • Group: Members
  • In My Garage::'99 VFR
    '98 F3 Trackbike
    '77 KZ 1000 Dragbike
    '75 CB400F SuperSport
Thank You's: 0
Neutral
Posted 24 February 2007 - 07:19 PM
WTF? I've got mine all fabbed up and am trying to install, but the only way it fits puts the adjustment screws to the RIGHT side of the bike where it is rather difficult to get at them. Been scouring the site for a pic of one installed, and all I've come up with is this one from Rob:
Posted Image
But I think that is a 954 shock from the way I read it. What am I missing here?!?!?! I haven't ridden in six months, I NEED to get this back together!!!
Edit: here is my shock, from what I've read I believe it's a 929 item. Perhaps I am mistaken?
Posted Image
"Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure or nothing" ~ Helen Keller
"Loud Cams Save Lives"
0
#21 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 25 February 2007 - 03:03 PM
Don't know how helpful this is going to be seeing as how my bike is in pieces at the moment.
I guess you can see the shock really well, but nothing else.
Maybe the interference with the plastic undertray you are experiencing is not a problem for me because of my underseat exhaust?
I cut and modified the plastic battery box and rotated it forward as much as possible for the exhaust project.
Posted Image
Posted Image
Posted Image
Posted Image
Good luck, I'm sure you can make it work. Maybe trim the battery box if possible?
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#22 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 25 February 2007 - 03:07 PM
Oh, and the shock in the first pics in this thread IS a 954 shock, the one with the yellow spring and gold reservoir.
The later shock with the white spring and the black reservoir is an Erion edition 929 shock.
Yours is a 929 shock based on the reservoir design, spring colour be damned.
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
#23 User is offline   turtlecreek
  • Ham Fisted Fat Bastage
  • View blog
  • View gallery
  • In My Garage::Silver 2003 VFR
    2005 Sir Squidly Gixxer 750 Track Bike
    Gone: 1997 YZF600r, 2005 Yamaha Roadstar
Thank You's: 5
Neutral
Posted 11 June 2007 - 09:46 AM
View Postsnowparang, on Jun 11 2007, 08:51 AM, said:
Besides the 929/954 shocks, any other compatible ones? RC51? Ducatis? R1s/R6s?
Compatible as in mounting points, length and travel. Spring is not a big issue as it can be replaced quite easily.
i just put an f4i shock on mine. .5" shorter, so you simply add washers or spacer, but standard mount worked great. upgraded my spring and had it revalved. shock was ~$20-30 OFF ebay and the spring was $100 and the revalve was $150...so $300 and i practically have a new show w/ reservoir and compression adj.
here is link:
http://www.vfrdiscussion.com/forum/index.p...mp;#entry395670
I learned a long time ago, best way to realize the danger of your pace is when it goes from that speed to zero really abruptly.......mighta' been faster than I thought......Skuuter Posted Image
"Courage is almost a contradiction in terms. It means a strong desire to live taking the form of a readiness to die. 'He that will lose his life, the same shall save it' is not a piece of mysticism for saints and heroes. You must seek life in a spirit of furious indifference to it; you must desire life like water and yet drink death like wine." GK Chesterton
MODS: Givi Windscreen Factory Windscreen due to Dragon Bite, Sargent Seat, Headlight Modulator, Heli Bars, Padded Grips, PCIII USB, 30 Amp Fuse Upgrade, Fender Eliminator, Evap Canister Removed, PAIR Valve Removed, Flapper Mod, De-Snorkled, O2 Sensor Removed/Plugged, BLS Footpeg Mod, .95 Racetech Springs and Ohlin Valves, F4 Shock Rebuilt/Resprung to 950lb for Fat Arse, '99 Catless Headers, 15T Front Sprocket, Vecky5 Gutted Exhaust, Riv's Hugger, 12v meter, VFRharness w/ relay block, Speedohealer
0
#24 User is offline   BaileyRock
  • View blog
  • View gallery
    04 vtec track pig
    07 SYM Fiddle 50
  • Signed Flaf:
Thank You's: 29
Excellent
Posted 11 June 2007 - 03:09 PM
View Postmechdziner714, on Jun 11 2007, 02:49 PM, said:
I am looking to do the 929 shock upgrade to my 5th gen soon. Is there a particular model year 929 shock needed. I was also wondering if pre-load adjustments are still easy, as they are w/ the 5th stocker? Would it be worthwhile to have it revalved/rebuilt before installing. My guess is its easy enough to remove and have re-worked if it turns out the one I get from fleabay is worn out.
The 929's were only made in 00-01 models and standard one's had a yellow spring and Erion models had white springs. Stock they have the SAME spring rate as the VFR so other than spacing it's a straight bolt in w/o mods. Most people want/need a heavier spring on the VFR so that would also apply to the CBR shock on the VFR, but you can sure run it untill you plan to upgrade the rest of the suspension w/o issue! :thumbsup:
Someone here did use a 954 shock too if I'm not mistaken, but the 929 is the easiest mod for the 5th gen.
Also look here.
http://www.vfrdiscussion.com/forum/index.p...c+shock+options
current bikes
07 GSXR 750(SOLD!)
0
#25 User is offline   BaileyRock
  • View blog
  • View gallery
    04 vtec track pig
    07 SYM Fiddle 50
  • Signed Flaf:
Thank You's: 29
Excellent
Posted 11 June 2007 - 03:12 PM
View Postadmw12, on May 6 2007, 06:47 PM, said:
I have a 2004 and neither the 929 nor the 954 shock will fit either way( facing left or right) and keep the same ride height. I made a spacer the length of the difference between the stock shock and the 954/929, well the res on the 954 hits the engine, and the 929 hits a hard line ( hydralic probably). So now I have to buy a longer bolt and make a longer spacer. This however will change my ride geometry and change the handling of the bike. Something I wish I didn't have to do. Anyhow, anyone have any other suggestions ( rather than buying a $1000 shock).
Check here, he installed a 929/954 shock on a Vtec!
http://www.vfrdiscussion.com/forum/index.p...0506&hl=929
current bikes
07 GSXR 750(SOLD!)
0
#26 User is offline   MikeG
  • Club Racer
  • PipPip
  • View blog
  • Group: Members
  • In My Garage::2006 ST1300
    99 VFR
    82 CB900F
Thank You's: 0
Neutral
Posted 25 June 2007 - 08:19 PM
I am jumping in late to this thread but am interested in the 929 swap. Is the main advantage of the 929 shock that it has both compression and rebound damping? I also have an almost new CBR1100XX shock, but that looks like the VFR shock-only rebound damping. I also looked at the F4i shocks but it sounds like they need new springs and valves even though they have a remote reservoir. Any advantage to those over the 929, other than the length being closer to the VFR?
0
#27 User is offline   VFR FLYER
  • Grumpy Old Man!
  • View blog
  • In My Garage::Y2K YELLOW VIFFER
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 25 June 2007 - 10:43 PM
View Poststic3, on Jun 25 2007, 07:22 PM, said:
Has any of VFRD's master fabricators gone into the business of making up 929 shock adapter kits for us less gifted members? I am sure there is a market for such a item.
from what rob posted earlier, the 954 shock is not a good option. be advised the 929 install will require some trimming of the battery box. i made several spacers of different length from 1" steel round stock. i have since decided, even painted they would start to rust. (yuk) i bought a length of 1" square bar stock of 6061 aluminum. part is much better (not perfect but i'm trying). the most critical part is the top mount hanger. the 10mm bolt has to be removed and replaced with 120mm length, welded into place. and then the bolt head has to be ground down about half its height. the stock hanger costs $12.01 plus shipping from ron ayers. so they raw costs of parts for me is about $20. rob made his own for $2 ?. having a used hanger would save the $12 but how long would the bike be apart waiting mod. if your still interested, send me a PM
0
#28 User is offline   VFR FLYER
  • Grumpy Old Man!
  • View blog
  • Signed Flaf:
Thank You's: 1
Neutral
Posted 04 August 2007 - 05:06 PM
this post shall never die! too much good information. i've noticed lately some of these same questions keep coming up, so i decided to add a little more information. if a person has the ability to modifiy the mount for a 929 shock. i would suggest you make a new top bracket rather than use the old one. if you reuse the old one you must grind or cut the top half of the bolt head off for clearence of the top of the shock. this may NEVER be a problem, but i worry just the same. enco sells 1"x1/4"x36" ground flat bar for $22.22. you could still have the 929 shock bought and mounted under $100. your not going to beat that deal!!!! :wheel:
0
#29 User is offline   opus
  • PipPipPipPip
  • View blog
  • View gallery
  • Group: Members
  • In My Garage::1995 VFR 750F
Thank You's: 0
Neutral
Posted 18 April 2008 - 08:59 PM
So for the people that have done the bracket welding, are you just welding the hex head of the bolt right to the top of the bracket, or is it below next to the shock? I'm really fuzzy on this part and I don't see any pictures that show how the bolt gets welded to the bracket.
One picture shows the old bolt totally removed and the new bolt sticking up through the bracket. But the hex head is below the bracket, and in later pictures it's gone. Do you weld it to the bracket and then cut off the hex head? Or???
Help! I am stuck at this step and want to get my bike put back together.
1995 VFR with a 929 shock.
Thanks!
opus
0
#30 User is offline   Veefer800Canuck
  • Gear is good!
  • View blog
  • View gallery
  • Signed Flaf:
Thank You's: 20
Excellent
Posted 21 April 2008 - 08:27 AM
Thanks!
Opus, I did not weld the bolt to the bracket.
I had to grind the bolt head thinner so it would clear the shock eye, then I installed the lengthened bracket into the frame, then bolted the shock to the bracket.
But I did not weld the bolt to the bracket. You could have that done, no reason why not.
Posted Image
Rob McKinnon
'99 GL800RR-SP2
Quote
Quote
0
Share this topic:
  • (6 Pages)
  • 1
  • 2
  • 3
  • Last »
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
